4.2 issues
Old October 15th, 2009, 10:42 PM   #1
SleeperStang88's Avatar
2000 Mustang V6
need to run at track
SleeperStang88 is on a distinguished road
4.2 issues
well i have the 4.2 in and now im having issues when WOT it will not shift.....i have an automatic and it seems at 4-5 grand it seems to bounce likes it hitting the rev limiter and will not shift unless i let off the gas
now i deleted the egr....and my mechanic tells me that the egr has vacuum lines that control the up and down shifting ....any ideas?
_____________________________________________
4.2 H/C/I with LT headers, sitting on 315s
Old October 15th, 2009, 11:42 PM   #2
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
hmm... idk if the egr has any lines that connect into the automatic transmission. Umm did you put the motor in? if so you may have not connected all of the vacuum lines to the tranny. does it shift regularly?
UDP, CAI, True Duals, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, FRPP C Springs, and J&M Full Length Subframe Connectors
Great Automotive How To's http://tooldesk.com/blog/
Old October 16th, 2009, 02:34 AM   #3
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
Trans shift point are electronically controlled as far as I know.
The EGR wouldn't have anything to do with this. Double check that all your connectors are attached. More than likely it's a wiring problem.
Did you change anything in the trans?
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Old October 17th, 2009, 11:43 AM   #4
2000 Mustang V6
i did not put it in myself, i had my mechanic do it, but it does shift normally when i drive it normal.....just wot is when it will not shift
Old October 17th, 2009, 06:21 PM   #5
2004 V6 & 2000 GT
Check out the TPS. Make sure that it is seeing the correct voltage at WOT.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old October 19th, 2009, 10:22 PM   #6
slvr2000stang's Avatar
2000 Mustang
14.10@96.75
slvr2000stang is on a distinguished road
No it does not.
And a mechanic saying something so far off like that would scare me.
2000 V6 vert
2003 Lightning
Threads Similar to: 4.2 issues
issues with 97 gt racer1997 96-98 13 June 10th, 2009 04:44 AM
serious issues mpboy 99-04 21 March 25th, 2009 07:41 PM
AC Issues... 02MustangV6e9 V6 Mustangs 4 February 23rd, 2009 08:37 PM
still having issues... mustangsoldier 5.0 Mustangs 32 February 16th, 2009 07:11 PM
Issues... mustang1072 V6 Mustangs 20 December 18th, 2007 02:09 PM
