My procharged v6 - Page 2
Old September 15th, 2009, 12:14 AM   #21
1994 V6
Flex is on a distinguished road
Dudes,
You need to chill. JT, run your car and then the debate will be over. You'll know exactly where you are at. Just have fun man, that's what its about. I am curious as to why you said a Walbro 255 is not good.
Old September 15th, 2009, 06:16 PM   #22
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
Originally Posted by Flex View Post
Dudes,
The warboro will not work because in 99-04 the v6 has a returnless fuel system...Witch requires a pulsating pump like the focus or gt-40 pump for hi flow. The warlboro is meant for a return fuel system and will over heat and burn up in the 99-04's.
I agree on letting my car do the talking.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old September 16th, 2009, 08:07 PM   #23
shine1stang's Avatar
97 v6 mustang
10.71@125
shine1stang is on a distinguished road
nice setup man
97 v6 tma turbo
600hp and 10 sec v6 member
xxxhp @21psi 10.71@125mph
http://www.youtube.com/watch?v=hBoRWBr77Do
Fastest Single Port V6 Mustang w a Ported Stock Upper Intake
www.gssmotorsports.com
Old September 16th, 2009, 08:24 PM   #24
slvr2000stang's Avatar
2000 Mustang
14.10@96.75
slvr2000stang is on a distinguished road
Nice setup.
Hope you reach your goals with it. I like your "it will run what it runs" attitude. That's a good way to look at it.
2000 V6 vert
2003 Lightning
Old September 16th, 2009, 11:18 PM   #25
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
This isnt my best run because track prep was not all that great. Also I was just starting out learning on how to heat the nitto 555r. I was a little to deep in the water box when I did the burn out and I think I pulled water onto the track with me. Something like a 2.1 60' with 3.73 and stock stall.
[youtube]rXxBglWw0UI[/youtube]
Old September 17th, 2009, 07:28 AM   #26
2000 Mustang
14.10@96.75
You just need to get a set routine and stick with it.
Doing your burnout & staging the same every time will help you out.
2000 V6 vert
2003 Lightning
Old September 17th, 2009, 10:12 AM   #27
236Mustang's Avatar
236Mustang will become famous soon enough
very nice man and welcome
1995 Turbo V6 Mustang (auto)
Check out my build <----
ET: 14.1@99mph (coupler blowing off/MBC failing )
Built by Iron Horse Motorsports
Old September 17th, 2009, 03:29 PM   #28
97 v6 mustang
10.71@125
+1 definitely helps
97 v6 tma turbo
Old November 16th, 2009, 11:34 PM   #29
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
Just to update this...I have installed a cam and plan to dyno it sometime later this month or early next month. First I have to send some wot pulls to my tuner to make some adjustments. In addition the heads and intakes have been gasket matched, upgraded springs, comp retainers, comp pushrods. The cam specs are 216/222 .541/.541 112*.
The car has definitlly picked up quite a bit of power and tq at part throttle. Havent been able to do a full wot pull because the tires will spin badlly even at 50mph. That will be fixed this week sometime. fedex man brought me some new 555 275/40r17's today. Although I do have some 555r's mounted on my stock 16's I have been to lazy to swap the rims.
Hoping to be detuned to around 360-370 for longevity.
Old November 16th, 2009, 11:51 PM   #30
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
Sounds like you have a great setup. That is exactly what I want to do with my car except mine is a manual. You are lucky!
UDP, CAI, True Duals, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, FRPP C Springs, and J&M Full Length Subframe Connectors
Great Automotive How To's http://tooldesk.com/blog/
Old November 17th, 2009, 02:30 AM   #31
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of light
360-370, with what mods at what psi?
Hi, You can call me Kyle
Old November 17th, 2009, 06:11 PM   #32
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
Power mods are procharger d1sc boosting to 12-13 psi. Gasket matcked heads and intakes. Gasket matched 97 windstar upper. 70mm tb. cam. Dual exhaust running cutouts and highflow cats. All the fuel mods. Griffen 3" aluminum race cooler. Have a snow stage 1 kit but not hooked up(may sell it). Also have a 110 oct mix tune. Tuned by justin starkey.
Car made 318/326 pulling to 5000 rpm with the 3.6" pulley...had sprak blow out and could not pull to 6000rpm last dyno'd.
Old November 17th, 2009, 07:23 PM   #33
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Don't set yourself up for disappointment, those type of numbers don't seem to be achieved without nitours, big vavle heads, or 4.3L
Old November 17th, 2009, 08:10 PM   #34
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
It's been done on a p1sc 11psi stock heads and cammed.
Old November 17th, 2009, 08:27 PM   #35
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
who/where?
only rare case of any numbers close to that would be stang38l, that's 1 car out of like 15. All the others are 310/320. But hey hopefully you make those numbers.
Old November 17th, 2009, 09:32 PM   #36
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
who/where?
I'm making more than those numbers now. Those are stock p1sc numbers with the 3.6" pulley. The d1sc has a much better mid and top end. But yeah hopefully I do hit my goals. We will se what happens in the next couple weeks.
Old November 17th, 2009, 09:37 PM   #37
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
is your dyno posted anywhere?
Old November 17th, 2009, 09:47 PM   #38
Ticket-Me-Yellow's Avatar
2001 Mustang V6
14.89@93 mph
Ticket-Me-Yellow is on a distinguished road
Send a message via AIM to Ticket-Me-Yellow
Bud i say just run your car. That will fix everything here
Selling Mustang So Im
Selling All M112 Parts
Old November 17th, 2009, 10:13 PM   #39
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
You can see my dyno with the 3.9" pulley at vapauto.com. The other graph was not posted on the web but I do have the graph. It is with a 3.6" pulley swap. Made the numbers in my sig pulling to under 5000rpm.
Old December 28th, 2009, 11:58 PM   #40
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
Update....Ordered a custom stall...3300...From direct trans. Heavy duty billet cover....chrome moly hub...Anti balloning plates...Strenghted welds. $535 dollars shipped to my door. My buddy runs one of these converters in his blown fox with great results.
Pretty excited about it and cant wait for the track to open back up in april to try this thing out. I need to run a 7.8 or better to be faster than my buddys blown fox. If the new cam,stall,tires,and suspension come together I dont see why I cant pick up .6 seconds in the 1/8th.
Hoping this is the last high dollar peice to the puzzle til I build my sc block. Except maybe the front suspension and a few tubular parts out front.
Decided to stay with the 373's to see how they do with the new stall but will be putting in the detroit locker when I drop my trans.
Threads Similar to: My procharged v6
Procharged slrvstang2007 2005 - 2010 3 June 11th, 2008 08:53 PM
Procharged Mustang GT apicia 99-04 17 February 9th, 2008 04:55 PM
Procharged 05... 9.53et manOwar Videos 6 January 10th, 2007 11:09 PM
