Windstar Intake + Smog pump?
I have a Windstar upper intake manifold on the way from Vapauto.com. It says on their site that it requires you remove the smog pump on 99-00 Mustangs for installation.. would it be possible to relocate the smog pump? Are there any pictures of anybody doing this?
PS. I have a 99 v6 and I live in California, so I don't believe deleting it would be an option, as I wouldn't pass smog tests. |
2000 Mustang
Some 99-00 v6 stangs came with smog pumps, you need to find out if you actually have one
![]() Detailing Crew Member North Carolina Modded Mustangs #5 Last edited by 00BlueMustang; September 23rd, 2009 at 12:22 AM. |
01 True Blue v6
to slow to matter
Um. . . .Did you buy it already? You prolly should of asked the question before it was "on its way". I haven't heard of anyone doin this, but hopefully someone else will be able to help you a little better than I.
MM's Database Error
he does have one, and its prolly faulty since he's also throwing the smog pump cel. i've never heard of anyone making a work around the pump.
A friend's giving me his kit that he ended up not using from Vapauto.com.
My smog pump is bad as WLJohnson05 said, and I need to replace it soon to pass smog. I just need to know if its possible to relocate the smog pump to accommodate the Windstar or somehow remove the smog pump alltogether and still pass smog tests. |
#6 | |
2003 V6 Mustang
14.2 @ 96
My understanding is that the smog pump provides extra air into the exhaust for the first few minutes after startup to reduce emissions until the converters heat up. It should have no effect on emissions after the engine is warmed up. However, if it is setting a code
that could keep you from passing or they could fail you from the visual inspection if it is missing. I would think a non stock intake would cause you to fail as well, though they do allow some modifications that have been shown to not affect emissions. |
Threads Similar to: Windstar Intake + Smog pump?
| windstar intake | mannymustang | V6 Mustangs | 9 | April 29th, 2008 03:29 AM |
| Windstar Intake | 2000Mustang | V6 Mustangs | 18 | August 4th, 2007 11:41 PM |
| Windstar intake? | Orangester | V6 Mustangs | 1 | March 30th, 2007 12:07 AM |
