#41 |
2001 Mustang V6
14.7@95
You won't believe the difference a stall converter can make. Thats the best bang for the buck on autos. Make sure you run drag radials or slick, you'll need it for the extra thrust off the line!
2001 Mustang V6 - Was Procharged. Current Mods: Granatelli Sports Tune, Cold Air Intake, Underdrive Pulleys, BBK Throttle Body, TB Spacer, MAC Cat-Back- Appearance Mods: Looks like a GT. |
#42 |
2001 Mustang V6
14.7@95
I agree. Go run that mustang!
#43 | |
You should almost pick up that time with the stall alone IMO. Everything else should be just butter. Cam will do wonders as well if it is geared more toward a blower cam.
436rwhp/378rwtq tuned by HPP www.hppmotorsports.com - www.stangcharger.com - www.rpm-mustangs.com |
#44 | |
[8MINUS2]
#45 |
2003 V6 Mustang
14.2 @ 96
#46 |
[8MINUS2]
Yeah, I would think an eaton would do better 1/8th than a centri.
#47 |
Unless the centri is a standard and can launch at what ever RPM he wants.
#48 |
2003 mustang
7.48x1.56=11.67
Really I'd like to break 7's is all. But I know what your saying...Once you get to a certain point it becomes harder and harder to shave off those tenths.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
#49 |
7.8s is bottom 12s thats a far hit and shot. good luck with it though man
#50 |
[8MINUS2]
^ this also.
#51 | |
2003 mustang
7.48x1.56=11.67
If I'm running 87mph with a shitty 2.03 60'...Say I 60' at 1.8 with the new converter...that would be a couple miles faster in the 60'...and give me a higher trap all together. I would have to run around 90-92mph to hit a 7.8. This is all given the tires hold the track. At this point to run a 7.89...The track is going to have to be near perfect condition and I'm going to have to be near perfect launch and shifts. Also the colder weather the better. Another way would be to rev to 6500rpm...but I dont want to go that high on stock block. I shift 5800-6000 usually. Not trying to bench race but the track is closed til april so all I can do is talk about it
#52 |
i wouldnt rev past the 6000mark on the stock bottom, the stock rods are to weak for high RPM like that, especially with a power adder. really a good stall can easily break you in the 1.7 60fts
#53 |
2003 mustang
7.48x1.56=11.67
![]() My converter was delivered today. It's reall a nice peice.
#54 |
[8MINUS2]
A big red blob
#55 |
2003 mustang
7.48x1.56=11.67
And a messy ass work table lol.
#56 |
looks nice!!!!
![]() UDP, CAI, True Duals, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, FRPP C Springs, and J&M Full Length Subframe Connectors Great Automotive How To's http://tooldesk.com/blog/ |
#57 |
97 v6 mustang
10.71@125
awesome buddy!!
97 v6 tma turbo 600hp and 10 sec v6 member xxxhp @21psi 10.71@125mph http://www.youtube.com/watch?v=hBoRWBr77Do Fastest Single Port V6 Mustang w a Ported Stock Upper Intake www.gssmotorsports.com |
#58 |
2003 mustang
7.48x1.56=11.67
Started installing the converter today. Cant find out if the 4r70w has 2 or 3 electrical plugs on it. Dont want to drop the trans and pull wires loose.
I will post back with the results if the roads are clear.
#59 |
I am building a 4.2 "longrod" form super-six motorsports and will be running an eaton M98 at 10 PSI, with a small stall (B&M torker 2000) AOD, 3.73's in a 1983 'stang 'vert. It will be a month before my pistons get here, but it will be based on a .060 over S/C motor times and dyno slip to come. Rick
3 Mustangs 1 Lincoln Hearse 1 Lincoln ragtop 1 mercury Sable Savior of the 4-eyed 'stang Last edited by plstktnkr2; February 14th, 2010 at 10:26 AM. |
#60 |
2002 Nitrous Injected V6
12's?
Go for the 12's man, Goodluck. Any reason the tumbnails arnt working for me
![]() Project Red Magic -Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped- -18 Inch Hypercoated Saleens wrapped in Nittos- |
Threads Similar to: My procharged v6
| Procharged | slrvstang2007 | 2005 - 2010 | 3 | June 11th, 2008 08:53 PM |
| Procharged Mustang GT | apicia | 99-04 | 17 | February 9th, 2008 04:55 PM |
| Procharged 05... 9.53et | manOwar | Videos | 6 | January 10th, 2007 11:09 PM |
