Gear Question - Page 2
Old March 19th, 2006, 09:59 PM   #21
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
$379.99 from mustangtuning.com. but vmp tuning has the same price, and justin from vmptuning.com does a great job with tunes...
ModdedAutos
1999 Mustang V6
Old March 19th, 2006, 10:11 PM   #22
02v6Mustang is on a distinguished road
Hey Atlantic Blue did u take a look at that setup that i put on the thread a few posts earlier? If u have time could u take a look at it and see if that setup would be alright? Cuz i don't don't much about that brand.
Old March 19th, 2006, 10:31 PM   #23
14.79 @ 92.15
the 2 links you provided (the motive gear and frpp t lok) are good deals. you would be lucky to be see advertised that low...
here is what i have and run:
mac long tube headers
off road h pipe
magnaflow cat back
cai
sct xcal 2
ran a 15.650 @ 86.420 with stock gearing and one wheel peeling. this thursday i am expecting very low 15s or very high 14s.
now i can easily hand asses to stock eclipses, but camaros of different years/options have different engines- even in the v8. a v6 camaro is a 17second 1/4 mile car stock. same goes for v6 trans am... now some v8 camaros are like stock 5.0L mustangs with just over 215bhp and 15 second 1/4 miles. so depending on the motor and driver and what you can run, the results of the races you have in mind are questionable.
as far as the brand- motive is like frpp gears, but generally 10-20 dollars cheaper for the ring and pinion set. also, motive is a louder gear than the frpp unit. some say the motive gear whines a little...
ModdedAutos
1999 Mustang V6
Old March 19th, 2006, 10:41 PM   #24
So u don't think i would be disappointed with thsoe two links that i provided if i bought and installed those gears with that t lok? And as far as the camaro goes all i know about it is that it is a 1995 Camaro Auto V6 (2.8L i think) and a completely stock motor.
Old March 20th, 2006, 07:08 AM   #25
14.79 @ 92.15
i could beat the camaro to 25mph on my bicycle man. dont even worry about the camaro- actually, i would encourage a video taped ass whipping of the camaro.
and you will be fine with the links you provided. if you are installing them yourself, you will need an installation kit- aapx $60 and the gear lubricant/friction modifier. shops carry this stuff and install should be around $250
ModdedAutos
1999 Mustang V6
Old March 20th, 2006, 11:11 AM   #26
ok that works. i'll probably get a shop to install it for me. thanks again for your help. i really appreciate it.
Old March 20th, 2006, 07:49 PM   #27
artisan00 is on a distinguished road
i agree with everything atlantic said, just dont spend TOO much time at 115...... the revs will be pretty high at that point
(truthfully i dont think its safe to drive that fast on public roads anyhow but im not your daddy :wink )
Old March 31st, 2006, 06:50 PM   #28
red stang is on a distinguished road
Send a message via AIM to red stang
ok youll prolly think im retarded but what are these gears youre all talking about? What do they actually do and what do all these numbers mean? Someone please explain this to me and what some good setups are. I have a 99 v6 auto so what would be the best?
Old March 31st, 2006, 06:55 PM   #29
14.79 @ 92.15
the gears are ring and pinion gears for the rear end. i actually ran a 15.025 at 91.37 mph the weekend after i put my gears in and had a break in period pass. and this time was with a locked converter in the transmisison. i am now expecting mid 14s out of a rebuilt tranny- enough to beat stock 4.6L's, even some 99-04 gt's.
stock, you have an open rear end differential with 3.27:1 ring and pinion ratio gears. a gear such as a 3.73:1 or 4.10:1 would get you better accelereation and get you into your powerband rpms quicker, thus making your car faster. on my bolt on 99 v6 auto, i gained 1/2 second from the gears in my 1/4 mile time, and my trap time is consitently in the 91+ mph range now instead of high 80mph range.
I have Ford Racing Performance Parts 4.10:1 ring and pinion gears and a Ford Racing Performance Parts Trac lok differential (to get both the left and right rear wheels to spin equally in straight lauches)
ModdedAutos
1999 Mustang V6
Old March 31st, 2006, 07:58 PM   #30
im confused, what actually do they do and how does it help performance? I understand that it helps the acceleration and allows you to get to your power quicker but how? Sorry about all the questions.
Old March 31st, 2006, 08:03 PM   #31
14.79 @ 92.15
The gears change the motion of the driveshaft to the axles to make your car move. The ratio of the gear is what effects performance. A gear with a higher ratio (i.e. 4.10:1) will turn the rear end more quickly than that of a gear with a lower ratio (i.e. 2.73:1 or 3.27:1). By changing the gear ratio, you simply enable your car to acclerate quicker or slower. so getting a gear like a 4.10:1 gear will allow your car to acclerate more quickly
ModdedAutos
1999 Mustang V6
Old April 1st, 2006, 02:35 AM   #32
blue6er99's Avatar
blue6er99 is on a distinguished road
hey AB what kind of gas mileage did you get with those gears
Old April 1st, 2006, 06:41 AM   #33
14.79 @ 92.15
I don't know yet. I had them about a week before I had to put the car in the shop to rebuild the transmission.
ModdedAutos
1999 Mustang V6
Threads Similar to: Gear Question
4.10 gear question thatonekidw/theGT 99-04 11 October 14th, 2007 07:48 PM
yet another gear question... 01silversnake 99-04 3 September 26th, 2007 04:22 PM
gear question?? steveclark79 Modular Mustangs 1 August 13th, 2007 09:40 PM
got a gear question bloo4.6 99-04 8 June 21st, 2007 04:10 PM
Gear question amphibrecon 99-04 3 March 23rd, 2007 07:32 AM
