Discussing automatic shifting and reving ? in the V6 Mustangs Forum. it won't stall. You won't accelerate any more but all your shifts even ...
Old February 13th, 2007, 04:55 PM   #21
Resident MM Ricer
GreenFaleen's Avatar
2006 Scion tC
13.9@103/8.9@81
it won't stall. You won't accelerate any more but all your shifts even when your driving normally will be sharper, quicker, and more efficient.
Scion Tc-strup racing header, CAI, Ground Kit, NOS 100shot, Custom suspension, Doc. I 50% STS
Thanks To My Sponsors:
Strup Performance
Old February 13th, 2007, 05:10 PM   #22
MM Ninja / Site Moderator
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
i want my shifts to be so firm u cant have opened drinks in my car lol ill need a tune for that as well im thinking.
Modded Autos Join today, All makes all models
Originally Posted by drgnracin72 View Post
fat girls dont expect dick, they apreciate it...
Old February 13th, 2007, 05:31 PM   #23
don't get the torque converter you don't need it it just helps. you can get the improvement kit and the shifter for 265 installed for about 50
and your rev limiter should be 6 unless you had it changed 4 is the neutral rev limiter.
How hard is it to install do you think I can do it my self with out lifting the car or any thing ?
2000 3.8l mustang v6 automatic - Stock.
Old February 13th, 2007, 05:43 PM   #24
Juggalo_X's Avatar
14+@Slow
hell no man u got to pull the valve body in the tranny YOU NEED TO BE A PROFESSIONAL for the install or your car she wont move from where u started ripping her apart guaranteed. and the car will have to be lifted to get to the tranny pan and remove the valve body.
Old February 13th, 2007, 06:08 PM   #25
Moderator
Cricket's Avatar
8.876@80.013 1/8th
Since it's an auto you can't stall out...well if its a properly maintained auto you can't.
You can always rev while coasting when your moving put your car in neutral
Originally Posted by 232stang
...and then cricket put in his $0.03 because hes above $0.02
Blue Mustang Society Member #001
click it
Old February 13th, 2007, 06:18 PM   #26
Do I have to push the button in and move it to neutral or do I just slid it up?
Also tommorrow I'm going to manualy shift using the two gears I have one question when I come to a near stop and I'm in second gear since I can't shift down what do I do ? Can I remain driving in 2nd gear or would that be very slow?
Old February 13th, 2007, 07:02 PM   #27
Juggalo_X's Avatar
14+@Slow
iuf your in the 2nd position it will down shift to first for you just wont go over 2nd till i move the shifter to D
Old February 13th, 2007, 07:22 PM   #28
Moderator
Cricket's Avatar
8.876@80.013 1/8th
To go down you have to push the button. To get out of D no matter what you have to push the button. You can shift down to 1st when comming to a stop. It really isn't necessary. This is the exact reason why I'm gonna finish up my exhaust, and do what I can to either get a brand new v6 or get a used GT. I'm tired of the auto, and want a 5 speed.
click it
Old February 13th, 2007, 08:18 PM   #29
Ok so when I'm in first and get to 4krpm I just pull it to second then if i need to slow down it will do igo to first again for me? and this will not break any thing right ? I just want to see how it drives using top gear as 2nd.
Old February 13th, 2007, 08:19 PM   #30
Juggalo_X's Avatar
14+@Slow
ur going to hit ur tach limit driving in 2nd i think and yes if your stick is in the 2nd position if you come to a stop it will down shift to 1st all the 2nd position does is stop it from shifting past 2nd
Old February 13th, 2007, 08:35 PM   #31
what's the tach limit ? and what is the real pupose on having the ability to use only 1 or 1st and 2nd gear ?
Old February 13th, 2007, 08:38 PM   #32
Juggalo_X's Avatar
14+@Slow
keeps the car in a gear that has more torque for towing and getting out of mus or snow and the tach limiter stops you from exceeding the maximum rpm of the engine so you don't damage it.
Old February 14th, 2007, 12:18 AM   #33
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
yeah only down shift with a stock setup if your stopped if you need to slow down or keep going just put it in drive. And 1 and 2 are used for keeping low speeds when in snow or a steep incline when towing
Strup Performance
Old February 15th, 2007, 08:21 PM   #34
Victoria's Avatar
So after reading this thread I tried shifting in my car today, which is an auto. I started in first, went to second, then third, then drive. I must say, it didn't seem much different than having the car in drive. I could tell that the RPMs could be manipulated more, but when I went a gear higher each time it took about a second and a half for the switch to kick in unlike a manual transmission. Because of this, I had to change gears before I hit the 3,000 RPM mark, which I was aiming for.
Old February 15th, 2007, 09:11 PM   #35
Juggalo_X's Avatar
14+@Slow
that delay is because its an auto the torque converter has to sync between gears if you get a shift kit it will help along with a nice after market shifter
Old February 15th, 2007, 09:38 PM   #36
Victoria's Avatar
Interesting. Without the shift kit I think manually shifting an automatic is pretty useless. I probably won't do it again unless I need to for some unknown and unlikely reason.
Old February 15th, 2007, 09:46 PM   #37
yea. greenfaleen answer my questions and gave me great links which = great info. just PM him, hes got the answers
Threads Similar to: automatic shifting and reving ?
engine reved up and kept reving ronneone 5.0 Mustangs 10 December 23rd, 2007 12:05 PM
5.0 Over reving on startup cptkng79 5.0 Mustangs 1 June 21st, 2007 08:59 PM
Will a tuner improve shifting in my automatic? jrfan4life 99-04 3 March 31st, 2007 07:32 PM
slapstick shifting on an automatic bryanrocks907 V6 Mustangs 9 October 20th, 2006 10:39 AM
automatic tranny shifting too late? 2007gt Drivetrain 1 August 24th, 2006 03:46 AM
