Throttle positioning sensor =frustration! - Page 2
Old September 20th, 2009, 12:15 AM   #21
stephen has a spectacular aura aboutstephen has a spectacular aura about
This is an explanation
Setting the Mustang TPS Voltage
From what you describe it sounds more like a problem with the idle air control valve (IACV). The throttle body should close all the way down to the stop screw and then the IACV controls air at idle. The TPS should have come with the throttle body.
Also the MAF determines the flow rate and could be contributing to the problem. The computer is taking in data from the TPS, MAF, and oxygen sensors to adjust the mixture.
Old September 20th, 2009, 12:39 AM   #22
According to this the TPS isn't adjustable
Mustang TPS FAQ
It explains how the system works.
Old September 20th, 2009, 03:18 AM   #23
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
Personally I would think that it's a defective replacement part.
If it's any sort of electronics or parts that need to be very accurate I'd go with factory parts. I've seen a lot of complaints that are fixed by putting factory sensors on in place of a cheap sensor from auto zone. Not to say that all aftermarket sensors are junk, I just prefer factory.
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Old September 20th, 2009, 10:46 AM   #24
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
Mustang TPS FAQ
You adjust it with the set screw.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old September 20th, 2009, 06:25 PM   #25
boblongtv's Avatar
1999 V-6, 1998 gt
Hey she looks fast
boblongtv is on a distinguished road
Send a message via AIM to boblongtv
I put my stock tb back on and its still messed up. I never touched the set screw so I dont think that is the problem. It has to be the sensor. Do you think there is a big difference between a factory tps and an autozone one?
Old September 20th, 2009, 07:21 PM   #26
2004 V6 & 2000 GT
Only in the quality of the parts as far as I know.
I haven't ever tested one sensor against another so I'm not sure which is more accurate. I do however know that a lot of the time people put on these aftermarket sensors and they can cause issues. It also may fail sooner than a factory part.
I know a lot of people are against the whole dealership but sometimes it is better to just use the original parts.
I don't know if you've tried disconnecting your battery yet or not. If you haven't try disconnecting it and let it sit for about 10 minutes. That should reset the KAM. Which will reset your idle and all other adaptable parameters.
Also someone mention and IAC valve. This could be stuck open. Try removing it and cleaning that if resetting your KAM doesn't work.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old September 20th, 2009, 07:53 PM   #27
boblongtv's Avatar
1999 V-6, 1998 gt
Hey she looks fast
Ill try that. Could I have put the sensor in wrong?
Old September 23rd, 2009, 03:16 PM   #28
boblongtv's Avatar
1999 V-6, 1998 gt
Hey she looks fast
So today im supposed to get this fixed and I took off my stock tb again to switch it back with the 65mm bbk one. I made sure I did everything correct. I looked at the pics of wat my tps should look like and I believe I have the wrong kind.....It is a ford mustang tps but an offbrand and the mounting locations are wrong, compared to the OEM picture of the tps mounting locations.
OEM tps PIC: http://i649.photobucket.com/albums/u...621933DEL1.jpg
autozone tps pic: http://i649.photobucket.com/albums/u...gtv/141136.jpg
Old September 26th, 2009, 03:40 PM   #29
boblongtv's Avatar
1999 V-6, 1998 gt
Hey she looks fast
I fixed it!!! I bought a new tps from the ford dealership. Thanks for yalls help!
Threads Similar to: Throttle positioning sensor =frustration!
throttle positioning sensor 03silvergt954 99-04 9 September 15th, 2009 04:05 PM
Crankshaft Positioning Sensor - "Special tool" fairlaniac 2.3 Mustangs 0 July 30th, 2009 08:52 AM
camshaft positioning sensor 1999.35mustang V6 Mustangs 2 October 9th, 2008 03:53 AM
throttle position sensor 88stang 5.0 Mustangs 2 July 7th, 2008 03:05 PM
camshaft positioning sensor mmvi V6 Mustangs 7 August 4th, 2007 02:01 AM
