Sterring rack bushings - Page 2
Old October 8th, 2009, 09:21 PM   #21
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
Zatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud of
iTrader: 12 reviews
Ohhh Lol... I got ya. I guess I was just out of it when I read that post.
Old October 9th, 2009, 02:01 PM   #22
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
They hold the rack in place and over time deteriourate.
When this happens and you turn your wheels the rack will shift and cause a pop or clunk noise.
You need to remove the nut and the through bolt to get the bushings out. The two bolts that I pointed out before are the correct ones.
If the bushings look large it's probably because they are uncompressed.
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Old October 9th, 2009, 04:59 PM   #23
MM's Official Lucifer
goren813's Avatar
'00 3.8L
I've been adding confusion to all of this, since I was confused myself. I was taking the bushings y'all are talking about as something else, like when you're leaking power steering fluid out of the thing, that's why i suggested just replacing the whole thing. In this instance replacing only the bushings is the way to go.
Old October 9th, 2009, 05:06 PM   #24
2004 V6 & 2000 GT
It's all good.
What you were referring to would be considered seals as far as I know. Unless you meant the bellows boots.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old October 11th, 2009, 09:59 PM   #25
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 12 reviews
Well, hopefully the new brushings will be in sometime this year Lol. Ordered on the 6th and they prolly will not be here till the 13th since Monday is a holiday.
Old October 13th, 2009, 02:38 AM   #26
sircrashalot is on a distinguished road
use a torch to remove the old ones
Old October 13th, 2009, 08:38 PM   #27
2004 V6 & 2000 GT
I hope you're not serious.
There is no need to use a torch. Its just 2 nuts, 2 through bolts and 4 pieces of rubber.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old October 13th, 2009, 09:06 PM   #28
2002 Mustang GT Vert
Xtremist is on a distinguished road
I have this same popping sound when I steer. I was told by a few people that it was probably the steering rack bushings.
Let us know if this fixes the problem. I'm looking at doing this fix myself if it will fix that popping sound.
Old October 14th, 2009, 02:23 AM   #29
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 12 reviews
They just came in today. Gonna try and install tomorrow. I got the Offset ones since my car is lowered, and the hole in the bushing is not center, but off center. I suppose this is the "offset".
Old October 14th, 2009, 02:36 AM   #30
00BlueMustang's Avatar
2000 Mustang
00BlueMustang is a jewel in the rough00BlueMustang is a jewel in the rough00BlueMustang is a jewel in the rough
Yeah that seems right
Detailing Crew Member
North Carolina Modded Mustangs #5
Old October 15th, 2009, 02:44 AM   #31
2004 V6 & 2000 GT
Yep. That will raise or lower the rack depending on how you put the offset.
The offset is to help re-align some of the steering geometry that was changed when you lowered your car. It won't be perfect but it should help a little.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old October 15th, 2009, 02:50 AM   #32
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 12 reviews
Should the holes in the brushings be near the bottom or top of the rack? It depends on which way I turn them when I install them... im guessing the holes need to be near the bottom so the bolt, and thus the rack, are forced upward?
I can take some pics of the brushing if needed. Gonna try to get this done this weekend.
Old October 15th, 2009, 02:54 AM   #33
2004 V6 & 2000 GT
That would be my best guess. It should move it up about an inch.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old October 15th, 2009, 02:57 AM   #34
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 12 reviews
well... wouldnt you want it to move down acually since the suspension has gone down and you are trying to align it again?
The rack is still straight in the right spot... but the ends (where the tires/springs/shocks are) have gone down... so the rack needs to come down... right?
Old October 15th, 2009, 03:00 AM   #35
2004 V6 & 2000 GT
No you want to move the rack up because the body of the car has gone down and the control arms, knuckles and all the other stuff has gone up.
If you move it down you're going farther away from where you need to be.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old October 15th, 2009, 03:12 AM   #36
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 12 reviews
Gotcha
Old October 21st, 2009, 06:37 PM   #37
Any updates?
Did it fix the popping sound?
Threads Similar to: Sterring rack bushings
Offset steering rack bushings... smokeshow 99-04 9 May 4th, 2010 03:25 PM
Steering rack bushings njstang 99-04 1 May 2nd, 2009 02:55 PM
need new steering rack bushings.. droppedbass87 96-98 1 August 4th, 2007 09:32 PM
Help..rack bushings Flomaster_Knockoff 5.0 Mustangs 2 May 20th, 2007 03:41 AM
offset steering rack bushings AFtriathlete General Tech 2 May 10th, 2007 11:53 PM
