white smoke?
When I get on it occasionally white smoke pours outta my exhaust...it only happens on punches from about 50 or above...any ideas on what or why this is
2000 V6 vert Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears. |
blown head gasket or intake gasket not good dude not good at all. ur burning coolant
MM's Resident Ricer
2006 Scion tC
13.001@113
how long has your exhaust been in?
48.47@ 12.58
+1 on burning coolant
The exhaust has been on since about the end of dec...I haven't seen the smoke 4 a while though
MM's Resident Ricer
2006 Scion tC
13.001@113
umm your exhaust shouldn't be burning any thing off anymore than. Yeha you got a bad gasket somewhere
check your oil is there airation bubbles in it or is it orange maybe a bit green cuz u might be putting it right into ur crank case and thats even worse then burning it. also pop the coolant cap off and check for oil in ur reservoir. also inspect the outsideo f the block by the heads and where the intake bolts on for a visible leak.
Hmm...ok I also remember a lil oil on the rear 2 spark plugs...is that involved...and what color would the coolant be if I had a problem...and I thought blown gaskets led to overheating
u got a cracked head most likely if u got oil on ur plugs or bad valve seals or bad rings. last time i had oil on my plugs it was a cracked head.
MM's Resident Ricer
2006 Scion tC
13.001@113
Man I would go get full diagnostic test and have them run a compression test as well.
#11 | |
And its only on the two rear most plugs...and how would one crack a head
#13 | |
#14 | ||
he doesnt have that much power these blocks can hold plenty power.
MM's Resident Ricer
2006 Scion tC
13.001@113
Yeah you crack a 3.8 block you are doing very good it is one of the strongest block available from ford. It is something within the internals.
i cant see any bolt-on cars cracking the block unless they have a zillion miles on them
I don't drive fast. I fly slow.
MM's Resident Ricer
2006 Scion tC
13.001@113
I even doubt that I have never heard of a 3.8 cracked block. Ford did there homework designing this one.
#18 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
oh yeah but the actual block is amazing imo
#20 | |
Threads Similar to: white smoke?
| My white smoke problem pt.3 | ByPopularDemand | V6 Mustangs | 16 | May 12th, 2007 05:40 PM |
| That white smoke | ByPopularDemand | V6 Mustangs | 19 | April 19th, 2007 10:56 AM |
| white smoke at idle | product1620 | 96-98 | 10 | April 11th, 2007 04:37 PM |
| My white smoke problem | ByPopularDemand | V6 Mustangs | 17 | March 22nd, 2007 10:44 AM |
| white smoke | zero | 5.0 Mustangs | 47 | March 19th, 2007 11:22 PM |
