Rear End
i get a jerk when i let off in my car through higher gears not so much, dont think its the brakes just replaced those. Any ideas?
2000 Mustang V6 5spd. (deceased) 1988 Monte Carlo SS (cruiser) 1993 Mustang GT 5spd (bruiser) |
a jerk when you take your foot off of the gas? Does it do like 3 or 4 jerks and than stop? do you have a manual?
yea its a manual, no stops didnt stall it.
now when you let off the gas r u at full throttle
slipping clutch that grabbs when you let off the gas maybe?
Sex, Eating, and Driving Fast, the Three Greats in life and I can do all of them without leaving my MGM |
#6 | |
basic test to see if it is the clutch:
Park the car on FLAT ground. Put the car in first gear and hold the clutch in. Put your other foot on the brake (push it to the floor) Slowly (very slowly) release the clutch WITH your other foot still on the brake. Keep pulling the clutch out until it stalls out. If you can release the clutch between 1/2 and 3/4 of the way out, you need a new clutch. If it stalls before half way out, I would say your rear is busted and that jerk you feel is just really bad slap from the rear. |
yah i know, but with the gas on it would be slipping, but when he lef off the gas the wheels would be moving at relitively the same speed and the engine would be dropping in rpm's until the fly wheel and the clutch were moving at the same speed and would regain traction and jolt the engine becuase of the two momentums acting against each other in an inelastic colision, the bump would be because the engine would have to keep trying to maintain its deceleration while at the same time the transmition would be trying to maintain the same speed, this would cause the engine to stop decelerating and keep speed with the clutch, causing the jerk. it would be less noticable at higher speeds cause of the different gear ratio
#9 | |
It wouldnt cause a jerk though. there would be no power going to the transmission except at 800rpm. Thats the only time it would jerk. |
its not the trans im pretty sure it didnt do this until after i bent the axel shaft so i figured it was the rear.
Threads Similar to: Rear End
| 8.8' Rear end vs. 9" rear end | jhooper | Classic Mustangs | 22 | April 25th, 2011 04:59 PM |
| Rear End | D-Brow | V6 Mustangs | 16 | April 18th, 2007 12:54 AM |
| rear end | Mustang RacR94 | V6 Mustangs | 18 | April 9th, 2007 11:58 AM |
| What rear end? | ken5_0 | 5.0 Mustangs | 13 | March 20th, 2007 02:01 AM |
| Rear Rotors and Rear Axle | rondaw3g0410 | 99-04 | 1 | September 6th, 2006 11:00 PM |
