How Many Inches Should I Lower
Hey guys.. well Ive been thinking about lowering my stang, its a 2000 V6 with a Roush body kit, how many inches should I go for ?? the thing is that I dont want the hard/stiff ride, its basically for looks
Ive been doing some research and I see they go from 1" to 2" any place where I can get a good deal? thanks you all |
02 Mustang V6
13.605 @ 101.60
![]() iTrader: 6 reviews
I went w/ Eibach Sportline's in the front, stock springs in the rear, and just wore out $300 worth of tires in 4 months because I didn't install Caster/Camber plates. Seriously consider these plates if you're dropping your car. I don't care how low you go I would install them and have the car professionally aligned after the spring & c/c plate install.
BBK Intake, BBK 70MM Throttle Body w/ Port Matched Upper Intake, BBK Shorty Headers, Magnaflow Exhaust, GT Tips, Eibach Sportline Springs, EGR Delete, Aluminum DS, 7.5 T-Lok w/ 3.73's, Centerforce Clutch, ZEX 75 Shot, Sniper Tuned
yeah I heard about the camber plates!!
thanks!! I will do that! |
1.5 is the usual lowering height that is done. What size rims?
48.47@ 12.58
If you want both comfort and lowering then your best bet is airbags honestly.
White 2000 V6 Mustang|Black Saleens 18x9|Flowmaster 40s|AM CAI|8000K HIDs|SCT XCAL III/H&R SS
I got 245/45/17 front and 275/40/17 u think 1.5" all 4 corners are ok?
any good deal? thanks |
2000 Mustang
Yeah you should be ok
![]() Detailing Crew Member North Carolina Modded Mustangs #5 |
Thanks you all!
2005 Mustang V6
I put it the Eibach pro kit 10 month's ago springs and dampers and never had the car re-alined, and I guess im lucky, because the tires are still very good. But when I put on my 17 inch tires in April, I will have it re-alined.
CAI, UDP, Eibach Pro Kit, Predator performance tune, C/C Plates, Ajustable Panhard Bar, 17 inch rims and tires, GT duals with Pypes X pipe. GT Rear Bumper. |
2005 Mustang V6
Question for GT owners,Fog lights
A early Christmas present for my 05 V6, fog lights. If I get the GT light switch, can you have both the head lights and fog lights on at the same time?or just the fog light? Also, what type of bulb goes it there? Thanks and happy holidays...
2006 Mustang 4.0
![]() iTrader: 1 reviews
Yes the GT switch pulls out for the fogs. So turn it all the way over then pull it out for both the headlights and the fogs.
2005 Mustang V6
Great, Thanks
MM's Official Lucifer
Eibach prokit (rated 1.5" drop) and 18x9 rims w/ 245/40 tires.
This is what the rubbing did to the wheel well (driver's side) ![]() So I cut that portion out ![]() And pop riveted a sheet metal plate on the inside of the well. Silicon puddy to seal it all up.
So... just know issues may occur over time. Since Ford made the driver's side well dip lower in that spot to make room for that wire loom??? Maybe something on the GT goes there? Either way, problem solved now, smaller turning radius! Woo hoo!
2000 sixxer, 1988 Fox
Just be forwarned to do it right, you'll spend some money, I spent about 700 dollars on mine 800 after the alignment, and mine is h&r ss springs, maximum motorsports c/c plates (you definitly need those) and kyb gr-2 shocks and struts, and I did all the labor myself. BUT it does ride really nice just a bit stiffer than stock and it lowered me 1.75 on all 4 corners
99 GT & 05 GSXR 750
next year
1.75-2" Ftw!
![]() NCMM Treasurer/Coordinator Moto Droid FTMFGDW MM Cares Crew GRAMMAR NAZI |
Threads Similar to: How Many Inches Should I Lower
| 10.5 inches in the front? | domrebel9 | 99-04 | 36 | December 28th, 2009 02:35 AM |
| My rear end is off by a few inches... | silver2006foose | 2005 - 2010 | 11 | May 18th, 2009 02:26 PM |
| how many inches is this | 00redgt | General Tech | 0 | May 3rd, 2008 07:03 PM |
| 460 Cubic Inches | MSO | The Clubhouse | 28 | November 10th, 2007 01:36 AM |
| how many inches to lower? | tjames | V6 Mustangs | 7 | August 27th, 2007 06:58 PM |
