WHenevr someone gets a Mac Cold Air Induction
Old February 19th, 2007, 08:13 PM   #1
V6boi is on a distinguished road
Send a message via AIM to V6boi
Noobie question but ...
How do you get the filter in the quarter Panel, does it gets fit in. Or do u have to take out the wheel well? just asking due to installation purposess
If i wanted to drive like a Civic , I would've pulled my E-Brake up
Old February 19th, 2007, 08:21 PM   #2
DeathScythe95 is on a distinguished road
Send a message via AIM to DeathScythe95
you should be able to get to it from under your car, it was a tight fit when i installed mine, you done have to take off the wheel or anything
VROOOOOOOMMM!!!
Old February 19th, 2007, 08:41 PM   #3
02 Mustang V6
13.605 @ 101.60
Garman91 is on a distinguished road
iTrader: 6 reviews
I had to buy my best friend a McFlurry to come over and help... It goes smoothly w/ two people...
BBK Intake, BBK 70MM Throttle Body w/ Port Matched Upper Intake, BBK Shorty Headers, Magnaflow Exhaust, GT Tips, Eibach Sportline Springs, EGR Delete, Aluminum DS, 7.5 T-Lok w/ 3.73's, Centerforce Clutch, ZEX 75 Shot, Sniper Tuned
Old February 19th, 2007, 08:43 PM   #4
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
there is a hole where your old intake went. i you want to change it just take off the pipe that connect to the MAF.
NCMM #9
Old February 19th, 2007, 10:13 PM   #5
02ponypackage's Avatar
02ponypackage is on a distinguished road
I have a MAC intake...and that filter can be a problem being wide....you just need to get under the car and stretch armstrong to bolt the clamp on the intake to the pipe...I did it at nite so it didnt help me out but I made sure the rest of the piping was set the way it should be and tightened i couldnt look and tighten the bolts because I needed to stretch so much but just getting the filter in there with a screwdriver in hand ready to finish clamping will do the trick...its a hassle
just a V6 with a bad belt slip under the hood
Old February 19th, 2007, 10:13 PM   #6
like put the filter on the pipe and just slide it in?
Old February 19th, 2007, 10:17 PM   #7
no ....make sure the piping is set....then work that filter from under the car going up...there will be a slight opening in order to see wat ur doing with a flash light if needed....just make sure u push it onto the pipe then turn both screws then make sure u check it from above if its on and or loose
Old February 19th, 2007, 10:18 PM   #8
MM's Resident Ricer
2006 Scion tC
13.001@113
thats what I did put it on the pipe. Slide it in then bolt it up to the maf.
NCMM #9
Old February 19th, 2007, 10:19 PM   #9
the mac filter is to wide for the fenderwell hole....its not a small simple one...its the pain in the arm one
Old February 19th, 2007, 10:22 PM   #10
MM's Resident Ricer
2006 Scion tC
13.001@113
I have a mac kit but I put a smaller filter on it. But you can turn it sideways and put the long part in then turn it and get it in. Then bolt up to the MAF then the heat shield.
NCMM #9
Old February 19th, 2007, 10:27 PM   #11
mine wouldnt fit from inside the bay....so i went from the bottom
Old February 19th, 2007, 10:29 PM   #12
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah it took some work thats why I changed it with the K&N conical. Plus it will be easier to fit my ram air to.
NCMM #9
Old February 19th, 2007, 10:32 PM   #13
yea, i put mine on the intake then slid it in eventually because putting it on and tightening it under the car was a bitch, but my filter was smaller too
VROOOOOOOMMM!!!
Old February 19th, 2007, 10:35 PM   #14
i had the Mac wide filter...its bigger then a cone style
Old February 19th, 2007, 10:37 PM   #15
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah thats the one I originally had it was annoying to get in but I made it go. My body kit made it hard to get to the filter.
NCMM #9
Old February 19th, 2007, 11:11 PM   #16
I do have a K&N Cone shaped one , will that do good enuff?
Old February 20th, 2007, 12:05 AM   #17
Will a cone shaped K&N filter fit on the tubing? cause it fits on my tubing now or whatever it is on now, being stock intake
Old February 20th, 2007, 12:39 AM   #18
1995 BMW 325i
232stang is on a distinguished road
Send a message via AIM to 232stang
i couldnt get my heatshield pushed all the way back, it was a punk.
Originally Posted by Cesar2cool
lol i use my car for speed
Old February 20th, 2007, 12:40 AM   #19
So the K&N filter will work on the new tubing or will i just have to go up under the car that way with the new filter?
Old February 20th, 2007, 09:55 AM   #20
MM's Resident Ricer
2006 Scion tC
13.001@113
the K&N will work I like it better personally the MAC filter is no different just a different shape. I didn't even put the heat shield on. there is so much air running through the fenderwell it is pointless IMO and you have more fresh air coming into the engine bay without it.
NCMM #9
Threads Similar to: WHenevr someone gets a Mac Cold Air Induction
forced induction Elder 96-98 10 October 24th, 2007 08:37 PM
Cold Air Induction for us Newbes RyanHNT Parts 1 June 2nd, 2007 12:28 AM
Forced induction? shroom 99-04 4 June 2nd, 2007 12:20 AM
cold air induction jellybean 99-04 18 February 11th, 2007 04:39 PM
My cold air induction has a problem SlvrStang V6 Mustangs 17 January 14th, 2007 08:58 PM
