O2 Sensor Locations
Old March 16th, 2006, 12:37 AM   #1
green machine is on a distinguished road
O2 Sensor Locations
Can you guys tell me where the o2 sensor (bank 2 sensor 2) is located becuase different peolple have told me different things. One person said its on the passenger side after the cat converter and anothe said it was the pre cat on the driver's side...
thanks
my vehicles:
1996 Mustang v6 232 ci
1969 F100 stepside inline six 300 ci
www.mooresvilledragway.com
www.shadysidedragway.com
Old March 16th, 2006, 09:05 AM   #2
mdvaldosta's Avatar
11.47@120.58
What's the actual code? Bank 2 is the driver's side... but I've never heard any reference to a sensor number. Usually you get it as upstream or downstream.
Taken from Ford OBDII Diagnostic Codes:
P1137 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1138 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1150 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1152 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1157 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1158 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
Old March 16th, 2006, 08:02 PM   #3
the code is p0156
(o2 circuit bank 2 sensor 2)
my vehicles:
Old March 16th, 2006, 08:07 PM   #4
mdvaldosta's Avatar
11.47@120.58
Bank 2 is definately the drivers side, and I'm 99% sure sensor 2 is downstream (after the cat).
Old March 16th, 2006, 10:40 PM   #5
thanks. I just took that one offf a little while ago and the exterior has a crack in it so i think i fixed the problem so far. Thanks for all the help.
my vehicles:
Threads Similar to: O2 Sensor Locations
Stock Vaccum Line Locations Speedstang302 5.0 Mustangs 20 November 3rd, 2007 03:12 AM
harness locations for a Notch homebrewed 5.0 Mustangs 11 October 21st, 2007 12:28 AM
Motor Mount Locations GTpwrdCapri Modular Mustangs 4 March 2nd, 2007 08:59 AM
O2 Sensor Locations? Blue98GT Modular Mustangs 7 January 10th, 2007 07:05 PM
