2 Problems
Old October 15th, 2009, 08:56 PM   #1
Dancing Naked In The Rain
mcqueen's Avatar
2 Problems
1. I just changed the air filter (old one was filthy as hell) and now my car occasionally idles high. It normally idles right around 700-800 rpm but some times it will idle at 2000 rpm now. I've got the stock air intake (minus the snokle thing).
2. My front wheels rub the insides of the wheel well when I turn the steering wheel as far as it goes. The rims look stock so I'm not sure if this happens in all Mustangs or not.
Old October 15th, 2009, 10:46 PM   #2
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
hmm the the car probably idlles high becuase the computers learn the strategies, and it is probably used to your old filter, or you may have a dirty maf sensor. And as far as the front wheels go, from your pic it does not look like stock wheels, that may be the problem, you could take a closer pic of your wheels.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old October 15th, 2009, 11:12 PM   #3
2004 V6 Coupe
04stang123456789 is on a distinguished road
yes, it does not appear that you have stock wheels as codeman said... Look at your tire size and post what the numbers say on it... it will have three numbers and a letter sch as 225 55 R16... Look to se what the first number is, because stock tires should not be rubbing
Old October 15th, 2009, 11:34 PM   #4
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
Zatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud of
iTrader: 15 reviews
Is the car lowered? I have 17" rims (not stock) with 275s on the front and they come very close to rubbing on the front.
So technically you should not rub unless your are lowered with 18" rims and a very larger tire (such as a 275).
Black Bullitt Rims FT/FS
Looking to Sell or Trade for Silver FR500s
Looking to buy a lot of 99-04 Interior Pieces
If you have any for sale, PM me
Old October 15th, 2009, 11:39 PM   #5
sircrashalot is on a distinguished road
sound like u could of mess your MAF sensor...
Old October 15th, 2009, 11:41 PM   #6
, tire's to big
rims to big
lower to much....
dude u get new struts and cc plate?
if u lower it any more then 1.5" u will run into issue's
Old October 15th, 2009, 11:42 PM   #7
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
Originally Posted by 6er_w/a_Vengance View Post
they look like stock gt wheels...which mean 245/45/17...might be time for a new suspension to fix any rubbing...or is it a solid bald section from alignment your confusing with rubbing....
as for the idle....clean your MAF...
He says its when he turns the wheel as far as it will go, it rubs... so I bet he means the tires is hitting something.
Old October 16th, 2009, 12:38 AM   #8
mcqueen's Avatar
Alright I'll clean the MAF when the weather clears up and tomorrow I'll get some good pics of the rims (fair warning, they're dirty) and check out what size the tires are. I would have gotten pics tonight but it's raining some asshole stole my usual parking spot so my car is sitting in the dark
Old October 16th, 2009, 12:45 AM   #9
ItaliStang's Avatar
01 V6 convertible
too slow to try
ItaliStang is just really niceItaliStang is just really niceItaliStang is just really niceItaliStang is just really nice
it may not actually be rubbing... I know if mine turn all the way they make a noise that sounds like it's rubbing, and that was with stock 16" wheels...
put the front end up on jacks, have someone turn the wheel the whole way, and check it to see if it is...
Eagle Scouts or GTFO!
#8 in MM's coolest members
Originally Posted by 93hatch View Post
I voted for 93Snatch, because I don't even know what the fuck that thing on his avie is. Is it a Thunder Chicken?
its fucking zapdos show some goddam respect!!!!!
Old October 16th, 2009, 12:52 AM   #10
mattf0509's Avatar
2000 3.8L v6
when i finished track was closed
mattf0509 is on a distinguished road
is it a grinding noise? my car makes a slight noise when i turn the wheel all the way but its the power steering whine
Old October 16th, 2009, 12:54 AM   #11
mcqueen's Avatar
There's a little bit of a grinding noise but the vehicle gets jerky too
Old October 16th, 2009, 01:20 AM   #12
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
More than likely it's just pump noise. Mine does it too and I have stock rims.
As for the high idle do not clean your MAF. Unhook the battery for 10 minutes or just keep driving the way it is. You'll reset the KAM either way.
The MAF has a protective coating of oil to keep it from getting dirt inside of it. When you clean it, it removes that layer and makes it more prone to failure.
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Old October 16th, 2009, 02:09 AM   #13
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
So, do you have a spot on the tires or in the wheel wells that leads you to think its rubbing? Or is it just the sound and/or the jerkyness?
The sound is the power steering pump. When you turn the wheel to it's limits the pumps make a whine noise.
The jerkyness would constitute more investigation. Have any suspension mods been done?
Old October 16th, 2009, 09:28 AM   #14
mcqueen's Avatar
I haven't personally made any mods to the car besides a new set of headlights and a new exhaust system (not headers though). I think when I have some time today I'll look the car over really well because it seems the previous owner may have tried to do a few things himself and he was far from handy with cars. I'll take a look for a possible spot where it would be rubbing when I look the car over later.
Old October 16th, 2009, 10:21 AM   #15
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
You should be able to tell quickly if it is lowered or not... here is a comparison for you:
Not Lowered - Stock (rims are not stock)
Lowered - Non Stock (rims are not stock)
Just look at the wheel wells... if you can fit your whole hand between the tire and the fender then more than likely it is NOT lowered. Also look under the car at the springs and shocks/struts. If either or is a different color (blue, yellow, red, ect) then it is most likely lowered. HOWEVER... some lowering springs are black like the OEM ones... so even tho it may look like black oem springs, they might not be.
Old October 16th, 2009, 03:12 PM   #16
mcqueen's Avatar
Alright I just got done with my little inspection. The car hasn't been lowered. The springs look to be OEM. I didn't really notice any spot where the tire would be rubbing so I'm going to go with the conclusion that it's the power steering pump. The tires are 235/35/17. I also got you guys a pic
Old October 17th, 2009, 12:01 AM   #17
2000 Mustang v6
winnie51189 will become famous soon enoughwinnie51189 will become famous soon enough
Send a message via AIM to winnie51189
Those are definitely not stock rims, but they don't look bad either just needs to be lowered so the wheels don't look so small.
Old October 17th, 2009, 12:27 AM   #18
mcqueen's Avatar
Eh, I'm gonna have to wait until I move to lower it. The curb leaving the parking lot from my current apartment building if huge. I worry about fucking something up already lol.
And I looked closer earlier and I found a spot that might be rubbing after all. I'll get a pic in the morning.
Old October 17th, 2009, 01:45 AM   #19
2000 Mustang v6
Originally Posted by sircrashalot View Post
, tire's to big
rims to big
lower to much....
WTF??? Is there even 1 sentence in there that is actually complete and uses any English grammar?
Threads Similar to: 2 Problems
A/c Problems roquecampos 96-98 7 August 19th, 2010 07:11 AM
Need help with problems.... unlicensed to drive The Clubhouse 56 June 14th, 2009 09:24 AM
95 v6 problems KevinJ99GT V6 Mustangs 2 September 16th, 2008 12:21 PM
95 v6 problems KevinJ99GT V6 Mustangs 7 September 10th, 2008 12:45 AM
T-5 Problems 351stang 5.0 Mustangs 6 November 22nd, 2007 04:12 PM
