Discussing Datalogging in the V6 Mustangs Forum. Ok so I have been doing thinking on datalogging versus dyno tuning. Ok so here ...
Old October 29th, 2009, 10:41 PM   #1
Codeman's Avatar
Datalogging
Ok so I have been doing thinking on datalogging versus dyno tuning. Ok so here is what I kind of think correct me if I am wrong. Is it true that you can get as accurate of results with datalogging if you do it with an wideband a/f while you datalog as when compared to dyno tuned. It seems like datalogging would be more accurate, because you are driving so you will get the airflow like you would when your actually getting your power, so your readings will be more accurate. Is that correct? I mean if you properly datalog. Cuz think of it if you are strapped to a dyno you don't have the same airflow as you would if you were accelerating down the road so that won't be as accurate of a reading.
UDP, CAI, True Duals, Sct Xcal III
Visit this automotive blog http://tooldesk.com/blog/
Old October 29th, 2009, 10:43 PM   #2
HMUSN's Avatar
a data log will give you safer numbers because you are in fact on the road.
a dyno tune will give you larger numbers though.
Old October 29th, 2009, 10:47 PM   #3
Codeman's Avatar
ok, well how does that work? I mean i know dyno tuning you will get to see what power you are making. Is the dyno tune larger number, because they have the dyno sheet to adjust for the curve? And as far as say I do not have access to a dyno would datalogging work well for just h/c/i? As long as I have a wideband a/f in my datalogging.
Old October 29th, 2009, 11:21 PM   #4
On a na setup a decent tuner can usualy get by without a wideband hooked up and make the proper adjustments off of the 02's.
03 3.8 procharger d1sc
318/326to 5000rpm
8.41@87.3mph in 1/8th
(needs a pi 3500 stall)
Old October 29th, 2009, 11:30 PM   #5
v606er's Avatar
69
I have an xcal 3 and an HP laptop, what else do I need for datalogging?
steeda UDP, steeda CAI, xcal3 w/ 93oct tune, 3.73's, tlok
magnaflow exhaust is in, dunno when it will be installed.
The unexamined life is not worth living.
Old October 29th, 2009, 11:33 PM   #6
V-SICKS
itschristorres8's Avatar
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
in real life the best tune is a done in a car on a laptop with an accurate a/f gauge and other gauge or acc.
Your cars load is different from the track to the dyno
The Devil & The Daily
Daily-13.37@104.4mph
V6- Stock bottom-439rwhp & 402rwtq 12psi 100oct
built motor-497rwhp & 508rwtq 15psi pump
Old October 30th, 2009, 12:28 PM   #7
Trick Tuners's Avatar
KB'd GT
Information on email tunes and the free retunes - Trick Tuners Forums
SCT Tuning, JLT intakes, Aeroforce OBDII gauges and PLX wideband products @ Trick Tuners
My forums
Xcal3 SF with preloaded tunes and free custom tunes for life for $379 shipped. Custom tunes based on actual data is extra.
Old October 30th, 2009, 03:04 PM   #8
Codeman's Avatar
that is kind of what I thought cuz it is real then.
Ok so I could tune using datalogging for h/c/i.
Old October 30th, 2009, 07:43 PM   #9
slvr2000stang's Avatar
2000 Mustang
14.10@96.75
I have not & would not. Always use a wideband.
2000 V6 vert
2003 Lightning
Old October 30th, 2009, 11:27 PM   #10
9986paulk's Avatar
1999 Mustang V6
Yea that's what I'm going to do when i get my cam done. It'll actually be close to the cost of a dyno tune, though, unless I find a good deal or used wideband.
Old October 31st, 2009, 01:26 AM   #11
v6 Mustang GOD
ESG-642T's Avatar
2k2 Mustang V6
Joe@tricktuners can write you a tune for a cam....
He wrote one for my stupid, didn't want to drive around town, cam.... And well the car ran good besides the fact that the cam shouldn't have been in my car.
Anything past that and you really need wideband data period, even when people go and do datalogging the cars usually have wide band's hooked up.
Old October 31st, 2009, 01:53 PM   #12
Codeman's Avatar
ok well i will maybe just get a mail order tune for now since i just got a bolt on basic car, until i get a wideband and some h/c/i
Threads Similar to: Datalogging
Xcal3 datalogging carlos Power Adders 1 August 21st, 2008 06:45 AM
datalogging question... BakerFX4 Trick Tuners 2 June 6th, 2008 07:42 PM
datalogging? Drxlubex All Other Vehicles 3 April 6th, 2008 10:58 PM
Datalogging using Xcal3 Mach Boy 99-04 9 March 4th, 2008 02:04 PM
DATALOGGING FIND NEED TO KNOW 05mustang_kb_charged 2005+ 2 May 19th, 2007 12:35 PM
