#41 | |
SORRY IF YOUR EXTREMELY CLOSE MINDED go crawl in the same hole where people said v6s would never run 10s lol if you had a v6 spin to 7500rpms 300hp would be a laugh in the past i was talking 6500-6800rpms your forgetting SSOOO much i doubt that honda head first and for most flows 500+cfm! thats smoking big block heads second our motor is MUCH bigger and makes much more torque and the bore size and piston size isnt even comparable! stop with your silly excuses. plus you think that hondas "500+cfm" heads are benifiting that car all motor! lmao the video is AN IDEA. AN EXAMPLE. you say its a bad one, I say you have a bad reason and poor range of options. you'll stay under the safe category where trying something new isnt your thing go with the proven already done 50times setup and never stand out. lastly...ive said sooo many times already NO ONE is making 300whp n/a v6...but what would you prove with that?! how many people even attempt it? that still doesnt prove the fact OF HOW EASY! I could do it with out ANY sheet metal custom fabrication. a plastic little intake manifold off a mini van. a 4.3L stroker, the heads and cam and the right rear and tranny. DO YOU know the difference between a the loss in a t5 and a C4 tranny.... DO YOU know the gains between 87-93 octane and 118+ octane rated fuel? making some dyno read 300hp is pointless. I might be able to easily build a 300hp v6 doesnt mean it'll run mid 11 or 11.80s. OPEN YOUR MIND PEOPLE. 300hp n/a is not a mythalogical story that'll never be real. Its so possible and doable its upsetting
#42 |
So why are you posting then?
![]() 8000rpm turning V6 mustang
#43 |
2000 Mustang
14.10@96.75
so do it.
2000 V6 vert 2003 Lightning |
#44 |
lol and be a slow as you! ![]() no thanks if i did i know my rings would at least be filed in under a month ![]() oh then id pose and insert un-oil parts for pictures cause its cool. then diss a company that I watched build a motor then later point out all the obvious flaws and pretend like i know stuff about these cars but cant tell the difference between a gasket match and a uniform as hell ports. but he we cant ALL have your knowledge right Kirk?! Mr. Clean hands no brains. 1 more thing, you cant race me if my daily runs faster then what your cars ever done and its bone stock..... Keep up your great builds! because 240whp and still in the 14s is well proven on your side. plus you make alllll the right choices...what $7-9K on a motor that looked like crap and built by crap performance. Tell me more Kirk cause if i listen to you clearly I'll make the right choices as your past as proven. Btw i do talk this much shit in person if the person is truly a RICER as you. see you in 5months
[SIGPIC][/SIGPIC] Acmillr loves me Last edited by itschristorres8; October 24th, 2009 at 08:56 PM. |
#45 |
MM's Database Error
lets stay on topic people. remember there is a difference between good arguements and bashing people.
#46 | |
2000 Mustang
14.10@96.75
But obviously you have to take the low road all the time. Good luck and see you on the other side.
#47 |
Priest of the Car Gods
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
#48 | |
2003 mustang
7.48x1.56=11.67
I feel if we had half the aftermarket support as the old buick gn's no one would waste their money on a v8 mustang. Only if we had a turbo from the factory then we would catch the aftermarket attention. Hell...we even have to make custom turbo headers. And thanks to a very few v6 supporters we can buy a stroker kit for this car. I just hope the 3.8/4.2 dont disapear like the 2.3 has done over the years. But it looks to be heading that way
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
#49 | |||
A 5.0 with a "normal" H/C/I swap makes around 300 at the crank, so I find it interesting that you get the same results with the same architecture but 3/4ths the displacement. I would think that you'd be making more like 230 at the crank after such a swap, maybe 250 with good heads. Other than that, I think you've hit the nail on the head; because of the availability of, and large aftermarket for, the V8, it's assumed that anyone who's interested in performance will go that route. Those that do chase performance usually have the V6 because they couldn't afford the V8, and likewise can't afford aftermarket parts for the sixxer anyway. I also don't expect them to stick around. If the rumors of the 3.7L V6 are true, I expect 3.8 parts to start getting scarce.
#50 |
ya well lets hope the parts do not get scarce. And as far as the hp numbers go. The numbers are there for the possibility of getting to 300 rwhp. If the v6 mustang that ran 10 sec with nos and 11 someting without got 265 to the wheels with the c4 and an 8.8. I think that with the t5 and the 7.5 and some better ported heads and some experimenting that it may be possible. just the change from the c4 and 8.8 will change the numbers quite a bit. i don't want to start an arguement. Everyone is entitled to their own opinions, it is just kind of a goal of mine. And I will hopefully accomplish it and then can prove that it can be done. I guess only time will tell.
![]() UDP, CAI, True Duals, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, FRPP C Springs, and J&M Full Length Subframe Connectors Great Automotive How To's http://tooldesk.com/blog/ |
#51 | |
2000 Mustang
14.10@96.75
#52 |
well i am not looking for the time that he got, I am looking for the rwhp. And he had 278 rwhp with the c4 and 8.8 with out the nitrous. I think that it is reasonable. I hope that I can get the 300 rwhp mark. I got all the goodies for my rearend coming on the way, and 3.73 gears, and im looking at getting a windstar upper at christmas.
#53 |
I've said before, pay attention
secondly just shut up. YOU DONT KNOW what you're talking about at all. IF YOU have no knowledge its better you just stay quiet and not get noticed for your ignorant, close minded statments
#54 |
Why dont I built it? Why dont you give me the money and I'll do it. I'm sure you have another $9k to hand out
#55 | ||
2000 Mustang
14.10@96.75
Welcome back.
#56 | |
![]() On a more serious note, what *exactly* have I said that's ignorant and close minded? It seems to me that you're so convinced that I'm attacking your favorite motor that you just go all rabid defending it rather correcting anything I've said that's wrong.
#57 |
[8MINUS2]
Highest N/A hp.. on v6p.net:
264.8/280 Stock 4.2L bottomend, Longtube headers, RPM Gen1 BV Heads, 207/215 camshaft, Stage 1 Lower and Modified Upper intake, MAC CAI, Dual Magnaflows w/ X-pipe, UD Pulley, 70mm TB So, with the right upper, cnc heads, some compression, maybe a custom set of long tubes, better parts to spin it up to 7k, cnc lower without the egr bungs at all, more well matched cam. You could prob pick up that 36rwhp.
#58 |
just buy a motor from SSM (if u got the money
)http://www.supersixmotorsports.com/p...Shotblocks.pdf "these engines can be tuned to produce 280-390 horsepower naturally aspirated" but i think they mean like 280-390 hp to the crank hummm...
![]() 1995 Turbo V6 Mustang (auto) Check out my build <---- ET: 14.1@99mph (coupler blowing off/MBC failing ) Built by Iron Horse Motorsports |
#59 | |
[8MINUS2]
Why do that, when I can build one for half the price?
#60 |
well for people that dont want to go threw the hassle of putting anything together . For them to just buy is assembled
and that have the money
Threads Similar to: 300hp?
| 300hp v6 | Triple A | The Clubhouse | 25 | January 8th, 2009 11:07 PM |
| 300HP N/A | man_of_war2081 | 99-04 | 22 | July 28th, 2007 04:00 PM |
| 300hp | burlingtonNC98GT | 96-98 | 6 | May 21st, 2007 10:26 PM |
| 300hp | stang5.0 | 5.0 Mustangs | 5 | April 21st, 2007 09:08 PM |
| how to get 300hp | stang5.0 | 5.0 Mustangs | 3 | April 19th, 2007 01:00 AM |
