Trans question need help
my transmission is acting up at least i think it is the transmission but when accelerating it won't shift i have an auto and it will way over rev it will not shift till i let off the throttle so wtf is going on this tends to do that more often in a heavier accel. than in low but does it all the same
2000 Mustang V6 |
#2 | |
Re: Trans question need help
i have already done that should have stated that i guess but i have checked the fluid it looked like new and i haven't started at ne of the other places but i'm going to use some trans service bottle into it today or tommorrow if i can cuz u know hard to find time but as far as that goes what if that doesn't do it what would i need to do if it is ne of the things said above
2000 Mustang V6 |
MM's Resident Ricer
2006 Scion tC
13.001@113
whats it revving to. If your at WOT you'll shift around redline.
i let off of it before i get there i aint stupid but it gets around 5000 before i will let off of it this is driving me up the wall i was beat in a race the other day because of this if it helps it does it most often in 2'nd & 3'rd gear
2000 Mustang V6 |
#6 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
try staying in the gas a bit it will shift around 5.2 or 5.3 if it gets past that let out, but mines shifted right at redline before I got my tuner.
well the question bout that is will it hurt the engine if i got it that high of a rev and how i fix shift bands if u don't mind tellin me
2000 Mustang V6 |
MM's Resident Ricer
2006 Scion tC
13.001@113
it won't hurt it as long as you don't get deep into the redline you get to about 6.5 let out fast you should be no where near there with out a tune. The 3.8 is a strong block. If you want to change your shift bands get an x-cal2 or livewire and you hae control over all that.
#10 | |
ps dont do what i did i just beat my explorer untill it puked and scrapped it lol i think every thing that could leak was leaking once i was done with it lmao rear end transfer case tranny engine oil and coolant lol and the rear washer fluid leaked too lol
ok i'm going to give the trans fixer fluid a try and i will see where i'm at then it still going on i take it to my mechanic he does wonders and just a good guy don't charge ya inless he actually did something hard ya know but thanks i see where i stand after this trans fixer thanks
2000 Mustang V6 |
#13 | |
here is all the possibilities of whats wrong with your tranny for what your experiencing could be vacuum line has broke fallen off or caused a leak too.http://autozone.com/servlet/UiBroker?UseCase=S001&UserAction=viewSimpleDiagRes ultsInfo&Parameters=Automatic+Transmission|~2|~Dri ving|~22|~Delayed+Shifts|~45|~Feels+like|~1&FROMJS P=type
ok i will work on it i post back when it fixed
2000 Mustang V6 |
Threads Similar to: Trans question need help
| A trans question for a 92 mustang | kaine420 | 5.0 Mustangs | 9 | June 10th, 2007 12:12 PM |
| no trans filter on 5-speeds? (newbie question) | YNOT | 5.0 Mustangs | 6 | May 9th, 2007 10:52 PM |
| 86 5.0 trans Question? | 86foxgt | 5.0 Mustangs | 1 | April 11th, 2007 11:07 PM |
| Question on AOD Trans - No 3rd Gear....Help please!!!!! | TomF514 | 5.0 Mustangs | 4 | January 7th, 2007 02:55 PM |
| mach 1 trans question... | delgadog | 99-04 | 2 | December 23rd, 2006 07:47 AM |
