Suspension mods
Old January 18th, 2010, 05:05 PM   #1
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
Suspension mods
Ok so I just put some new gears and a tlok in. I am curious about what suspension mods to get this spring. I already plan on buying subframe connectors. I am looking for a decent ride since I drive it daily and I want to make it mostly for drag racing. I am looking at getting lower control arms, and if I do should I get uppers? or do they not make that big of a difference. Im also looking at getting eibach drag shocks. Would these be a pretty good start as far as my suspension goes?
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old January 18th, 2010, 05:23 PM   #2
ZachsV6 is on a distinguished road
I don't think anyone believes the IRS was ever meant for drag racing because of wheel hop. However, i put one in my car, replaced all the rubber bushings with Delrin and aluminum, put Bilsteins on it and even with POS Goodyear GS tires that are KNOWN to hop on any car, i don't get any perceptable hop. Plus I got the benefit of the 8.8 rear.
I drive my car every day and for that reason I put in the IRS. It rides like no other and even with the rigid bushings I haven't noticed an increase in NVH. I still have the rubber subfame bushings and that would be why.
I spent about $2k putting it in my car including all the bushings and bearings I replaced.
I'd drop the SRA for the IRS any day unless you were making a dedicated, "trailer it to events" dragster. Spend the SRA money on a used IRS and then put the right bushings in it, you'll pwn.
-Zach
2000 V6 Conv
Stock motor
Modded IRS, brakes
Old January 19th, 2010, 01:51 PM   #3
Codeman's Avatar
ok, but i dont want to go irs, i just rebuilt everything in my rear axle. and plus, i would rather spend the 2k elsewhere. so as far as control arms go, should i get bother uppers and lowers?
also would it be a decent setup if i had new control arms, subframe connectors, and eibach drag springs?
Old January 19th, 2010, 08:20 PM   #4
Subframe connectors are a must in any performance mustang. Always. Full Length, make them a priority.
Control arms. There are some good ones out there that free up weight and allow you adjust pinion angle, things like that. It never hurts to upgrade but I dunno if I'd make it a priority just yet.
Drag springs, any of them, are funky to drive on every day, weirder if you get the matching shocks. They are hellacious when launching tho and can really let your car hook up.
2000 V6 Conv
Stock motor
Modded IRS, brakes
Old January 19th, 2010, 08:33 PM   #5
Codeman's Avatar
alright. well what would be the best option to go for a dd street strip stang? you seem to know a lot in the suspension area and i would like your input.
Old January 19th, 2010, 09:51 PM   #6
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
If you are setting it up for the street/strip than eibachs drag springs are the way to go. Just make sure that you have a good drag radial out back and you will hook pretty decent.
Your biggest thing is going to be the auto. You need to get a stall to get you out the hole quicker.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old January 19th, 2010, 10:49 PM   #7
Codeman's Avatar
I have a 5spd so I wont need the converter. And do the drag springs ride close to stock? or are they dramatically different?
Threads Similar to: Suspension mods
best suspension mods for DD mustang_jim85 V6 Mustangs 16 November 8th, 2008 12:21 AM
Suspension Mods? 01brknGT 99-04 1 May 25th, 2008 11:50 AM
suspension mods. 01dutchGT Classic Mustangs 6 March 12th, 2008 03:39 PM
My Suspension Mods!!! slvrbllt98GT 96-98 9 May 13th, 2007 10:07 PM
Suspension mods fogged306 5.0 Mustangs 6 April 19th, 2007 08:54 AM
