HIDs
Old December 28th, 2009, 08:21 PM   #1
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
HIDs
Ok so I got this HID kit Standard 9007-3 Bi-Xenon HID Kit - $68.99 : VVME.COM, Car Parts, HID KIT, Tattoo Kit, Ballast, Bulbs I just installed them in my 02 mustang. They work and everything, it is just that when i pull the switch out for my headlights they turn on but the high beam light is on. I try flipping the lever for the high beams, but it does not do nothing, i know that they do not have a high or low beam, but the high beam light just stays on. Is this normal, or did i maybe mix some of the wiring up? or is there anything i can do? thanks.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old December 28th, 2009, 08:24 PM   #2
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
http://www.moddedmustangs.com/forums...low-beams.html
*EDIT* I'm confused, you linked to bi-xenon kit but said they don't have a high or low beam. If they are bi-xenon HIDs then they do have high and low beams. If they are standard HIDs, then they can't be on high beams when you turn them on. Do you have Bi-xenons or regular xenon HIDs?
Old December 28th, 2009, 08:30 PM   #3
Codeman's Avatar
thanks for that. I will try that tom or the next day, and hopefully it works.
Old December 28th, 2009, 09:09 PM   #4
Codeman's Avatar
ok edit* sorry about the confusion, i got confused because i was looking at another site where they were just the regular ones where they are only low beam. I got the kit that I posted the link to, sorry for the misunderstanding. And I really appreciate the link that helps a lot. I will try it tom or wed and hopefully it works.
Old December 28th, 2009, 09:15 PM   #5
Moderator
2003 Grand Cherokee
Yeah, you have high and low beams. That sticky should work. Let us know how it works when you try it.
Old December 28th, 2009, 09:57 PM   #6
99 v6
99redstang is on a distinguished road
if u just bouth low beams it wont work cuz they have to be high and low aka bi xenon
Old December 28th, 2009, 10:40 PM   #7
Codeman's Avatar
I have the bi xenon kit. And the problem is my high beam light is stuck on. I will try the wiring sticky and see how it works. thanks
Old December 29th, 2009, 06:18 AM   #8
Moderator
2003 Grand Cherokee
Check to make sure the servo isn't jammed. If you put a clean rag over the bulb (do NOT touch the bulb w/ you fingers as the oils are bad) you should be able to push it in with little to no resistance. Just make sure you do this w/out any power to the bulb.
Old December 29th, 2009, 11:31 AM   #9
Codeman's Avatar
ok, well i know that i was doing that before i put them in, so unless it got jammed in the couples hours before i put them in. Because i was looking at the kit and instructions at home, then i put on rubber gloves cuz i wanted to look at the bulbs. Then when i put the protector back on each of them i noticed the bulb would move in and out. I will try the wiring first and see hopefully that is it. If not i will post again and let you guys know
Old December 29th, 2009, 01:51 PM   #10
Codeman's Avatar
ok, well i switched the wires around, now when i pull my light switch i have only driving lights. I have to flip the high beams on to make any light come on. I will double check the wiring, but does anyone know what i may have done wrong? thanks
Old December 29th, 2009, 02:02 PM   #11
2003 v6
03stanggg will become famous soon enough
so the lights only work on low beam when you have your "high beams" on? Sounds like a wire issue i would just recheck you wired them correctly... just make sure the wires are snug in the housing below
http://i723.photobucket.com/albums/ww234/wendell1988/sss.jpg
Old December 29th, 2009, 03:55 PM   #12
Moderator
2003 Grand Cherokee
Yes, make sure all plugs are snugged together and plugged into the correct plugs.
Old December 30th, 2009, 01:12 AM   #13
Codeman's Avatar
alright i will check the plugs and all the wires. i just re did them like the article. this is something else, i noticed my headlights when i hit bumps like flicker up and down. Idk if this could be the cause of no low beam? since you were saying about a servo. I dont know much about the hids, but it doesnt seem like they should move around when i hit normal road bumps. Idk well would the servo be a cause of no low beams? cuz they now work correctly except i have no low beam. before when i would turn the lights on by pullin the lever it would automatically go to high beams, now i pull it and driving lights come on and gauges light up, but no headlights, until i flip the blinker switch.
Old December 30th, 2009, 06:19 AM   #14
Moderator
2003 Grand Cherokee
The headlights should be on whenever the headlight knob is pulled all the way out (regardless of the position of the high/low beam switch). It sounds like there's an issue with the wires on the connector to the stock headlights (the one you changed the wires on). Make sure those are all getting connected and seated properly.
Old December 30th, 2009, 04:33 PM   #15
Codeman's Avatar
alright, i will double check them and make sure to push them in all the way. i hope it works.
Old December 30th, 2009, 05:37 PM   #16
Codeman's Avatar
well just got done checking the blue plug in and two wires were not pushed in all the way i should have caught it yesterday. oh well, the headlights work correctly now thanks for all the help.
Old December 30th, 2009, 06:18 PM   #17
Moderator
2003 Grand Cherokee
Good to hear. Hope you like the HIDs
Old December 30th, 2009, 07:14 PM   #18
Codeman's Avatar
I do they are way better, way brighter. thanks again
Threads Similar to: HIDs
HIDs trueblue02GT Audio/Video 50 September 13th, 2009 02:28 AM
HIDs weems The Clubhouse 43 July 14th, 2009 06:33 PM
Hids 2phast 99-04 3 November 20th, 2008 03:16 PM
My new HIDs Zatrekaz Audio/Video 62 June 9th, 2008 11:46 PM
