v6 crate motors? - Page 2
Old January 28th, 2010, 01:08 PM   #21
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
ya do not listen to the people to tell you about swapping in engines. just swap in a stroker and your car will be QUICK!!!!!
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old January 28th, 2010, 01:13 PM   #22
stangcharger's Avatar
stangcharger is on a distinguished road
Send a message via AIM to stangcharger
plus if the route is going to be turbo the 4.2L forged motor will be able to handle 600+rwhp easily and the 5.0L will try and crack on ya at 500rwhp. With a built stroker motor and turbo 500rwhp will be easy as pie. Then it will just be getting the tranny and rear end to handle it.
436rwhp/378rwtq tuned by HPP
www.hppmotorsports.com - www.stangcharger.com - www.rpm-mustangs.com
Old January 29th, 2010, 12:55 AM   #23
95 mustang v6
mustang95 5.0 is an unknown quantity at this point
Send a message via AIM to mustang95 5.0
Originally Posted by ReverendDexter View Post
Huh. I thought the 3.8 used the smallblock bolt pattern.
If it doesn't, it'd probably still be worth beefing up the internals of your T5, assuming that you have a manual. An AODE/4R70 should be fine with those power levels assuming it's not overheating.
no its an auto
F.O.R.D
First On Race Day
enough said
Old January 29th, 2010, 12:58 AM   #24
95 mustang v6
Originally Posted by goren813 View Post
But I agree with Rev, get the stroker, see how long the rear holds. Will be a quick car with that motor.
ya if i can afford the motor by the summer i will drop it in and see how long the trans and the rear end hold up. do you know how much hp and torque the auto trans can handle by any chance? Because rear end and new built auto will be my next mods after the motor is put in
F.O.R.D
First On Race Day
enough said
Old January 29th, 2010, 01:03 AM   #25
95 mustang v6
thanks everyone thinks bigger is better, and dont get me wrong i love v8 mustang, but this stroker motor looks like a real good buy, i was looking into buying one from supersixmotorsports and it said a stroker can be built to have around 350-390 hp n/a depending on what you want. for around 7-8k i thinks thats a great deal just hoping the tranny holds.
F.O.R.D
First On Race Day
enough said
Old January 29th, 2010, 01:05 AM   #26
95 mustang v6
Ya my first priority after getting this motor put in is to save up for a tranny and a new rear end, then go after a turbo unfortunatly everything takes time and money so motor first lol
F.O.R.D
First On Race Day
enough said
Old January 29th, 2010, 09:30 AM   #27
95 mustang v6
thanks everyone for some really good feed back. I would want to get a twin turbo to run lower boost and get maximum hp but i have heard you need custom made ac lines and other modification.
F.O.R.D
First On Race Day
enough said
Old January 29th, 2010, 11:11 AM   #28
Honestly there really is no need for twins for what most want to do. The single is going to kick in faster than a centrifical and make more lower and high end power. Plus you will be able to make your goals with one i promise.
Old January 29th, 2010, 12:49 PM   #29
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
^Agreed. You will see if looking around that most people use singles and get high numbers. I am in no way suggesting following the crowd just for the sake of fitting in, but there's a rhyme and reason to it in regards to turbos on these, and actually most, cars. People tend to automatically think more is better, but this isn't the case.
Old January 29th, 2010, 02:03 PM   #30
Codeman's Avatar
also, you auto should easily hold the power that your stroker is making. that is if you keep it cool. your rearend is another story.
Old January 29th, 2010, 05:36 PM   #31
rear end will be a matter of luck and the auto in good shape with J-mod and whatever cooling yall do will hold 400rwhp or under for a good amount of time. J had more than that on his for awhile. then when it goes just beef it up and make almost whatever you want.
I have had some luck. I am still on my 7.5 rear.
Old January 30th, 2010, 05:36 AM   #32
Ghostly Echo's Avatar
2009 Mustang v6
Ghostly Echo is on a distinguished road
Send a message via AIM to Ghostly Echo
isnt it cheaper to build your own ?
I made a boo boo
Old January 30th, 2010, 04:19 PM   #33
95 mustang v6
ya i wanted a single but i didnt know that a single actually spooled up faster than a twin, i thought the twin were smaller than a single so they would spool up faster? If thats the case then i will def go with a single setup, cause there a lot cheaper than a twin.
F.O.R.D
First On Race Day
enough said
Old January 30th, 2010, 07:19 PM   #34
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
Twins will have less lag...but with the right single you will be just fine.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old February 1st, 2010, 01:03 AM   #35
95 mustang v6
thanks for the info, not really to knowlegible about turbo's in general
F.O.R.D
First On Race Day
enough said
Old February 1st, 2010, 01:04 AM   #36
95 mustang v6
thanks everyone very informative and helpful thanks again got alot of good feed back.
F.O.R.D
First On Race Day
enough said
Threads Similar to: v6 crate motors?
Build up or buy crate engine?? Where to go for crate engine cgb6810 5.0 Mustangs 17 October 27th, 2007 10:33 PM
Crate engine Wally1968 2005 - 2010 9 September 11th, 2007 04:11 PM
Crate Motor dblindberg 2005 - 2010 0 March 11th, 2007 01:18 PM
Crate Engine jkonfuzhon 94-95 13 March 2nd, 2007 04:46 PM
GT40 Crate! jkonfuzhon 5.0 Mustangs 7 February 27th, 2007 12:40 AM
