Odd sound
Old January 19th, 2010, 10:08 AM   #1
Wataru's Avatar
2000 Mustang V6
Wataru will become famous soon enough
Send a message via AIM to Wataru Send a message via Yahoo to Wataru
Odd sound
Havent posted in awhile but I figure this is probably the best place to ask...
On occassion and it's not everytime, when Im driving, sometimes right before I accelerate and right before I stop, the car will "clunk". It sounds like when you have too much stuff in the back of your car and it all rolls forward to hit the trunk walls.
I noticed it was worse when we had 20-40 degrees here.
Old January 19th, 2010, 03:13 PM   #2
mattf0509's Avatar
2000 3.8L v6
when i finished track was closed
mattf0509 is on a distinguished road
Sticky lifter, bent rod, drivetrain...possibly a motor mount it was kinda a vague description
Old January 19th, 2010, 04:07 PM   #3
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Sticky lifter would give more of a flutter, exhaust leak type sound upon acceleration. Possibly something suspension wise, and motor mount possible... but yeah kinda vague, more of an area of the car, or a better description of when it occurs.
Old January 19th, 2010, 07:22 PM   #4
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
Mine does the same thing but it's because my rear control arm bushings are worn out.
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Old January 19th, 2010, 07:50 PM   #5
lcorriveau3's Avatar
1999
YAWN!!! what??
lcorriveau3 has a spectacular aura aboutlcorriveau3 has a spectacular aura aboutlcorriveau3 has a spectacular aura about
WHat about the bodies in the trunk, they could be shifting!!
Actually is it a clunking from the rear end? Sounds like you could have a bearing going in the rear diff.
Old January 20th, 2010, 09:57 AM   #6
Wataru's Avatar
2000 Mustang V6
its a clunk from the rear. Best example would be if you had a car with a non-secured spare tire in the trunk and when you stopped or kicked off fast when accelerating, it would roll around and hit the trunk walls.
Old January 20th, 2010, 10:07 AM   #7
mattf0509's Avatar
2000 3.8L v6
Have you checked the spare? Lol
Old January 20th, 2010, 10:11 AM   #8
goren813's Avatar
'00 3.8L & '05 4.6L
+1
And after that, check out your spring isos, and all the bushings in the rear suspension, as well as the rear brakes. And make sure your gas tank isn't able to move around...
Old January 20th, 2010, 10:23 AM   #9
Wataru's Avatar
2000 Mustang V6
...yes it was the first thing I checked.
Im going to take it in with my tax return and do some regular 70000 mile junk, plugs, wires, flushes...
Old January 20th, 2010, 07:48 PM   #10
1999
YAWN!!! what??
Have you checked to make sure that one of the shocks hasn't broken a mounting bolt?
It's gotta be something simple just have to find it. I also wonder if it is backlash in the rear differential. I had noise in mine a few years ago and ended up rebuilding (new bearings and seals) when I changed to 3.73s.
Threads Similar to: Odd sound
Odd. Fluffy The Rhino The Clubhouse 9 May 28th, 2009 06:13 PM
odd HMUSN The Clubhouse 6 November 8th, 2008 09:23 PM
Stills sound odd Bkbulldog 2005 - 2010 31 October 15th, 2008 05:41 PM
something odd JASonic The Clubhouse 3 June 22nd, 2008 08:37 AM
Sound issue, (sound clip coming later) dgt_mustang V6 Mustangs 5 April 11th, 2008 05:08 PM
