Discussing Not starting after rebuild in the V6 Mustangs Forum. Just had both heads off a 95 V6 and now she is refusing to start. ...
Old March 20th, 2006, 11:09 AM   #1
Just had both heads off a 95 V6 and now she is refusing to start. The engine is trying to fire, I believe I now have compression on all six cylinders. gotta check in a bit to make sure I have spark, (and fuel was undisturbed). Is there any way at all that the engine or ignition timing could have been disturbed? anybody know of similar problems, or known faults? for example, what would happen if the coil pack was on its way out? ANY hints or ideas for what to check are welcome as its got me totaly confused now.
Many thanks
Old March 20th, 2006, 11:51 AM   #2
Make sure you have the plug wires on the coil properly ... it is numbered in a strange pattern............. also check your plug wires and ensure they are connected to the correct plugs.
2003 Mustang Mach1
1995 Thunderbird LX 4.6; 4R70W w/Jmod, 8.8 3.27 Tracloc
1995 Mustang 4.2; MPX Supercharger/25%OD, 4R70W w/Jmod, 8.8 3.73 Tracloc (343rwhp/420rwtq)
Old March 20th, 2006, 03:33 PM   #3
It ran ok before the gasket went, as far as I can tell we didn't do anything to disturb the timing. I've just had all six plugs out, plugged into the leads and then placed against the engine. Turned her over and plugs 2+4 weren't sparking at all. changed plugs around and they came to life the next time I tried. Next thing is to look at the timing feed going into the coil (make sure thats set correctly, if there is any way to check). then replace plugs and try again.
Old March 20th, 2006, 06:56 PM   #4
You really should check the sparkplug wires.
2003 Mustang Mach1
Old February 22nd, 2007, 05:53 PM   #5
check the gap on those plugs. also check the distributor
FORD= First On Race Day
I'd rather push my FORD than have it towed by a Chevy.
Threads Similar to: Not starting after rebuild
c4 rebuild 342stroker Drivetrain 2 October 10th, 2007 01:57 PM
3.8 Rebuild arnett V6 Mustangs 5 October 9th, 2007 09:04 PM
To rebuild? hudini Engine 2 September 30th, 2007 10:47 PM
A little help after the rebuild? mikebert 5.0 Mustangs 28 August 16th, 2007 04:55 AM
T5 rebuild 92mustanglx 5.0 Mustangs 2 May 29th, 2007 09:48 AM
