Question about shifting and hearing a squeaking noise.. - Page 2
Old October 5th, 2009, 11:07 PM   #21
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
if your 97k on OE struts your due to change them, go ahead and do that. the pulling is probably a toe issue, get an alignment. AS for the squeak its hard to tell you much without hearing it, try a sound clip for us if possible.
As for the ball joint with no play in them i wouldnt replace them get a grease gun and lube them up. I cant remember if the 2000 mustang has fitting or not but if so just pop the gun on that.
that would probably only make a sound on ruff terrain though if yours is constant id rule that out. A sound clip would really help though
NCMM #9
Old October 6th, 2009, 12:33 PM   #22
MM's Official Lucifer
goren813's Avatar
'00 3.8L
^ The 2000 DOES have a grease fitting. Try refilling it, but if the boot is worn/cracked/missing you'll need new ones. Replacement isn't hard so long as you rent the removal tool from an auto store.
Old October 6th, 2009, 01:34 PM   #23
00mustangv6's Avatar
2000 Mustang v6
00mustangv6 is an unknown quantity at this point
Well these mechanics think its the brakes. They said the rotors are heated really bad and the pads are cracked. Would that cause the squeak when accelerating?
Old October 6th, 2009, 04:12 PM   #24
goren813's Avatar
'00 3.8L
Rotors may yeah if they're warped/grooved (I guess they call that "heated"). Get those and the pads replaced and see what's up.
Threads Similar to: Question about shifting and hearing a squeaking noise..
what is this noise i am hearing? 06tungstengt 2005 - 2010 16 May 15th, 2009 07:20 AM
squeaking noise? Chris951 5.0 Mustangs 14 December 14th, 2008 02:35 PM
Squeaking noise when starting, help?!?!? Mike Johnson V6 Mustangs 1 June 16th, 2008 12:02 AM
squeaking noise Fastback91 96-98 4 February 6th, 2008 11:08 AM
squeaking noise dark-samurai2 V6 Mustangs 10 October 8th, 2007 12:24 PM
