Dyno Tune?
Ok I'm tired of thinking about it. What is a dyno tune. Can you get a dyno tune from ANYONE who has a Dyno, by dyno i mean the thing you run your car on to see your HP/TQ. I'm not understanding... Is the dyno tune something different than the X-Cal, or are they the same thing... just a tuner or something...
what i mean by this last question is, which is better. if i get a x-cal, will i still need a dyno tune, or if i get a dno tune, will i still need an x-cal? or are they both just tunes, and the dyno tune is just better than the x-cal, and the x-cal is just cheaper... pleaseeeee fill me in.
Red '98 Mustang. Custom Dual Exhaust w/ fabbed X pipe. CAI. 17in Black Rims w/ Aluminum Lip. Alpine Head Unit and Type-S speakers in doors and decklid. 600w Bridged BOSS amp to two 12" Audio Bahn Blue Flame Series Subs. |
can you rephrase
can you have a x-cal2 and then have a dyno tune and they work together, or is it one or the other. because it says it only added 8rwph for my year 3.8.
justin, the best way to get a tune is this. Buy an Xcal2 or a livewire. They come preloaded with 3 tunes as it is. It just messes with all the "computer" internals to make your car perform better. like air/fuel ratios, etc.
and for an extra 125 dollars you can get the digital readout of your a/f ratios and screw with it yourself to what you want. the only point to a dyno is to measure your hp after they are done and before they start.
ah ok thanks... how much hp can i really expect from a x-cal2... i wish i could just borrow one from someone and use one of their tunes and i pay them 15 dolla (cross fingers for some love lol).
ill let you borrow mine for 50. ur paying for shipping both ways though.
MM's Resident Ricer
2006 Scion tC
13.001@113
they aren't car interchangeable
well i guess that plans out. lol. why arent they though?when you pull it off does the tune go back to stock?
#11 | |
In addition, when you tune a car the VIN is locked into the tuner until the car is returned to stock. In response to the original question, an XCal is typically enough for most cars. A dyno tune will help to extract every bit of performance that is available from your car. The XCal is general and the dyno tune is specific if that helps. |
so is the dyno tune or the x-cal give you the most performance... for my year it said the vmptuning dyno tune only gave it 8 hp
Zoolander
04 Cobra #2260/3768 1/820
the x-cal is what gives you the hp. the dyno just shows everything to make it easier, instead of guessing. One doesnt do more than the other. The X-cal does the actual tuning, the dyno just shows the numbers, and the tuners work with that.
when do u need dyno tunes?
technically you could do it stock. Best to do it after you free up about 40-50 horsepower though. you notice a bigger difference.
Zoolander
usually when you have a car with forced induction and your just gettin it setup. Thats usually. you can also get it for a n/a car or nitrous car and you want to squeeze all the hp out of it. Usually good when you have your setup the way you want it, and you just want to finish it off.
Sniper Tuning has a programmer that would put out better numbers then the Xcal2 and works on almost every ford application 96-05+ and the best part is it can be used on 2 different cars not just locked to 1...
just a V6 with a bad belt slip under the hood |
theres nothing like getting ur car tuned on a dyno and not just flashed.....because only then can u see more potential with the car...tho some people are better then others thats the best way to get results...i wouldnt bother getting on a dyno with no tuning....u dont need a dyno if you just flash it was a hand held for the most part.....just save up and get a Dyno tune
yeah, iv never even had a Dyno done. Where do you get them done?
Zoolander
performance shops. Usually good to get one done right after you have some form of forced induction put on, if you go with nitrous, or after your setup is done the way you want it to be.
Threads Similar to: Dyno Tune?
| Dyno Tune | Dawgfude03GT | Modular Mustangs | 3 | October 31st, 2007 06:33 PM |
| dyno tune | kennyGT | 96-98 | 2 | August 7th, 2007 09:21 PM |
| dyno tune & flash tune | miafan | 2005 - 2010 | 4 | May 31st, 2007 05:05 AM |
| Dyno tune ??? | 2000Mustang | Midwest | 0 | March 13th, 2007 06:38 PM |
| do i need a dyno-tune? | cdunc24 | 5.0 Mustangs | 3 | February 3rd, 2007 10:13 AM |
