#41 |
01 True Blue v6
to slow to matter
Don't know if you still wnated pics but here's mine.
#42 |
get some rims on that bish!
Selling Mustang So Im Selling All M112 Parts |
#43 |
01 V6 convertible
too slow to try
Ok, so was installing everything tonight and hit a few tough spots, maybe if anyone has any advice...
a) removing the front spring... we tried a spring compressor (the one that hooks down the center of the spring) and there wasn't enough room for the bolt to be tightened and compress the springs... so then we lowered the lift, put a jack under the control arm, took off the strut and sway bar connection, and slowly lowered the control arm... well, the spring was still tight in there, we did a lot of prying and tugging, and finally pryed it out with frustration (kinda worried about breaking the tie rod... not sure if that's possible by forcing the control arms too low) getting the new spring back in was a pain in the ass too, because we couldn't use the compressor again, so we just kind of pryed that in place... Any pointers to make this easier? lol b) we got the CC plates in place, strut in and ready to be tightened down... but ran into a problem, don't know how to tighten the top bolt... it just spins the whole rod... almost like we need a certain tool to hold the center notch in place while screwing the nut in place... (screwdriver and wrench didn't work)... is there some special tool for this I'm not thinking of? other than that, the car is about 3/4 done, just need to finish the front passenger side... but my friends were getting tired...lol some progress pics... thinking of eventually painting these red to match... cause my friend suggested we paint the rear diff and axle black just for the hell of it... ![]() ![]() So much easier with my friend's lift... ![]() ![]() ![]()
#44 |
MM's Official Lucifer
nice! god how I wish for a lift like that!
As far as the springs go, you dont need a compressor, as you found out it only makes it harder. Drop that A-arm as low as it will go, then seat the spring in the a-arm then raise it up. Prying/forcing, etc. is necessary. Make sure you have the springs lined up the same way the stockers were. For that strut its basically what you were attempting... prolly just got too fatigued to finish. A nice heavy screwdriver in the top of that nut while someone else spins the wrench. What I actually did was fabricate up a new tool with a strip of metal. Just grinded one end down til it was thin enough to fit into the nut. That gave a better grip and a lot more torque than a screwdriver...
"Fast she goes...in the city of Overdose" ![]() |
#45 |
01 V6 convertible
too slow to try
yeah well really we were attempting that method with the strut on the old corroded one... because for some reason we thought we needed the two "cup shaped" peices on both sides of the bace plate on the stock strut... then realized that we didn't need those...
(btw is there any parts at all on the stock strut or plates that are needed to be re-used with the aftermarket stuff I have?) so it wasn't working on a corroded strut, but I bet it'll be easier with the brand new stuff |
#46 |
2003 v6
![]() iTrader: 2 reviews
NO you shouldnt need anything from them, unless your new stuff didnt come with bolts...
#47 |
^ Yup, you should be able to toss everything from the stocks. Just don't do it until you install all the new stuff and have the car on the road, that way you'll know for sure.
#48 |
01 V6 convertible
too slow to try
way ahead of ya
![]() finished the install yesterday and it's now back on the road! (and a little closer to it )pics will be up soon! |
#49 | |
2001 Mustang V6 Coupe
#50 |
01 V6 convertible
too slow to try
#51 |
yeah i have the pro kit. i love the way they look. not too low and they ride is perfect. not much rougher than stock.
2003 3.8l Sonic Blue 2007 GSXR 750 For Sale: Eaton M112 supercharger/plenum/ and 2 cobra TB's only $375!!! PM me!! |
Threads Similar to: lowering the 6er...
| New Siggy For 6er... | 6ER THEN I 8ER! | Chopshop | 10 | June 3rd, 2009 01:47 AM |
| Getting a new 6er! | lwhitetrash88l | V6 Mustangs | 31 | April 15th, 2008 12:49 PM |
| New 6er | ItaliStang | New Members Introductions | 13 | November 5th, 2007 03:55 PM |
