2002 Nitrous Injected V6
12's?
H, X or Y
So im going to be getting dual exhuasts soon and most likely getting an exhuast shop to do the work. My question is which is the best to get and is it worth it for the money. Stick with a Y pipe or go H or X. Ive been hearing X is more import like and H is more muscle with not much a proformance differnce from each other, but a big step from the Y pipe. Im looking for proformance, loudness and deepness all be considered.
So should I: 1. Get the Y pipe, 2. Get an H pipe, 3. Get an X pipe, 4. Have the shop fab one of these?
![]() Project Red Magic -Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped- -18 Inch Hypercoated Saleens wrapped in Nittos- |
MM's Official Lucifer
Cheapest route is to have shop fab one up. However many shops will not fab or install o/r midpipes, meaning without cats. So either find one that will, or you'll have to purchase one of your choice elsewhere. NO NO NO on the Y pipe, you'll def. want to replace it. From here it's really a matter of personal taste. As you have obviously seen elsewhere, h-pipes are more rumbly, "muscle" sound, while the x tends to get raspy on these cars in mid to high rpm range. Personally I am getting a MAC Prochamber ... best of both worlds. I would search Youtube, and here, for exhaust vids. You can get a rough idea of what some set-ups sound like from that. Hearing them in person is worlds different, so try to find some local modded sixxers. Also keep in mind that mufflers have as much to do with the sound as the midpipe. You'll hear Flowmaster 40 series and Thrush Welds. The battle over those 2 choices is yet to be won. For the rest of the piping, as well as tips, the cheapest (price wise, not necessarily quality) is having a shop just fab that up. And don't forget your long tube headers, which will require a mid pipe made for long tubes. You can find these for sale or again the shop would just fab one.
^ +1
White 2000 V6 Mustang|Black Saleens 18x9|Flowmaster 40s|AM CAI|8000K HIDs|SCT XCAL III/H&R SS
12's?
if i get x pipes, and h pipes I think i still need cats to be emmisions okay in PA
#5 | |
2003 v6
![]() iTrader: 2 reviews
Not sure what other areas dont have it though...
12's?
chester, im preety sure there nazi's
muneris pro ego
if you have emissions then you will need a catted h or x pipe, with the h recommended.
and goren420 you know the Prochamber will not bolt up to a v6 exhaust right? you will have to have it custom fabbed
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() Last edited by Ninjawafers!; January 12th, 2010 at 04:41 PM. |
That was me that said that and yeah I'm aware, it'll be a custom set-up.
#9 | |
muneris pro ego
![]() my set-up (hopefully coming late february or early march) will consist of MAC LT's with a Prochamber with Thrush Welded mufflers... and ill have it running out of my 4 inch Gibson tips
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
#10 | |
99 v6
muneris pro ego
having a shop fab up a kit will, more times than not, be cheaper than buying a pre-made kit
I know I read somewhere that x pipes were better for higher rpms because they even out the exhaust flow better at the higher rpms then an h pipe, which makes sense in theory, so I've been planning on going with something with an x pipe...any additional thoughts on this anyone?
![]() My 'Stang |
#13 | |
muneris pro ego
as for our sixxers that is not true and it will add a raspy sound to our already rapsy sounding exhaust, especially in the upper rpms
Oh, ok, thanks for the info...my vote is for H pipe now lol
![]() My 'Stang |
muneris pro ego
thats what im here for
#16 | |
12's?
Correct on the first part. Midpipes do nothing in terms of performance on our cars due to the firing order. Stick with divorced duals, a y-pipe will be a bottleneck in terms of flow.
agreed, ^ You will not really gain any performance from your exhasut, it may feel a little increase in response, but it is mostly for sound. The best sound on our sixers is to run either divorced duals, or an h pipe. I would compare prices, and call a couple exhaust shops and ask for a quote. As far as sounds you like for mufflers, type in v6 mustang exhaust on google video or youtube and listen to the different setups, since it is your car and your opinion.
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
12's?
since it looks divorced duals or an h pipe are the best, it looks as tho exhuast might be cheaper then I first though. Im going to go scope out devroced duals since it might be cheaper and better =]. Think an exhuast shop can do devorced duals after the cats with 2.5 pipes fairly easy and inexspensive? Of corse im going to need sparklyass tips!
#20 | |
2004 Mustang V6
Not Tested
2004 Blue V6 -True Dual Exhaust [Straight Pipes to two Flowmaster Original 40's] -MAC Cold Air Intake |
