Car fails to accelerate
Old October 15th, 2009, 09:39 PM   #1
20Mustang02 is on a distinguished road
I have a '02 Mustang V6 recently I've noticed whenever I try to accelerate (esp. uphill or slight slope) the car fails to accelerate and sometimes it even slows down to less than 25mph even while pressing the pedal... The only time I can really make it go is if I hold the pedal down and even then it struggles to go past 2000rpm
Today while driving it jerked a bit and then slowed down...I heard sort of a air tapping sound and pulled over there was grayish white smoke coming for the exhaust
The check engine light has now come on and it throws the code about the EGR Valve is getting too much flow..
Any suggestions on what the problem could be?
Old October 15th, 2009, 10:10 PM   #2
sand1303 is on a distinguished road
catylitic converter clog? just a guess. don't know anything about the egr but if you have a code what is it. give the actual code
Old October 15th, 2009, 10:19 PM   #3
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
smoke makes me want to say head gasket. but that would be more blueish and all the time
code is probably bad rear o2 sensors, and the accel problem id blame of the cat so get new cats new rear o2(probably killed by the cats dumping fuel on them) and you should be ok,
NCMM #9
Old October 15th, 2009, 10:36 PM   #4
The exact codes are p401 & p402
Old October 15th, 2009, 11:44 PM   #5
sircrashalot is on a distinguished road
sound like you have a blown head gasket.... white smoke is coolant burning. in cylinder.
Old October 15th, 2009, 11:45 PM   #6
blue smoke would be piston rings going bad.
Old October 16th, 2009, 01:28 AM   #7
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
Not to sound like a dick but you are all heading in the wrong direction.
Your EGR valve is stuck open or staying open.
On the front of your engine not far from the EGR is a black canister with a vacuum line going to the top of the EGR. Unhook the vacuum line from that and see if the problem goes away. If it does replace that actuator. I can't remember the exact name. If that doesn't solve your issue pull a vacuum on the EGR to make sure that it opens and closes.
If the EGR is good and the actuator is ok, replace the DPFE. 98% of the time it's the DPFE.
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Threads Similar to: Car fails to accelerate
DIY fails. Imran The Clubhouse 15 April 2nd, 2009 03:22 AM
Burning Smell Only When I Accelerate Hard crossfire876 99-04 7 March 9th, 2009 09:43 PM
heater causes my car to accelerate byits self... 00gtv8 99-04 7 January 11th, 2009 03:43 PM
never f^%ing fails joejoe8455 The Clubhouse 22 April 28th, 2008 01:44 AM
does A/C really make you accelerate slower? nba1341 The Clubhouse 37 July 17th, 2007 10:12 PM
