99 v6 cam/intakes
Hey, I've gone through all of the pages of topics here, and some topics have come up that help, and yet, they still don't help me. I am interested in a cam, and possibly ported intakes... maybe cylinders later down the road when I can afford it. Would anyone reccomend a cam? Should I just get the cam or should I get other stuff with it? what all do I need if I get a cam(only) or if I only get the ported intakes?
After install, will I need to reprogram my computer or anything? -99 v6 32k miles -dual flowmaster exhaust -4.10 gears w/tlok |
MM's Resident Ricer
2006 Scion tC
13.001@113
I wouldn't worry with internals till you got full bolt ons. Go with a tuner some ud pulleys, a CAI then more up to the heavier stuff.
well I was told I could get some hp out of a cam and/or intakes. besides, I can't afford an s/c or t/c
#4 | |
by the way with the 4.10s you should recalibrate your speedometer
I don't drive fast. I fly slow.
which tuner do you reccomend?
#6 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
def the x-cal 2
#8 | |
well, I have the 1996-2007 Mustang Granatelli Fuego Tuner... I was told it was better than the xcal2... it adds 20-35rwhp(so they say)
well, I didn't plan on going by thier claims, but, I have nothing else to go by. around here, there's only one place to get a dyno and they charge more than I could afford. so, it's obviously not going to happen anytime soon. any reccomendations on a cheap s/c or anything?
#12 | ||
MM's Resident Ricer
2006 Scion tC
13.001@113
common cam size for 3.8 is a stock 4.2 cam
common cam for 4.2 is a 207/215 .495 lift cam cam i have for the F150 4.2 207/215 and i have ported heads and intake with a windstar upper with rollar rockers, makes good power I have a 218/222 cam with .570 lift sitting on my desk needing a new home, this is a large cam for my motor and IMO a little over kill on a stock head 3.8 Get a tune after the cam install it helps however i ran my truck with no tune for 6 months with out a tune on the 207 cam
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports. |
and with the cam change the springs to with it and maybe the rockers as well to work with the cam...if not still do the springs because it will benefit the cam plus you may have to regardless...guys at Sniper said the Springs will have to be changed in a mild or high cam....along with a tune to really bring it out and is better for the car running daily....rockers go with what ever fits best with the size cam.... Redlined Mustangs, Tom Morona Racing, and Super Six motorsports have nice V6 Cams, rockers, and springs along with other stuff but if u wanted a Custom Crane Cam or Comp i dont know if they make a V6 cam for the 99-04 but they can do custom ones will be more expensive tho
just a V6 with a bad belt slip under the hood |
Yes springs are a must when you do any cam, and also you need to check your pushrod length as well or you can end up with a disaster.
after talking with my mechanic he said firming shift pressures with the xcal 2 is the same as a shift kit so i dont know if i will be getting a shift kit or not i still may just to beef up the tranny.
and make sure along with the push rod and if rockers the Valve cover clearance is ok
i'm running stock covers with 1.73 harland sharp rollar rockers and don't have any problems
and I heard 1.8 can clear stock covers as well...I didnt know if theres any bigger to put on or something that can big to big....just reading the caption for the rockers it says clears stock valve covers...just though I mention it
i heard its better to make the lift up with the cam and keep the 1.73 ratio it keeps the geometry better.
Threads Similar to: 99 v6 cam/intakes
| intakes | mmvi | V6 Mustangs | 3 | September 23rd, 2007 01:15 PM |
| Intakes | boss302_gt | 94-95 | 18 | April 18th, 2007 10:06 PM |
| Air intakes? | spero | 99-04 | 15 | April 6th, 2007 02:44 PM |
| Intakes? | 86gt5liter | 5.0 Mustangs | 22 | February 28th, 2007 09:10 PM |
| Intakes | bittydrew | 99-04 | 2 | January 1st, 2007 07:00 PM |
