V6 Cam install question
ne1 knows how hard a Cam install would be ? or has done one with a 3.8 V6......Im doing a 8.8 rear swap hopefully this week....with some UPR upper and lower control arms.....the car is also being dropped 2inches.....after that I wanna go into the internals.....I want at least 300rwhp on motor or close to it...then it'll probably be sprayed from their
just a V6 with a bad belt slip under the hood |
Zoolander
04 Cobra #2260/3768 1/820
Depends on if your swapping the valve springs out at the same time. This isn't something that I have done, but it is easier to do this if your not swapping the valve springs out at the same time.
yeah but to my understanding it will help with a mild cam...so I know it gets more complicated....I saw a thread where i guy does a V6 cam with the engine still in the car....just took a lot of shit off it....just wanted to know how long it took and the gain they got from it
Zoolander
well he also replaced the valve springs to heavier ones, and that took him 15+ hours aside from where he lost one of the parts and had to wait a day to get a replacement for it.
#5 | |
get a haynes manual....
#6 | |
Re: V6 Cam install question
Zoolander
You don't have to break the block down that much. You can put cylinder one to TDC, remove the timing chain, slide the cam out, and put the new one in. It's a little more indepth than that, but you can do it that way.
Threads Similar to: V6 Cam install question
| T5 install question | wolverine8490 | 94-95 | 1 | July 27th, 2007 11:55 AM |
| X pipe install question HELP PLZ | Blue98GT | Modular Mustangs | 7 | June 5th, 2007 07:18 PM |
| h-pipe install question... | James | 99-04 | 2 | February 22nd, 2007 02:56 PM |
| Pro-M Install Question | BadnBlack93 | 94-95 | 5 | December 15th, 2006 02:22 AM |
| Steeda Tri Ax Install Question | o3gtdgs | 99-04 | 4 | November 15th, 2006 11:22 AM |
