Pinging or knocking noise while driving? - Forums at Modded Mustangs
post #1 of 15 Old January 10th, 2010, 11:33 PM Thread Starter
00mustangv6's Avatar
When I speed up at like 40+ mph I hear like a weird pinging noise comming from the engine? Would seafoam help this?
00mustangv6 is offline
post #2 of 15 Old January 10th, 2010, 11:35 PM
BadBlackGT's Avatar
Have you recently tuned your car or anything to advance the spark of your car?
If its got titts or tires, it's gonna give you problems.
Originally Posted by navyman8903 View Post
He has a 500rwhp 1990 5.0L with a cam who's lope takes virginity.
Originally Posted by Towelly View Post
Go find some Chill biscuits, dip them in some Calm the Fuck down sauce and chill the fuck out.
BadBlackGT is offline
post #3 of 15 Old January 10th, 2010, 11:52 PM
JTs03v6's Avatar
What rpm?? It does sound like spark knock. Try some seafoam in the break booster and run some high test through it.
Turbo 4.3 stroker, 6.73 @ 106mph...still tuning
http://moddedmustangs.com/forums/v6-...ker-build.html
JTs03v6 is offline
post #4 of 15 Old January 11th, 2010, 08:11 AM Thread Starter
My performance mods are just a CAI and shorty headers with dual exhuast.
When Im near 2500-3000 rpm around that range, sometimes less.
So its a spark knock? Should I replace the plugs?
My jeep makes the same exact noise when driving too
post #5 of 15 Old January 11th, 2010, 09:04 AM
MM's Resident Ricer
GreenFaleen's Avatar
is it a ping or a knock big difference there
NCMM #9
GreenFaleen is offline
post #6 of 15 Old January 11th, 2010, 01:56 PM Thread Starter
i would say its a ping. you have to listen closely its not that loud and it doesnt happen all the time. anywhere from the 2-3 rpm range
post #7 of 15 Old January 12th, 2010, 12:10 AM
02GreyStallion's Avatar
why are you running that high of rpms at 40 mphs
02GreyStallion is offline
post #8 of 15 Old January 12th, 2010, 10:06 AM
It's likely caused by carbon build up in the back cylinders (3 and 6) due to oil from the PCV system. This is a well documented problem on 99-00 Mustangs. I was told by a Ford parts person that they have a decarbonizing fluid that can be used like sea foam or try sea foam to get rid of the carbon.
stephen is offline
post #9 of 15 Old January 13th, 2010, 01:57 PM Thread Starter
Would it be ok to Seafoam the car? it has almost 101K on it. I just changed the oil over the weekend so I cant do it now?
post #10 of 15 Old January 13th, 2010, 02:00 PM
Catfiesh's Avatar
yea.. sea foam may help.. it will kill that monkey with the hammer..
MM Cobra Club #48
Mineral Gray Club Member #12
Im what you would call a "bad influence".
Catfiesh is offline
post #11 of 15 Old January 13th, 2010, 06:25 PM
It would be OK to run sea foam into the intake through the PCV hose. This could help to loosen up carbon in the combustion chambers.
Don't add it to the oil since it is new.
stephen is offline
post #12 of 15 Old January 14th, 2010, 08:10 AM Thread Starter
What about running it in the gas tank and the pcv hose?
would it make it run better and cleaner?
post #13 of 15 Old January 14th, 2010, 09:44 AM
I have 130 thousand miles i think you'll be okay. I wouldnt put it in the oil though. I did it and it ate my oil seals I dont know why, and it made the oil leak out main and etc. I was told by a mechanic after you put that junk in your oil and change it some of it is still in there and will be for a little while, not sure if thats true though, all i know is that seafoam eats through stuff.
I would suggest putting it through the hose, and fuel tank.
Stang187 is offline
post #14 of 15 Old January 14th, 2010, 02:30 PM
For the pinging what is needed is to run the sea foam through the intake via the PCV hose. That should help get carbon out of the combustion chambers. No need to add it to the oil or fuel. To clean the injectors I would recommend techron or an after market injector cleaner.
stephen is offline
post #15 of 15 Old January 15th, 2010, 05:15 PM
Look Ma! My First Post!
Your problem sounds like engine knock. You might have bad gas. Drive your car till fuel light comes on and fill your car with high octain premium gas.
blared is offline
Human Verification
