question on camshafts?
Old December 28th, 2009, 03:09 PM   #1
BlueStang624 is on a distinguished road
ok so im the newbie to the site right now... i have a 2000 v6. its got mild upgrades to the motor like cold air intake, TB spacer, and soon a SCT chip.. i was thinking of doing a cam next.... any suggestions? also whats an estimate price to have a 3.8L rebuild.. mines got 190k on it and i dont wanna start building it up to blow it up
Old December 28th, 2009, 03:22 PM   #2
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Depending on goals you can go mild to aggressive, SuperSixMotorsports sells them, as well as packages with heads and intakes as well. Also, there is a member here that used to actually sell cams, however I'm not sure if he still does, he'll be in here shortly I'm sure.
I do want to say avoid a chip. A tune, even "canned" ones will give better results than a chip. SCT sells handhelds, and there are connections here to have custom tunes made based on data logging that you can do by simply driving the car and sending an email. Especially if you get into the motor or add FI this is the way to go.
Old December 28th, 2009, 03:54 PM   #3
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
cold air, and tb spacer don't even fall into mild they fall into "beginner" at best. I would suggest you do a rebuild, port&polished heads, intake, and a camshaft.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old December 28th, 2009, 05:39 PM   #4
9986paulk's Avatar
1999 Mustang V6
9986paulk will become famous soon enough
and, to be honest, the throttle body spacer falls into the "worthless" category. And the CAI is almost the same, maybe 2-3 horsepower. But yea I would say get a handheld if you want to do anything to it other than bolt-ons really. Depending on your goals, which you really should decide first...if you're really serious you could do forged internals now, or even a stroker. But the thing is if you're just a beginner, you're going to have to pay someone to do all the work, which could get pricey. But I don't think the install would be any more or forged stuff than hypereutectic and cast, just the difference in parts prices.
Old December 28th, 2009, 05:45 PM   #5
slow as sin....
pyschopath76 will become famous soon enoughpyschopath76 will become famous soon enough
^+1
JLT Ram Air Intake/Accufab 70mm Throttle Body & Upper Plenum/SLP Longtube Headers/SLP Catted X-pipe/SLP LM1/4.10 gears
Military Crew - AZ2(AW)
Black Stang Member #6
Old December 28th, 2009, 07:54 PM   #6
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
for the cost of your rebuild if you are just looking at putting some bolt ons on your car, it wont cost near as much as building a fully built motor. I would not even waste time with forged internals unless you plan on going all out such as a big shot of nitrous, or f/i. It is a waste of money. You could maybe look instead of rebuilding your motor, look on the internet they have 3.8s all over that do not have many miles for cheap, and you may stumble across a good deal. If you cant find any just figure out what your plan is for your car and how you want to rebuild your engine and start calling around and getting estimates.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old December 28th, 2009, 08:17 PM   #7
just cuz everyone is talking about goals.. basically what my plans are, is to either a. rebuild the motor or b. find one with way less miles... then i was going to do some small internal things then i also wanted to swap for a 5 sp and turbo it
Old December 28th, 2009, 08:24 PM   #8
Codeman's Avatar
ok, well if you are looking to do stuff on the inside of your motor, if yours is in decent shape besides high mileage wear without any severly worn cylinders, mains, and crank it should not be to expensive and i would rebuild my own motor then and do what you want on the inside.
Old December 28th, 2009, 09:26 PM   #9
basically all i had in mind was to replace the camshaft, rocker arms, and valve spring. so when i can afford the turbo, im not putting so much work on stock parts
Old December 29th, 2009, 11:33 AM   #10
Codeman's Avatar
ok, well how much hp you plan on with your turbo kit? and if you replace all the valvetrain i would also add in some hardened pushrods. If you plan on stayin under the 400 rwhp mark you are fine on the stock bottom end and pistons. If not or if you like dishing out the money for a little reassurance then you can go ahead and put all forged parts in but it is gonna cost a lot of money.
Old December 29th, 2009, 01:41 PM   #11
2003 V6 Mustang
14.2 @ 96
ewells2420 is infamous around these partsewells2420 is infamous around these partsewells2420 is infamous around these parts
Only rebuild your current one IF you plan on doing a stroker kit with it and/or forged internals. Otherwise just go find a low miliage one from a junkyard.
Old December 29th, 2009, 02:10 PM   #12
9986paulk's Avatar
1999 Mustang V6
^ Yep that's pretty much the case. It'll probably be around $1000 more for forged internals from what I see @ SSMS. If you're planning on turbo, then yes, do it. Even if you don't end up with the turbo, then you can have your engine rev higher and it'll last pretty much forever N/A.
Old December 29th, 2009, 05:01 PM   #13
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
cheapest stroker kit is 1350 from ssms. Once you add bearings, machine work, and labor if you can't install it yourself you'll prob be around 2300$ or so.
Old December 29th, 2009, 07:47 PM   #14
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
Car-Part.com--Used Auto Parts Market
To find a engine near you. You could also use a 4.2l out of a f-150 or e-150 but will need to be tuned. This motor with a cam will give you some a much power curve over the 3.8 because the added displacement.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old December 30th, 2009, 01:57 PM   #15
9986paulk's Avatar
1999 Mustang V6
Well I just meant about $1000 more in parts over what you would pay to rebuild the engine with hypereutectic stuff, which is actually pretty close to right in that case. And that wasn't for a stroker kit, just 3.8 forged. But if I wa doing the forged stuff, I'd stroke it while I'm at it.
Old December 30th, 2009, 06:21 PM   #16
lcorriveau3's Avatar
1999
YAWN!!! what??
lcorriveau3 has a spectacular aura aboutlcorriveau3 has a spectacular aura aboutlcorriveau3 has a spectacular aura about
Stroke it Poke it and Tune it.
Threads Similar to: question on camshafts?
camshafts fliptikal 96-98 6 November 20th, 2008 11:51 AM
camshafts fliptikal 96-98 9 November 19th, 2008 05:55 PM
Best Place For Camshafts Toph6888 V6 Mustangs 16 April 9th, 2008 09:18 AM
Camshafts import party crasher 5.0 Mustangs 1 February 9th, 2007 10:44 AM
Question On Camshafts... acmillr 99-04 13 October 3rd, 2006 03:46 PM
