2000 sixxer, 1988 Fox
Intake gains
found a cheap SSMS lower intake for sale, gonna pick that up,so 3 questions
what would be the gains with just the lower intake what could i be looking at with lower intake and a windstar upper. Then just to throw a wrench in it if anyone has done this does it pick up more after a tune? just exploring my options
#2 | |
436rwhp/378rwtq tuned by HPP www.hppmotorsports.com - www.stangcharger.com - www.rpm-mustangs.com |
it would be best if your gonna do lower to just port the top part of the lower intakes in about a inch or so until you do your heads, otherwise it is kind of defeating the purpose. But I am sure if you plan on doing your heads and you get the lower with the windstart you will see some pretty decent gains.
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
Well yes I do plan on doing h/c/i but I've heard that the lower intake is the most restrictive, so I'm thinking that with the windstar should be pretty decent. The cam will be down the road as this is my dd and it can't be down for more than a day or 2, but back to my original ?, should this give me some pretty good gains? Just the ssms lower? I do plan on either porting the upper or getting the windstar later, but its too good a deal to pass up
YAWN!!! what??
If the price is right. New from SSMS is $450. when you say it's a good deal is it less than half? If so go for it. Tough to tell actual gains but every little bit helps.
yep every little bit adds up. if it is a good deal i would definately buy it you will probably gain a couple hp from it, but then once you put either a windstar, or port your upper it will make a huge difference.
[8MINUS2]
You'll gain a little, but don't expect it to be like "OH S***" or anything.
2003 mustang
7.48x1.56=11.67
You will have to port match the heads or you will create turbulence and possiblly loose power.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
so what youre saying is that i cant use the lower intake without changing out my heads, or at the very least port matching them
yes. You'll need to atleast port match. otherwise you'll have exposed surface that will impead the airflow, causing turbulance.
hmmm, looking to be a little more than i expected... might just pick it up and start stock piling parts
that sounds like a good plan. If it is a good deal, buy it and then save to port your heads. Then you can throw it on with your ported heads and then save and get a new upper. That is why i said if you do not plan on doing your heads for a bit it is best to only port into the top of the lower about an inch or so and make a taper effect. Obviously you can't do that cuz it is already fully ported. Definately get it tho, dont pass up good deals or youll be kickin yourself in the butt.
ya no kidding, what i think im gonna do is get the lower intake, then wait and see if i can get ahold of some ssms heads that someone is sellin, and then send ssms my upper intake mani. still debating on the cam but i guess if im already that deep in i might as well lol
Start off with the windstar upper. And leave the lower for when you do the heads and have them matched at the same time.
I p&p'ed as well as port matched my lower intake manifold and did the windstar upper intake manifold swap, barely noticed anything. Then did a cam swap and still didn't really notice much, but then again its still running stock exhaust and I haven't gotten a tuner yet either. Sure sounds good for a v6 tho.
2000 V6
If you are patient, wait a couple of months. The people who do the Windstar upper are working on a special project right now. It combines the current windstar upper package with the newer windstar lower. Its supposed to give even better results than port and polishing
^that should be interesting! Can't wait to get some more details on this.
that sounds sweet if the windstar upper and lower. does anyone have a more specific amount of time when they think it will be ready
#19 | |
2000 Mustang
14.10@96.75
The lower is not that bad, but can be improved
2000 V6 vert 2003 Lightning |
Threads Similar to: Intake gains
| accufab 75mm throttle body and intake plenium...gains? | turbot4 | 99-04 | 35 | March 9th, 2009 07:39 AM |
| gains? | SantanielloITA | V6 Mustangs | 5 | November 6th, 2007 12:08 AM |
| lower intake gains | 02ponypackage | V6 Mustangs | 67 | September 12th, 2007 07:31 PM |
| Windstar intake gains? | Orangester | V6 Mustangs | 33 | August 28th, 2007 10:20 PM |
| what kind of power gains froma bullit intake manifold | sonicblue | Modular Mustangs | 4 | August 6th, 2007 11:35 AM |
