gears and tlok finally - Page 2
Old February 1st, 2010, 08:57 AM   #21
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Good deal, always a plus when you get it done yourself. Sometimes those problems are nice to have, so you can get extra points for problem solving skills.
Old February 1st, 2010, 12:36 PM   #22
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
Before the adjustment I had about .020 backlash. I figured out why it was off, because of where on the teeth i placed my dial indicator. It threw it off. It is right now, i checked it like 15 times lol and in all different places, it is .010 now. And I actually am glad that I made some mistakes, because i will remeber the mistakes that I have made, and not do them again. You learn better from the mistakes you make, then doing it right im just glad it did not mess anything up
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old February 2nd, 2010, 09:53 PM   #23
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
Good. I'm glad the gears are ok.
I think something is wrong with mine. It sounds like a lot of bearing noise at high speeds. I'll have to check it out next time I'm on a lift though. Glad yours turned out good!
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Old February 2nd, 2010, 10:46 PM   #24
Codeman's Avatar
Ya, they are pretty tricky. I did not think that the gears were so particular, but they are. You have to have them just perfect for them to sound and work correctly. It is kind of crazy actually. Well I hope that yours turn out and you fix the problem. My car also did not seem to have much side bearing preload, so I added a little more.
Threads Similar to: gears and tlok finally
Installation of tlok and gears Matt. V6 Mustangs 10 November 13th, 2009 03:46 PM
Tlok and gears Toph6888 V6 Mustangs 46 February 6th, 2008 09:16 PM
Gears and Tlok? Wilson00V6 V6 Mustangs 17 January 9th, 2007 03:21 PM
98 3.8L Auto gears and tlok NDGreen07 V6 Mustangs 19 August 4th, 2006 10:09 PM
