Estimated price on head gasket? - Page 2
LinkBack (1) Thread Tools
Old January 14th, 2010, 07:14 PM   #21
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Originally Posted by 99 BLUE V6 View Post
JOHNSON / So with all those stickys you wrote. Surely this is a job your going to tackle your self right. I don't think your lacking in the knowlage department. Seems a little odd your even asking.
Hey, I wrote the look here before asking about mods sticky, he just stole it and posted it, instead of stickied my thread. *cough*
Originally Posted by stephen View Post
Perhaps I misunderstood what you were saying. It seemed you were saying only the Ford head gaskets are MLS. Actually victor first developed the MLS gasket. Before that Ford had major problems with aluminum heads on steel blocks. Anyway the two major gasket manufacturers are victor and federal-mogul (felpro). It's likely one of these makes Ford's head gaskets.
Well no, I was saying fel-pro from what I've seen tend to come apart.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old January 15th, 2010, 08:54 PM   #22
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
Originally Posted by ESG-642T View Post
Hey, I wrote the original look here before asking about mods sticky, he posted it, and has added more over time from his own research and others research. *cough*
i made that a little more true for ya
SCT Mass Air Flow Sensor $200
Old January 15th, 2010, 09:23 PM   #23
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Adding links doesn't make you much more responsible for it woody sorry. Get your hg issue fixed, and don't pay anybody to do it K?
Old January 15th, 2010, 10:16 PM   #24
Matt.'s Avatar
2002 Nitrous Injected V6
12's?
Matt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the rough
any luck with the gasket?
Project Red Magic
-Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped-
-18 Inch Hypercoated Saleens wrapped in Nittos-
Old January 16th, 2010, 02:05 AM   #25
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
havent ran any tests yet.
Old January 18th, 2010, 03:31 PM   #26
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
ok did some work on it yesterday. ran compression test and that was fine along with the plugs being fine. emptied the catch can which had a little bit of water in it and changed the filter on that since the old one was nasty looking. pulled out the air filter and cleaned that up. checked the oil...it was about a half a quart low. coolant was low in the reservoir. added coolant and oil. drove back to my apartment 80-100 miles away. so after classes are done today i am going to run down to autozone and see if i can rent a coolant system pressure tester and check that later on after everything cools down along with checking the oil and coolant levels. then ill see what i have from there.
Old January 18th, 2010, 06:51 PM   #27
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
Thats good it had good compression. But the water in the catch can doesnt make sence. Maybe check the lower intake.
I forgot to mention there is a test you can run that will find exhaust gases in the coolant. It's a purple fluid...I forget the name of the test though.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old January 18th, 2010, 07:37 PM   #28
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
the water in the catch can is normal IMO. condensation from those little filters happens, especially since my car sits outside in the cold. im gonna run that pressure test on the coolant system which should really tell me for sure if and where the coolant is leaking.
Old January 19th, 2010, 12:10 AM   #29
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
wow just checked the coolant level in the reservoir about 20 minutes ago....its almost empty. definitely a coolant leak somewhere inside...now to find out if it is the lower intake or the head gasket.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/149582-estimated-price-head-gasket.html
Estimated price on head gasket? This thread Refback March 6th, 2011 02:44 PM
Threads Similar to: Estimated price on head gasket?
Head gasket. JBIGBOOTSY 5.0 Mustangs 30 May 14th, 2009 02:40 AM
intake manifold gasket or head gasket? rasalibre 5.0 Mustangs 5 November 26th, 2008 05:37 PM
Head gasket? Elder 4V / SVT 14 June 22nd, 2008 12:33 AM
head gasket paulesparza94 94-95 0 January 24th, 2008 02:26 PM
head gasket cali 5.0 5.0 Mustangs 3 June 20th, 2006 03:33 PM
