Whos running an M112 kit right now? - Page 3
Old January 26th, 2010, 03:12 PM   #41
Ticket-Me-Yellow's Avatar
2001 Mustang V6
14.89@93 mph
Ticket-Me-Yellow is on a distinguished road
Send a message via AIM to Ticket-Me-Yellow
What size cam would be good to run on a stock bottom end with the m112
Selling Mustang So Im
Selling All M112 Parts
Old January 26th, 2010, 04:14 PM   #42
2001 Mustang V6
14.89@93 mph
is rico still running the 212/218 114lsa cam? If so where can i get it and what else do i need to run it
http://www.youtube.com/user/ChaoticD.../2/3MyT7XhCW4Q
Old January 26th, 2010, 04:25 PM   #43
stangcharger's Avatar
stangcharger is on a distinguished road
Send a message via AIM to stangcharger
http://www.3.8mustang.com/forum/showthread.php?t=254010 post #9
he is via this post he made today. And SSM should be able to custom make whatever you want.
436rwhp/378rwtq tuned by HPP
www.hppmotorsports.com - www.stangcharger.com - www.rpm-mustangs.com
Old January 26th, 2010, 04:36 PM   #44
2001 Mustang V6
14.89@93 mph
what does 114lsa stand for?
Old January 26th, 2010, 04:59 PM   #45
02 Mustang V6
13.605 @ 101.60
Garman91 is on a distinguished road
iTrader: 6 reviews
Originally Posted by JTs03v6 View Post
I have an m-112 in my basement right now in hopes that someone will design an ic and make some decent power.
Call Tom Morana I believe he's taking pre-orders... Or at least he was about a month ago
I do have a question - What actually poses the problem w/ high intake temps past 8-9 psi? Is the heat in the combustion chamber too high (without additional cooling) because of increased intake temps or does the super charger/intake manifold heat up too much causing excessive engine temps?
What I'm getting at is this - would lowering the compression of the pistons help reduce the heat issue at higher boost levels?
I'm building an m112 motor currently. 8:1 pistons, forged 3.8 crank, 25% UDP, dry shot of nitrous on full throttle to cool the intake. Is it possible to overheat the motor during in-town (non WOT) driving w/ a setup like that??
And I think LSA = Lobe Separation Angle
BBK Intake, BBK 70MM Throttle Body w/ Port Matched Upper Intake, BBK Shorty Headers, Magnaflow Exhaust, GT Tips, Eibach Sportline Springs, EGR Delete, Aluminum DS, 7.5 T-Lok w/ 3.73's, Centerforce Clutch, ZEX 75 Shot, Sniper Tuned
Old January 26th, 2010, 05:08 PM   #46
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
lobe separation.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old January 26th, 2010, 05:28 PM   #47
2001 Mustang V6
14.89@93 mph
i honestly didnt have a problem with heat and that was when i was running 8 to 9 psi
Old January 26th, 2010, 05:29 PM   #48
I believe the main problem is just the blower itself, it creates so much friction/heat. and yes if your out of boost you shouldn't have any heat issues in town.
Old January 26th, 2010, 05:30 PM   #49
2001 Mustang V6
14.89@93 mph
would i need anything else to install that cam?
Old January 26th, 2010, 05:46 PM   #50
2001 Mustang V6
14.89@93 mph
also where can i get one? id like to order it soon and not wait
Old January 26th, 2010, 05:49 PM   #51
02 Mustang V6
13.605 @ 101.60
iTrader: 6 reviews
I'm going w/ Comp Cams personally, I'd think you can order a cam w/ those specs from any major cam manufacturer: Comp, Crane, SSMS I think uses Comp Cams...
As far as install, I don't know - sorry
Old January 27th, 2010, 12:33 AM   #52
2001 Mustang V6
14.89@93 mph
yea im just trying to find a one with that duration
Old January 27th, 2010, 11:43 AM   #53
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
there is someone on this site who will custom grind a cam for you. just tell him the specs and he can grind it for you. i can't believe he has not pm'd you.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old January 27th, 2010, 02:28 PM   #54
2001 Mustang V6
14.89@93 mph
no ive been talking to him just he said it would be better if i just buy a new one there for i may not have to buy new springs
Old January 27th, 2010, 02:31 PM   #55
Codeman's Avatar
ok, how good are the stock springs good till?
Old January 27th, 2010, 02:55 PM   #56
2001 Mustang V6
14.89@93 mph
idk thats what i was wondering. like how come i can use them with a new cam and not a reground one
Old January 27th, 2010, 04:35 PM   #57
Codeman's Avatar
hmm, idk maybe it has something to do with how you need to get different length pushrods for a regrind idk?
Old January 29th, 2010, 04:19 PM   #58
sonicstang03 can only hope to improve
call SSM! they can make the cam you will need
2003 3.8l Sonic Blue
2007 GSXR 750
For Sale:
Eaton M112 supercharger/plenum/ and 2 cobra TB's only $375!!! PM me!!
Threads Similar to: Whos running an M112 kit right now?
Whos running the Centerforce Dual Friction clutch? PapaSmurf 99-04 11 October 5th, 2009 08:14 PM
whos running H&R SS' with a 275/315? bullitt ak 99-04 6 March 28th, 2009 02:23 PM
M112 kit??? rejectstang The Clubhouse 3 September 19th, 2008 01:53 PM
M112 kit WLJohnson05 V6 Mustangs 4 December 27th, 2007 03:51 PM
