ticking noise desperate for help!!
Old November 16th, 2009, 11:00 PM   #1
95 mustang v6
mustang95 5.0 is an unknown quantity at this point
Send a message via AIM to mustang95 5.0
ok i havn't been on in a while trying to fix my car before getting into upgrades, ok my 95 v6 mustang has been ticking for a while now i have fixed and exhaust leak on the exhaust manifold that was cracked, i have replaced all of the rocker arms and pivots because they were worn on both sides, and the car still ticks when giving it gas. im assuming its the lifters hoping its not any ideas????
F.O.R.D
First On Race Day
enough said
Old November 17th, 2009, 08:50 PM   #2
Ticket-Me-Yellow's Avatar
2001 Mustang V6
14.89@93 mph
Ticket-Me-Yellow is on a distinguished road
Send a message via AIM to Ticket-Me-Yellow
im still saying exhaust leak. Same thing happened on my work truck (F-250)
Selling Mustang So Im
Selling All M112 Parts
Old November 18th, 2009, 10:39 PM   #3
95 mustang v6
On the exhaust manifold? cause i just checked them, any ideas roughly were the leak could be, would be very helpful
F.O.R.D
First On Race Day
enough said
Old November 19th, 2009, 08:44 PM   #4
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
Best way to check is have a shop "smoke it". They will put smoke in the exhaust under pressure and any holes will be seen real easy. Their can be small cracks in the exhaust you cannot see with your eyes.
If its a sticky lifter, I woldnt worry too much. Just about every car Ive ever owned had a tick for a period of time. Unless its really loud with other simptoms I wouldnt worry.
Get a "stethascope" and listen to different parts of the motor. Isolate where the sound is comming from. I had a tick real bad once and thought it was a lifter. I isolated the sound to a fuel rail and then back into the injector. I ran a couple bottles of injecotr cleaner through and it fixed it.
Old November 20th, 2009, 12:50 AM   #5
95 mustang v6
well its not really loud but just annoying, been trying to fix this problem for a while now. i am going to have to try the stethascope again, also would running c foam through the car show leaks also?
F.O.R.D
First On Race Day
enough said
Old November 20th, 2009, 09:11 AM   #6
stephen has a spectacular aura aboutstephen has a spectacular aura about
If it happens when giving it gas, it could be an exhaust leak still. One place to check is the joint at the bottom of the manifold where the converter assembly attaches.
Are you sure your not hearing preignition ( pinging) ? That can be caused by
build up of carbon.
Old November 20th, 2009, 02:04 PM   #7
95 mustang v6
build up of carbon.
ya im going to give that a try see if i can see anything, and no its not a pinging sounds because at an idle you can barely hear it, its when you give it gas you hear it, it almost sounds like ticking springler noise when giving it gas.
F.O.R.D
First On Race Day
enough said
Old November 20th, 2009, 02:08 PM   #8
2004 V6 Coupe
04stang123456789 is on a distinguished road
check to make sure all the bolts are really tight at all of the connections in the exhaust because this same think happened to me and it was just a bolt that needed to be tightened a half a turn from the headers to the pipe. Most of the time its something small and stupid like that, and thats an easy problem to check and fix, so start there.
Old November 20th, 2009, 03:52 PM   #9
2000 Mustang v6
winnie51189 will become famous soon enoughwinnie51189 will become famous soon enough
Send a message via AIM to winnie51189
+1 on the exhaust leak at the manifold to pipe flange. It seems to be the most common.
Old November 21st, 2009, 04:30 PM   #10
95 mustang v6
alright, i will give that a look an see if that solves the problem
F.O.R.D
First On Race Day
enough said
Old November 28th, 2009, 10:15 PM   #11
lcorriveau3's Avatar
1999
YAWN!!! what??
lcorriveau3 has a spectacular aura aboutlcorriveau3 has a spectacular aura aboutlcorriveau3 has a spectacular aura about
Two years ago I had to replace exhaust manifolds and bolts. It stopped the ticking. Good luck.
Old November 29th, 2009, 05:11 PM   #12
95 mustang v6
thanks a couple weeks ago i just replaced the right side exhaust manifold, cause it was cracked, and i have looked at the other manifold, and it seems fine, when im driving the tick you can feel it like its underneath the car, im wondering if if the catalac convertors have a leak or somewhere around there. if not then my last resort is the lifters, very frustrating lol
F.O.R.D
First On Race Day
enough said
Old November 29th, 2009, 08:33 PM   #13
2004 V6 Coupe
if you have a jack and a couple jack stands, just go under the car and tighten the bolts at the flange where the pipe meets the manifold. All it takes is a slightly loose bolt for the ticking noise to happen. Its really easy to do just put the wrench on there and tighten them up as tight as you can before you go looking at the cats... This problem happens a lot and it happened to me and all it was were a couple bolts that werent tightened up all the way...
Old November 29th, 2009, 11:21 PM   #14
95 mustang v6
thanks hopefully that does the trick gonna try it out tomorrow or the next day with some good weather thanks man.
F.O.R.D
First On Race Day
enough said
Old December 1st, 2009, 11:04 AM   #15
2000 Mustang Convertible
redrocket7002 is on a distinguished road
This may not have anything to do with your sound but I had a sound to and it was the windshield washer fluid container shaking back and forth. (rusted out fender where its attached
Old December 1st, 2009, 01:22 PM   #16
2003 V6 Mustang
14.2 @ 96
ewells2420 is infamous around these partsewells2420 is infamous around these partsewells2420 is infamous around these parts
its a bomb!
Old December 5th, 2009, 04:44 PM   #17
95 mustang v6
Originally Posted by ewells2420 View Post
its a bomb!
lol hope not. i have been waiting for a day for it to stop raining so i can try tightening the exhaust flange bolts to see if that solves the problem. if not im going to replace the lifters over the summer
F.O.R.D
First On Race Day
enough said
Old December 14th, 2009, 06:50 PM   #18
95 mustang v6
i finally had time today to tighten the flange bolts but there tight, i think the only thing i could think of now would be the lifters at this point or another exhaust leak thats microscopic gotta bring my baby to the shop
F.O.R.D
First On Race Day
enough said
Old December 14th, 2009, 09:47 PM   #19
2000 Mustang v6
You really should take the manifolds off and look for leaks. I ran some seafoam through my car before taking my manifolds off, and it really showed the leaks.
Old December 14th, 2009, 11:05 PM   #20
2003 Mustang V6 Pony
JW101 is on a distinguished road
I had the same thing in my 03! I took it to the dealer and they took the manifold apart and said it was something to do with that. I always ticked when it was just starting up, or accelerating rapidly.
Threads Similar to: ticking noise desperate for help!!
ticking noise rainier446 99-04 14 May 26th, 2009 08:15 AM
a ticking noise 87gtmustang 5.0 Mustangs 20 February 7th, 2009 01:43 PM
a ticking noise 87gtmustang 5.0 Mustangs 2 February 4th, 2009 03:27 PM
ticking noise tweeters97 96-98 2 March 16th, 2008 09:31 PM
ticking noise kreil45 5.0 Mustangs 2 April 23rd, 2007 02:11 PM
