Foglights???
Old January 23rd, 2010, 01:26 AM   #1
Shelley's Avatar
KEEPIN IT CLASSY...
Shelley will become famous soon enoughShelley will become famous soon enough
Foglights???
Can I splice my foglights into my headlights? I wasnt sure if this was possible or if i have to go through my center console like all the write ups say.
Thank you.
Pankles
Old January 23rd, 2010, 01:51 AM   #2
Indybird's Avatar
2003 Mustang V6 Conv.Auto
Indybird is on a distinguished road
It is technically possible but I would strongly advise against it. One good reason is that its illegal (in all states I believe) to have your fogs and high-beams on at the same time. Unless you wired it up so that they were only on with the low beams.
If I were you I'd just get the proper fog light wire and harness:
97-04 Foglight Wiring Harness for V6 LX
and one of these
Mustang 01-04 Fog Light Switch by Ford
I'm planning on getting those two items when I switch over to a cobra front bumper.
-Indybird
Old January 23rd, 2010, 02:30 AM   #3
RFM 40th V6's Avatar
2004 V6 & 2000 GT
v6-15.0@96.3 GT-12.4@121
RFM 40th V6 will become famous soon enoughRFM 40th V6 will become famous soon enough
You could do it by splicing into the low beam power wire for your head lamps.
When you turn on your high beams the fogs would go out, thus staying legal. I'm sure you could share the headlight ground too. However I would put an inline fuse for each fog lamp.
The only issue that I see is that if a short occurs you won't only lose your fog lamp, you might lose that sides head lamp too.
04 V6/00 GT
460WHP/500WTQ
stock shortblock, single walbro255
Turbo Build
Originally Posted by BML99 View Post
He got ahead for 1 second then MY loltek kicked in and I got 12+ cars ahead.
Old January 23rd, 2010, 06:09 AM   #4
Teamsterjohn's Avatar
2005 Mustang V6
Teamsterjohn is on a distinguished road
I just put foglights on my 05, but I bought the wiring kit. It only took about an hour or so to install the wiring, I took my time when I made the hole in my dashboard for the switch. Foglights go off when the high beams come on with the wiring harness kit.
CAI, UDP, Eibach Pro Kit, Predator performance tune, C/C Plates, Ajustable Panhard Bar, 17 inch rims and tires, GT duals with Pypes X pipe. GT Rear Bumper.
Old January 23rd, 2010, 12:16 PM   #5
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
In my opinion, i would just wire in a switch for your foglamps. That is what i did for my car. I wired them up, and put a fuse inline and then just have a cool switch i bought. It lights up when i flip my foglights on and then i can shut my foglights off when i do not want them on.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old January 23rd, 2010, 12:25 PM   #6
Shelley's Avatar
KEEPIN IT CLASSY...
I already have the foglights and pigtails... so I guess i could just go to autozone or somehting and buy the basic foglights kit with the switch? Does anyone have the write up for this just a simple one not all the mumbo jumbo through the consol?
Old January 23rd, 2010, 12:39 PM   #7
Safud: MM's Resident Hadji
Safi's Avatar
00 v6 & 99 Cobra
Safi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud of
Send a message via AIM to Safi Send a message via MSN to Safi Send a message via Yahoo to Safi
It's very simple to do. Use an add a fuse and wire it to the fuse box and run it to a switch (rocker switches are the best looking for the interior imo). then from the switch run a line out to your foglights
Originally Posted by asiansensation78 View Post
Yeah Safi beat me on OG status lol
Old January 23rd, 2010, 12:48 PM   #8
Shelley's Avatar
KEEPIN IT CLASSY...
Thank you SAFI!
Old January 23rd, 2010, 01:33 PM   #9
Codeman's Avatar
ya the biggest pain is getting the wires through the firewall. just make sure when you drill a hole that you do not drill into anything under the dash, and make sure to use a gromet, or a tight fitting rubber tube to prevent the wires from rubbing through the insulation.
Old January 23rd, 2010, 02:32 PM   #10
Safi's Avatar
00 v6 & 99 Cobra
There is no reason to drill into the firewall at all
Just pass the line through the grommet already in place for the stock wiring
Old January 24th, 2010, 02:44 PM   #11
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
I'd recommend you just buy the OEM foglight switch(can be had for 15-25$) and wire them that way.
We have the correct wiring and plug sitting under our center console so all you really need to do is plug the switch into that, add a wire to the connector under the front drivers fender where the wire ends and then add a relay for power from your battery.
Old January 24th, 2010, 02:48 PM   #12
Codeman's Avatar
i just drilled another one because i could not fit anymore wires through the stock one because i ran all of my gauge wires through the stock one. i found it actually easier when i drilled another one.
Old January 24th, 2010, 04:18 PM   #13
Safi's Avatar
00 v6 & 99 Cobra
How was you not able to fit anymore wires through it? It's fuckin huge
I have 4 gauge wire for my amp and 2 8 gauge wires running through there...A foglight wire doesn't need to be big at all...just a little 12 gauge line
Old January 24th, 2010, 05:46 PM   #14
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
+1 i have a bunch of stuff running through mine. if it is tight you could cut it just a little and that will open it up more
SCT Mass Air Flow Sensor $200
Old January 25th, 2010, 01:58 PM   #15
2004 V6 Coupe
04stang123456789 is on a distinguished road
Sorry to jack this thread, but where can I find the actual fog lights and pig tails for the best price?
Old January 28th, 2010, 05:47 AM   #16
Shelley's Avatar
KEEPIN IT CLASSY...
We have the correct wiring? I have no wiring... Or else I would just buy the oem switch. This is why im thinking about buying a cheapo one and hiding it somewhere.
04stang... if your just looking for pigtails and fogs not the whole set you can find them cheap on ebay!
Old January 28th, 2010, 11:33 AM   #17
Dancing Naked In The Rain
mcqueen's Avatar
Unless the previous owner cut the connectors out, they should be in there. They're just hiding from normal view. If you open the center arm rest, remove the 2 rubber stops, remove the 2 screws, then remove the "pocket" (I guess you could call it) then you'll be able to see inside the center console. In there are 2 connectors that completely stock V6s have no use for. One of them is for a fog light switch. The OEM fog light switches are exactly the same size as the coin holders and it just so happens the connector is located right by the coin holders. Pop a coin holder out, pop the OEM switch in, connect the fog light connector and it'll look like the car came straight from the factory with fog lights.
Old January 29th, 2010, 02:14 AM   #18
WhtStang00's Avatar
2000 Mustang V6
WhtStang00 will become famous soon enoughWhtStang00 will become famous soon enough
Send a message via AIM to WhtStang00 Send a message via MSN to WhtStang00
whats the other connector for then?
White 2000 V6 Mustang|Black Saleens 18x9|Flowmaster 40s|AM CAI|8000K HIDs|SCT XCAL III/H&R SS
Old January 29th, 2010, 11:24 AM   #19
SSj_Guitarist's Avatar
2004 V6 'Stang
NYT
SSj_Guitarist is on a distinguished road
Send a message via MSN to SSj_Guitarist
This is what I did to put foglights in my car, it was super easy and only took about 3 hours..would've taken less time but I had to go to the store to buy a proper screwdriver...just get one with a really long neck. VMP Tuning - Buy Ford SCT & GM Custom Handheld Flash Tuners Performance Economy Towing: 01-04 CLEAR GT Foglight Kit
My 'Stang
Old January 29th, 2010, 01:14 PM   #20
It should be for the convertible top switch.
Threads Similar to: Foglights???
96 foglights HELP! theyanks904 V6 Mustangs 1 April 15th, 2009 08:58 PM
Foglights chromestang01 V6 Mustangs 2 April 15th, 2009 07:55 AM
Foglights? BLK01SS Chopshop 3 September 9th, 2008 07:15 PM
foglights Nick_Rapitis V6 Mustangs 7 August 15th, 2007 12:28 AM
