Discussing 02 V6, Service Engine Light, Error Code P0445 in the V6 Mustangs Forum. The light has been on for a while.. it used to be accompanied by the ...
Old February 15th, 2007, 03:25 PM   #1
whtpny's Avatar
The light has been on for a while.. it used to be accompanied by the check fuel cap light for a while but that stopped happening a while back.. i stopped by autozone a few days ago and they told me it was error code.. P0445.. i think.. well the guy told me the no problem associated with that code was the fuel cap.. so bought a new one and i can definitely tell that the vacuum seal with the new cap is much greater.. the guy told me the light should go off between 50 and 100 miles ive been nearly 200 since then and its still there.. any suggestions?
Mods: Fidanza Al Flywheel, Steeda UDP, EMP/Stewart Components WP, PP Plenum, K&N FIPK, Mac Prochamber, Pypes Violator Catback
WhtPny's Videos
Old February 15th, 2007, 03:27 PM   #2
maybe a full tune would help get everything workin right, and maybe it might be that it just isn't on all the way
Sex, Eating, and Driving Fast, the Three Greats in life and I can do all of them without leaving my MGM
Old February 15th, 2007, 03:32 PM   #3
MM Ninja / Site Moderator
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
Re: 02 V6, Service Engine Light, Error Code P0445
that is not a fuel cap issue
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
you have a problem with the circuit going to your purge control valve or the valve solenoid its self has failed or shorted. Inspect the wires to the purge control valve solenoid and make sure the insulation is not worn the wires are not in a stressed position and no wire fraying is happening if the wire looks ok replace the purge control valve and it should solve your issue.
Modded Autos Join today, All makes all models
Originally Posted by drgnracin72 View Post
fat girls dont expect dick, they apreciate it...
Old February 15th, 2007, 03:33 PM   #4
whtpny's Avatar
how much does a tune usually run lol.. can't afford much right now.. due to stuff ive having to pay for my ticket + my normal bills, lol.. should i go to a local shop or a ford dealership??
**edit.. ive checked the cap multiple times both new and old.. the new one is definitely on securely.. not so sure about the old one :-/
WhtPny's Videos
Old February 15th, 2007, 03:33 PM   #5
Juggalo_X's Avatar
14+@Slow
PS: the guys at autozone couldn't find there ass with both hands dont surprise me that they diagnosed the problem wrong even though this is a pretty standard OBD2 error code.
Old February 15th, 2007, 03:34 PM   #6
Juggalo_X's Avatar
14+@Slow
read what i posed first its related to a evap canister purge control valve issue
Old February 15th, 2007, 03:35 PM   #7
whtpny's Avatar
i suck with autos for the most part.. thats part of the reason i joined this forum .. lol.. but ill try to find someone that can explain or show me what to look at.. thanx for the help
WhtPny's Videos
Old February 15th, 2007, 03:36 PM   #8
whtpny's Avatar
just happened to think.. would this evap issue cause ne adverse effects on gas mileage or nething like that?
WhtPny's Videos
Old February 15th, 2007, 03:37 PM   #9
yah i was just kind of throwing some ideas out there, a full engine tune would help your overall proformance though
Old February 15th, 2007, 03:40 PM   #10
whtpny's Avatar
yeah im sure i could use a tune.... heres another question tacked on to the one in my last reply.. haha.. what would cause a problem like this to occur.. i dont remember ne error lights ever coming on in my car until shortly after i span out on a dirt road and flew across a ditch.. could i have hit something that caused this issue?
WhtPny's Videos
Old February 15th, 2007, 04:09 PM   #11
Juggalo_X's Avatar
14+@Slow
yes the purge canister traps and pushes any fuel vapors and such and put them into the intake manifold so they can be used a leaking or damaged evap system can have adverse effects on fuel millage
Old February 15th, 2007, 04:12 PM   #12
Juggalo_X's Avatar
14+@Slow
its possible you could have damaged part of your evap system it does have lines that run under the car. I believe purge valve is located under the hood on the firewall on the passenger side.... i have not had a chance to get a Haynes Manuel for my car yet...
Old February 15th, 2007, 04:33 PM   #13
whtpny's Avatar
alright, well thanx.. ill start with your first suggestion.. if everything looks good there i guess ill have a shop take a look at the entire system
WhtPny's Videos
Old February 15th, 2007, 04:52 PM   #14
could have been small rocks that damaged it, if you drive on dirt roads very often then i would recomend getting some of those custom molded mud flaps (they don't look like a truck mud flap, they look like the little ones right behind the wheels on subaru's, they don't look like it but they actualy will do alot)
Old February 15th, 2007, 05:00 PM   #15
where do ya get those flaps and how much
2000 Mustang V6
Old February 15th, 2007, 05:06 PM   #16
Resident MM Ricer
GreenFaleen's Avatar
2006 Scion tC
13.9@103/8.9@81
your rear o2 sensor valuve is stuck open go to a good mechanic and get a full diognostic to make sure thats the only one open about 200 dollars fix
Scion Tc-strup racing header, CAI, Ground Kit, NOS 100shot, Custom suspension, Doc. I 50% STS
Thanks To My Sponsors:
Strup Performance
Old February 15th, 2007, 05:11 PM   #17
try auto anything.com, they only cost like $20 but get the ones that are custom molded, not the ones that are like trucker flaps, they arn't really noticable when you just look at the car, but they will help protect the underbody and the paint from getting dirty fast or from rocks chiping up the rear bumper or rocker panels
Old February 15th, 2007, 05:38 PM   #18
Juggalo_X's Avatar
14+@Slow
weird i never knew an rear o2 sensor could throw this code i thought they didnt throw a code at all
Old February 15th, 2007, 05:41 PM   #19
Resident MM Ricer
2006 Scion tC
13.9@103/8.9@81
it will throw no code if it is malfunctioning (opening at weird intervals) but the doors for the gas fume recycle thingy ford has that is run by the rear o2 sensor like to get stuck open a lot it is annoying.
Strup Performance
Old February 15th, 2007, 05:43 PM   #20
Juggalo_X's Avatar
14+@Slow
the gas fume recycling thingy ur referring to must be the evaporative system lol i did no know that the rear o2 sensor controlled the evap canister purge control valve but it would make since if he spun out and damaged his rear o2 sensor wires that would cause a short out or a fault he is experiencing then. so bud if u come back check your rear o2 sensors and wires they may have been ripped off and causing a dead short to the exhaust system or the chassis and or may have a damaged o2 sensor.
