Changing Trans Fluid
Old January 20th, 2010, 06:59 AM   #1
Teamsterjohn's Avatar
2005 Mustang V6
Teamsterjohn is on a distinguished road
My V6 automatic has 40700 miles. Is this a good time to change the fluid and filter on it? Thanks
CAI, UDP, Eibach Pro Kit, Predator performance tune, C/C Plates, Ajustable Panhard Bar, 17 inch rims and tires, GT duals with Pypes X pipe. GT Rear Bumper.
Old January 20th, 2010, 07:07 AM   #2
Stang187 is on a distinguished road
whats the color of the fluid and how much is left?
Old January 20th, 2010, 07:15 AM   #3
2005 Mustang V6
With no dip stick, how can I tell? Ford said every 30.000 miles?
Old January 20th, 2010, 08:52 AM   #4
2003 V6 Mustang
14.2 @ 96
ewells2420 is infamous around these partsewells2420 is infamous around these partsewells2420 is infamous around these parts
Hmmm ..... you have 40k miles and ford says to change at 30k miles ............
Nope youre good for another 40k.
Old January 20th, 2010, 08:56 AM   #5
mattf0509's Avatar
2000 3.8L v6
when i finished track was closed
mattf0509 is on a distinguished road
I've got 110k and never changed it..as long as its still red and full ill prolly never get around to it
Old January 20th, 2010, 09:12 AM   #6
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Change it. And do it asap. Mattf0509, do not change yours. If you are close to the recommend mileage, it is a good idea to change it, and most likely you will never have to do it again. On high mileage cars in which the fluid has never been changed, it is recommended to not change it.
Old January 20th, 2010, 02:53 PM   #7
2005 Mustang V6
I changed it, and replaced the filter also. Now I have peace of mind, and no worries Plus, I have no plans on selling my car. Ford also says 5000 miles for the oil, noway I will ever wait for 5000 miles. Thanks guys.
Old January 20th, 2010, 03:04 PM   #8
Dancing Naked In The Rain
mcqueen's Avatar
Is that for automatics and manuals alike? I know it's true for automatics, just unsure about manuals.
Old January 20th, 2010, 05:12 PM   #9
2005 Mustang V6
The Haynes Repair manual says every 60k miles for manuals
Old January 20th, 2010, 05:20 PM   #10
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
Why not change it??
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old January 20th, 2010, 05:43 PM   #11
stephen has a spectacular aura aboutstephen has a spectacular aura about
Originally Posted by JTs03v6 View Post
Why not change it??
Some people believe that, if it hasn't been changed regularly, changing it
when long overdue can cause problems by dislodging all the friction material that has been worn away and lead to clutch failure, or at least that's my understanding.
Old January 21st, 2010, 08:10 AM   #12
2003 V6 Mustang
14.2 @ 96
Yeah a lot of the times the only thing keeping your tranny together is all the crud. If you drop your tanny pan and there is a lot of metal shavings and/or the oil is brown instead of red ..... dont change it.
Old January 21st, 2010, 01:28 PM   #13
goren813's Avatar
'00 3.8L & '05 4.6L
McQueen that's for auto's, my mistake if I didn't clarify. I changed my trans fluid when I put the new clutch in (5spd, ~120k) and it works well. I'm thinking I want to have the trans rebuilt I'm at 130k now I'm sure it could do better.
Old February 16th, 2010, 11:06 AM   #14
24KStang's Avatar
2k 3.8 5spd
Not yet..
24KStang is on a distinguished road
How do I change the tranny oil I am(were is plug?) @ 100000 now...oh ya 5sp..Thanks
Old February 16th, 2010, 07:41 PM   #15
goren813's Avatar
'00 3.8L & '05 4.6L
i'll post pics when i get home, but the trans has a drain and a fill plug on the pass. side. its a 1/4 drive socket to get them off, drain plug first, catch the oil in a drain pan. put that drain plug back in. its easiest to remove your shifter to have clear access to the top of the trans from inside the cabin. with a length of tubing you can feed down into the fill hole, with the trans oil container upside down inside. if u cut a hole in the bottom of the container the fluid will flow nicely. i belive it is roughly 3 qts (i used royal purple automax, but would recommend mobil 1 fluids). Once the fluid is just below the fill hole its full, or as it overflows stop.
Threads Similar to: Changing Trans Fluid
changing trans fluid? 209STANG 99-04 8 August 2nd, 2009 06:56 PM
Tranny Fluid Changing hellbred07 2005 - 2010 7 October 25th, 2008 10:58 AM
changing trans fluid with royal purple 01dutchGT 99-04 4 October 22nd, 2007 11:55 PM
Changing Tranny Fluid??? Where are the plugs??? Slowbra_12 96-98 3 August 6th, 2007 10:24 PM
Fluid Flush/Changing DSEZ General Tech 1 January 31st, 2007 05:05 PM
