2000 v6 mustang engine problems
Old December 17th, 2009, 10:48 PM   #1
2000 Mustang V6
Mr.James is on a distinguished road
so my auto 2000 v6 mustang has been beat up by the previous owner (the idiot) and has about 120,000 miles on it..well every now and then it will suddenly downshift, i lose all power, exhaust noise is nonexistant, and i have to floor it to go from 0-15 and it takes forever, and it shakes ALOT. its happened 4 times, everytime i just turn the car off and start her back up and it goes away, well tonight it did it to me twice in a row and after the 2nd time my Service engine soon light came on
my dad thinks something with the electronics is screwed up. could it just be my ecu going bad or am i facing a more serious problem? i plan on taking it to Advanced auto parts tomorrow and having them check the error codes bc i heard they do it for free...any other suggestions?
Old December 17th, 2009, 11:33 PM   #2
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
At this point the best thing to do is get the codes checked. Let us know what the codes read out to be and we should be able to steer you in the right direction. Best of luck.
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Old December 19th, 2009, 07:56 PM   #3
xn1919's Avatar
2000 mustang
xn1919 is an unknown quantity at this point
Send a message via AIM to xn1919 Send a message via Yahoo to xn1919
get a new one
visco
Old December 19th, 2009, 08:26 PM   #4
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
Originally Posted by xn1919 View Post
get a new one
if you arent going to be helpful dont post.
SCT Mass Air Flow Sensor $200
Old December 20th, 2009, 03:06 AM   #5
rfcsoulja's Avatar
01 True Blue v6
to slow to matter
rfcsoulja will become famous soon enough
Have you given it a tune up (plugs, wires, and coil possible)?
Old December 20th, 2009, 08:27 AM   #6
stephen has a spectacular aura aboutstephen has a spectacular aura about
Before guessing it would be good to read out the code from the OBD II system.
Old December 20th, 2009, 06:54 PM   #7
2000 Mustang V6
i talked to a mechanic friend of mine and he thinks that one of my O2 sensors is shot..could this be the culprit?
Old December 21st, 2009, 12:43 AM   #8
2004 V6 & 2000 GT
A bad 02 sensor doesn't usually cause a problem like the one you described.
I would think a TPS sensor, or something with the transmission.
But it's best to get the codes pulled.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old December 21st, 2009, 12:47 AM   #9
Dancing Naked In The Rain
mcqueen's Avatar
+1 I have a bad O2 sensor and about all it's doing is killing my gas mileage.
Old December 21st, 2009, 04:56 PM   #10
2000 Mustang V6
why would something with my transmission kill half my cylinders and make it idle rough?
Old December 21st, 2009, 11:42 PM   #11
If it's the O2 sensor, I don't see why the transmission would downshift when the problem happens. The O2 sensor should give an OBD II code. If the engine has more than 100K miles, the O2 sensors should be replaced anyway, so you might try replacing them.
Old December 22nd, 2009, 06:33 PM   #12
2000 Mustang V6
just got it back from the ford dealer
it was the starter coil, it was loose/going bad
they tighten it up and im going to get it replaced soon
Old December 22nd, 2009, 08:16 PM   #13
2004 V6 & 2000 GT
I was putting that in there because you said it would downshift randomly. I didn't mean for it to sound like the sole problem.
04 V6/00 GT
460WHP/500WTQ
Turbo Build
Old December 30th, 2009, 08:12 PM   #14
2000 Mustang V6
nah its all good just didn't know exactly what you meant by it
but the problems gone and im replacing the starter coil soon so it won't happen again
thanks guys
Old December 30th, 2009, 09:03 PM   #15
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
yeah probably your coil pack, also check the shift relay on your transmission the downshift makes me wanna say its that
NCMM #9
Threads Similar to: 2000 v6 mustang engine problems
Problems with my buddy's 2000 Mustang GT 4.6 ... NastyZ28 99-04 18 January 4th, 2009 12:35 PM
2000 Mustang Mach 460 Radio Problems bushden Audio/Video 21 March 28th, 2007 07:25 PM
