3.8L engine vibration
Hopefully, someone can help me figure this out.
My engine vibrates, it always has for the last 120k miles. I've had the car since 30k. It is only engine vibration. I have triple checked everything else and it happens whether i rev the engine, drive...no matter. The vibration is coupled to the engine speed. My car was built on June 7, 2000. It has a BA in the suffix of the engine code meaning that the engine has a 2001 shortblock. (According to Ford) Questions: 1) Are 2001+ 3.8's internally or externally balanced? Tom Morana says that all 3.8's are externally balanced but i've heard conflicting stories that 2000 engines are ext balanced and 2001 are int balanced. 2) Anyone else have this problem on a 2000 mustang? 3) Anyone heard stories of the wrong flexplate and harmonic balancer being installed from the factory. e.g.; if my engine is internally balanced after all, would/could ford have put on the wrong balancer and flexplate and should I switch them to 2001 parts. 4) ANY other clues toward a solution to this vibration. Thanks in advance. -Zach
Safud: MM's Resident Hadji
Could be worn out motor mounts
#3 | |
+1 on the motor mounts
Already checked the motor mounts and tranny mount. They were fine, both in good shape, but I replaced them anyway about 15k miles ago. The vibration didn't change at all.
I've also done a compression test and all cyl's are within a few percent of each other. A tad lower than spec but that's to be expected on a motor with 150k on it. -Zach
2002 Nitrous Injected V6
12's?
mine vibrate a little more then ushally at 65-75 mph but not anything bad, but not that big of a problum. From 10-70ish and 80-120 Its perfect. Also noticed the same for my brother's S4. Could also be your brakes if it shakes alot when you aply them at higher speeds.
![]() Project Red Magic -Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped- -18 Inch Hypercoated Saleens wrapped in Nittos- |
I've checked. The brakes are new. I checked the runout on the hub and rotors to cancel out tolerance stacking just for that reason.
The car has IRS. The pinion angles have been set. The runout on the pinion flange and pinion yoke were checked and the driveshaft was balanced and indexed. The wheels were balanced and all suspension rubber in the front is new. Aside from the IRS subframe bushings, there is no rubber left in the rear, only aluminum and Delrin. Every source of vibration that could arise from the drivetrain was checked and checked again, documented and then fixed. The only vibration left in the car is the engine. I'm almost to the point where I am going to drop the pan and see if the crank is fully bobweighted. If it is, then my shortblock is internally balanced and has the wrong HB and flexplate. I'm probably going to do that regardless unless someone knows for certain that there are some mismatched engines out there in the 2000 mustangs. I only have to make the motor last for about 6 more months and then it's replacement will be ready. But until then I have to drive it every day. Given that I have tracked down every other vibration in the car, it just makes the engine vibe that much more annoying. -Zach
2000 V6 Conv Stock motor Modded IRS, brakes |
#7 | |
99 V6 BASE
NEVER RACED THIS ONE
If you find out PLEASE let me know my 99 does the same thing around 1000 to 1500 rpms and it drives me nuts i cant figure it out
#9 | |
i found a forum with a guy that had this same issues replacing everything but the HB and that turned out to be his issue. even if it has not turned or moved or changed in anyway it can be too far gone? what you guys think? |
2000 Mustang 3.8
ehh w/e the mostly stock time is
My car vibrates all of the time. but then again my exhaust is welded to the chassis with no rubber in between
anyway, i would check the balancer and if you have a manual get the flywheel resurfaced.
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
#11 | |
I was starting to doubt the beast 3.8 but now all i can do is hope that i find a new motorcraft belt. Now i have no doubt this mustang will see 300K or more miles on this original motor. |
Skar Gone
1998 Mustang V6
17.27@76.66
35Mpg? What do you do, 10MPH everywhere? ._.;
![]() 1998 5 Speed, CAI, Exhaust, Rear Seat Delete. |
2001 Mustang V6
Stock (01 V6 Auto)
I have the same issue, I wouldn't call it a problem.
I have an 01 V6 with 113,000 miles. Under 60mph, no shaking. Accelerating from 60 to 70, shaking Driving at 70, no shaking Accelerating from 70 to 80, not sure... Driving at 80, no shaking Accelerating from 80 to 90, no shaking Driving at 90, no shaking. That's my experience, may not be exact, it's been a while since I went on the highway in my Mustang. It's not a big deal to me. I thought it was something in the AC that was loose or shaking, because it sounded like it was coming from really, really close to me, like closer than the engine is.
Threads Similar to: 3.8L engine vibration
| Engine vibration at certain rpm | wolverine8490 | 96-98 | 10 | May 26th, 2011 05:34 PM |
| vibration | grnstang | 5.0 Mustangs | 0 | April 12th, 2009 11:25 PM |
| What causes engine vibration? | fatoeknee | 5.0 Mustangs | 18 | March 4th, 2009 12:31 PM |
| Vibration above 3k | alabamastanger | 5.0 Mustangs | 11 | May 29th, 2008 07:01 PM |
| vibration | cali 5.0 | General Tech | 2 | May 31st, 2006 05:09 PM |
