How much weight should I put in the trunk? - Forums at Modded Mustangs
post #1 of 15 Old December 31st, 2009, 12:54 PM Thread Starter
00mustangv6's Avatar
We just got a light dusting and it was wet and slippery I couldnt even go a block before getting stuck and sliding slideways.
How much weight should I put in the truck and would it help me drive it and not get stuck..I had to call out of work again..
00mustangv6 is offline
post #2 of 15 Old December 31st, 2009, 12:57 PM
Priest of the Car Gods
ReverendDexter's Avatar
Sounds like you need the driver mod, man. Just keep your foot out of it and don't make quick motions. Smooth on the gas, smooth on the brakes (avoid using them at all if you can), and smooth on the steering. A "light dusting" shouldn't have you parked.
Function > Form, always
ReverendDexter is offline
post #3 of 15 Old December 31st, 2009, 01:27 PM
Here in wisconsin you can just buy big bags of sand to throw in the trunk--- that being said usually for a car 200-300 lbs in the trunk of the stang will make you grip better.
Or lure some children in to the trunk with candy to weigh it down.
But the way you drive determines everything! plan ahead while driving in the soup.
Eaton SC 6psi, 4.10 gears, PI cams, CAI, 70TB, OR-H, Bilstien struts/shocks, B springs, MM C/C, B&M trans cooler, 10th anny cobra brakes
jhills2 is offline
post #4 of 15 Old December 31st, 2009, 01:46 PM
just take it easy on the gas....but some junk in the truck won't hurt either
6ER THEN I 8ER! is offline
post #5 of 15 Old December 31st, 2009, 02:02 PM
MM's Resident Ricer
GreenFaleen's Avatar
dont put more than the weight of your engine or youll have trouble steering correctly
150-200 will be plenty if evenly spread out
NCMM #9
GreenFaleen is offline
post #6 of 15 Old December 31st, 2009, 06:56 PM
02GreyStallion's Avatar
Ya I know how you feel man. I have 160 pounds of salt and it seems to help but light driving is the only way to go
I almost put mine in a ditch yesterday....... after that i take it extremely slow
02GreyStallion is offline
post #7 of 15 Old December 31st, 2009, 07:25 PM
Not A Regular Member
I've got 210lbs (3 x 70lb bags) plus the spare tire on my trunk. Even with that I was doing donuts very very easily in the parking lot at work earlier. Putting weight in the trunk is a good idea but it's even better to be light on the gas and if you're having too much trouble from 1st, try taking off in 2nd. It's not so great on the transmission but it puts a lot less power at the wheels.
McQueen is offline
post #8 of 15 Old January 2nd, 2010, 01:58 PM
Very True ^^^
post #9 of 15 Old January 2nd, 2010, 02:17 PM
Tree Fiddy Z
Breakout's Avatar
Send a message via AIM to Breakout
a dead hooker should be sufficient
Breakout is offline
post #10 of 15 Old January 2nd, 2010, 02:32 PM
D-Brow's Avatar
Send a message via AIM to D-Brow
I just use 4 bags of 50lb. rock salt. Lay them out evenly in the trunk...other than that it comes down to the diver. It's a lot different driving a sports car in the snow than something with 4wd...completely different strategy. Gotta get your speed up before hitting hills and slow way down and of course tap the breaks going down em. Keep the car as straight as possible at all times to avoid spinning and slipping and as soon as u do immediately let off the gas and counter-steer then get right back on the gas lol. Just takes practice...I've already driven to and from work this year with at least 2 inches on the road at least 3 times and i live in a very hilly bad road area. Only got stuck once where i had to be pulled out by chain haha.
Mods
Cold Air Intake, True Dual Flowmaster Exhaust
1/8 = 10.78
1/4 = 16.47
D-Brow is offline
post #11 of 15 Old January 2nd, 2010, 02:32 PM
D-Brow's Avatar
Oh, and dead hookers are always a good substitute if u dont have any rock salt or sand
Mods
1/8 = 10.78
1/4 = 16.47
D-Brow is offline
post #12 of 15 Old January 3rd, 2010, 04:07 AM
Ticket-Me-Yellow's Avatar
Send a message via AIM to Ticket-Me-Yellow
i went on craigslist found snow tires and rims for 300 bucks. Put three bags of 70lb tube sand and put that over the axles.
If you want traction then yes pussy foot it. Be easy and gental. Now me? hahahahaha i love drifting the stang in the winter. So much fun!
Selling Mustang So Im
Selling All M112 Parts
Ticket-Me-Yellow is offline
post #13 of 15 Old January 3rd, 2010, 04:23 AM
Wax on, Wax off
Zatrekaz's Avatar
iTrader: 17 reviews
Sooo glad I live in the south......
Although my summer tires do not like 25 degrees.
2013 Hyundai Genesis Coupe 2.0T
2006 Lexus 250 IS - Sold
2003 Mustang V6 - Sold
Zatrekaz is offline
post #14 of 15 Old January 3rd, 2010, 04:40 AM
my summer tires are still on too! one problem........
no engine
post #15 of 15 Old January 3rd, 2010, 12:55 PM
slvr2000stang's Avatar
no engine
Summer tires? Ouch.
Winter tires are the way to go. I do it on both the Lightning & the Mustang
2000 V6 vert
2003 Lightning
slvr2000stang is offline
Human Verification
