rattling after startup
Every time i crank my car up, theres a bad rattling noise that comes from my engine, but it only lasts for 5 seconds then goes away. any ideas on what it is?
oil pump maybe
Sex, Eating, and Driving Fast, the Three Greats in life and I can do all of them without leaving my MGM |
Mine has a light rattle when I accelerate sometimes. It hasn't always done it, and it's not very noticeable, but I can definitely hear it coming from the engine from time to time. Then there are days when my dash seems to be loose, and other days where it's just fine. So who knows.
#4 | |
remember the problems already circled
I think it could be ur throw out bearing my buddy had an s-10 that did that and we he got it fixed i asked him what it was and said it was the throw out bearing it was bad
#6 | |
Re: rattling after startup
Ok. When you start it up and it rattles, is it more like a scratching (could almost sound like rattling), and it ONLY does it when you crank the car, than it is your starter. The teeth wore down too much to crank it properly. Replace your starter, i guarantee you it will go away. |
#7 | |
ok how much u guys think it'll cost for either the ball bearing replace or the starter replace
can also be the oil pump, the pump could have a few nuts not tourqed enough or you could just need an oil change with a thicker oil grade
man this sucks
#11 | |
#12 | |
sounded like the rattle was coming from the intake. It only did it for like 5 seconds. Sometimes it didnt do it for some reason. But when I replaced the starter, it was fine. its easy to do also. 2 bolts, no shims. about 10 minutes of work. |
not if it just has lost some power over time and runs ruff for the first couple of seconds getting the oil flowing, a good indicator of this bieng the problem would be the oil pressure being low
#14 | |
True. But his car is only 12 years old. they are made to last longer than that. It could be. You have a valid point, but I had the same problem, and it was the starter. Thats why I say that. Whats your oil pressure running at death? |
no clue at this moment, can check that tomorrow
the problem with it being the starter is that on all the cars i've seen with bad starters it took forever for the engine to start.
#17 | |
Ok, the lower right guage on your speedo, do you know if the needle is in the middle or more on the left side? |
#18 | |
its leaning towards the right side
#20 | |
Threads Similar to: rattling after startup
| Startup...ECU Keeps Resetting | OcOnnor220 | 99-04 | 3 | November 10th, 2007 12:26 PM |
| Squeals on startup | sasafrass12 | 5.0 Mustangs | 27 | September 6th, 2007 08:02 PM |
| squeal at startup | sasafrass12 | 94-95 | 2 | August 18th, 2007 06:14 PM |
| 5.0 Over reving on startup | cptkng79 | 5.0 Mustangs | 1 | June 21st, 2007 08:59 PM |
| Startup Trouble | DeathScythe95 | V6 Mustangs | 13 | April 7th, 2007 07:19 PM |
