4.2 stroker
Old October 28th, 2009, 06:17 PM   #1
brianm4289 is on a distinguished road
4.2 stroker
alright, my 95 3.8 has a rod knock and I was thinking about just dropping in a junkyard motor until I heard about the 4.2 stroker. Now from what I have read all I will need to change during the rebuild of my motor would be a windstar crankshaft, bearings, and pistons? I am also thinking about going with souper coupe rods since one of my rods is probably destroyed anyways and I plan on adding a turbo if I stay v6. Also, would there be any timing or computer issues? I had thought about a 351w swap but I think I am gonna just stay with the 6. Can somebody confirm everything I would need to do the 4.2 stroker to my 95 3.8? thanks every1
Old October 29th, 2009, 03:13 AM   #2
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Find a junk yard low mileage 4.2L out of an f150....
Otherwise you're going to need to have your block bored, new pistons, rods, cam bearings to be safe, piston rings... (If i forgot anything I'm sure chris will be in here to add) anyway plus head gaskets, intake gaskets, fun stuff like that... And you may want to go ahead and do a split port swap, and camshaft while your in the motor.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old October 29th, 2009, 06:24 PM   #3
What year f150? Also let's say I were to take the v6 out of the f150 would it be a direct plug and play swap computer, mounts, hoses etc or any fab work? And could I use the accessories from my motor now on the f150 engine?
Old October 29th, 2009, 06:37 PM   #4
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Short answer to that is no.
Old November 11th, 2009, 10:54 PM   #5
ok well if thats a no then can I get an answer to the original question of what parts exactly I would need to make my 3.8 a 4.2? i know a windstar crank, pistons, and bearings... anything else? also when changing the 3.8 to a 4.2 is there any computer issues? thanks every1
Old November 12th, 2009, 09:46 AM   #6
94 Eaton V6
Surgin is on a distinguished road
You can find a write up on V6Power.net.
The official 4.2 swap post - V6Power Messageboard
Justin
Old November 12th, 2009, 08:35 PM   #7
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
crank from a 3.8 windstar isnt a 4.2...
you need a crank from a 4.2L v6 truck
then you need the proper connecting rods and a custom piston. unless you find a motor out of a 4.2L v6 truck and just use that short block...wont gain much power, wont be worth swap, and wont be stronger
[SIGPIC][/SIGPIC]
Acmillr loves me
Threads Similar to: 4.2 stroker
4.2l stroker Stang6899 V6 Mustangs 25 January 15th, 2008 08:22 AM
To Stroker or Not to Stroker? That is the Question! 87StangLX General Tech 13 October 20th, 2007 10:46 AM
stroker speck96 V6 Mustangs 1 July 8th, 2007 07:22 PM
stroker? SWEET2KSTANG 99-04 11 December 2nd, 2006 09:02 PM
No More Stroker =( itschristorres8 V6 Mustangs 155 November 22nd, 2006 08:09 PM
