Discussing Stroked and Supercharged V6 in the V6 Mustangs Forum. Great looking project man, the craftman ship really shows in those engine pics, everything is ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
| View Poll Results: When this project is "done," what should the next upgrade be? | |||
| Suspension (shocks, struts, braces, sub-frame....) |
5 | 45.45% |
| More engine (rockers, pulleys, E-85....) |
0 | 0% |
| T-56 conversion |
2 | 18.18% |
| Built 8.8 swap |
1 | 9.09% |
| Boost Cool or Nitrous |
3 | 27.27% |
| Voters: 11. You may not vote on this poll | |||
#21 |
2001 Mustang V6
Great looking project man, the craftman ship really shows in those engine pics, everything is "Mr. Clean" looking.
#22 |
'02 Stroked/Blown 4.2L V6
Well since you asked so nicely I do have a stock shift knob my dog plays fetch with and 4 M10 broken off bolts you could have...
James02Mustang - Project "V6KR" - Stroked/Forged/Blown 4.2L V6 http://www.mustangjames.blogspot.com Yellow Mustang Registry Member #6644 http://s270.photobucket.com/albums/j...2mustang/V6KR/ (PROJECT PHOTO ALBUM^)
#23 |
Thank you!
#24 |
So I got all the sensors hooked up and no change... When I turn the key on the theft light flashes at various speeds, high speed fan runs constant, IAC does not reset, odometer reads all dashes, fuel pump does not run, does not crank and the module in the right front fender clicks when the car is keyed up.... I've been wrecking my brain for an answer and I'm stumped...
#25 |
1997 Pacific Green 3.8
Nice!
That's gonna be one nasty V6 Mustang! I want to eventually build up a sick 4.2l V6 engine similar to this one. Any tips for me just starting on the early planning stages...
-Nathan (formerly known as Stang3.8) "I'm Nate, I'm Nate- I got a three-eight!"
#26 | |
Tip 2: Save some more, you'll need it. Tip 3: Do LOTS of building and parts research. Tip 4: Shave your head so you can't pull your hair out.
#27 |
2001 Mustang V6
^^Nice.
I vote for this to be "Advice of the Year from MM" |
#28 | |
Perfect!And, I have been looking at SuperSix Motorsports' crate motor deals. If I save up enough money I could just buy a really nice 4.3 stroker to drop in- possibly with a T-56 hanging off the back of it...
#29 |
02 Mustang V6
I had a similar PATS situation w/ a 04GT. Changed ECU's and didn't change the gauge cluster so it wouldn't fire. Had to disable pats on the ECU w/ my flash tuner (Sniper in my case). Best bet to get your laptop back up and running to flash a tune w/ PATS disabled... my two cents
BBK Intake, BBK 75MM Throttle Body w/ Port Matched Upper Intake, BBK Shorty Headers, Magnaflow Exhaust, GT Tips, Eibach Sportline Springs, EGR Delete, ZEX 75 Shot, Sniper Tuned for 93 Octane w/ Nitrous
#30 | |
#31 |
IT TURNED OVER! Still got a list before it runs, but it's getting closer!
#32 |
2005 Mustang V6
In time, it will be well worth it!!! Nice work...
#33 |
UPDATE: Got the car pulled back to the garage from winter storage. Fixed the PCM issue, the problem was a wrong bank mode in the Tweecer cal corrupted the computer and then it went into lockdown (no start). Got the A/C taken out in prep for the delete kit. The "to start" list is getting shorter, expecting to make some noise mid spring.
#34 |
'02 4.3L V6 / '95 GT 5.0L
*subscribed*
#35 |
High HP V6 guys... what are you using for a radiator??
#36 |
1999 mustang 3.8 5spd
Faster than my wifes VW TDI
Subscribed, Waiting in anticipation..........
#37 |
I hate school. I only have weekends to work on the car for another month....
#38 |
Great job on the photo album.
#39 |
2003 Mustang V6 Conv.Auto
I hate to come in and ask this question so late in the thread, but where did you get that whole M90 setup?, I've never seen one like it.
#40 |
It is basically stock off a 1993 Thunderbird Super Coupe.
Threads Similar to: Stroked and Supercharged V6
| stroked s197 | tarpeeler | 2005 - 2009 | 17 | July 4th, 2008 09:26 AM |
| 342 Stroked | whitefox89 | 5.0 Mustangs | 25 | December 5th, 2007 03:51 PM |
| I stroked off a Smurf.... | homebrewed | The Clubhouse | 28 | May 12th, 2007 11:09 AM |
| Stroked and bored? | MySallyMI | 99-04 | 9 | April 16th, 2007 06:28 AM |
| NEED ADVICE: especially if someone has stroked and engine | 94' Cobra 351 | 94-95 | 8 | January 17th, 2007 08:20 PM |
