#21 |
Moderator
you shouldnt have any problems.
![]() ![]() BUILD 2 IN PROGRESS |
#22 |
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
An easy way to check and see if you're over clocking the alt is to turn on every load your car has.
Both amps, stereo, head lamps, flashers, a/c, wipers full speed, rear deffroster, and interior lights. Then take a voltmeter and measure the voltage at the battery with the car running. You should see 14-14.3 If you see below 13.5 you might need to upgrade your alt. |
#23 | |
Moderator
but you dont necessarily need to have all your accessories on as it will still read 14-14.3 with them off.
#24 |
2004 V6 & 2000 GT
The reason I say turn them on is to make sure that it can handle everything that he may need.
#25 |
2004 V6 Coupe
Just wanted to let you guys know... I switched the RCA's to the other side of the car and the noise is gone
#26 |
Moderator
good to hear, its always something simple.
#27 |
2004 V6 Coupe
yea I agree, its always something small and stupid that you cannot find... Thanks for the help
Threads Similar to: Odd Noise From Engine Bay
| Engine bay noise | 1989Gt. | 5.0 Mustangs | 0 | June 26th, 2009 02:02 AM |
| Odd Noise... Part 2 | 04stang123456789 | V6 Mustangs | 15 | April 22nd, 2009 11:54 PM |
| Odd Noise | 04stang123456789 | V6 Mustangs | 18 | March 7th, 2009 05:59 PM |
| Odd little noise | zinc02GT | 99-04 | 11 | October 17th, 2008 09:19 PM |
| Odd clutch noise | StangAddiction | 99-04 | 5 | July 27th, 2008 02:55 PM |
