C4 transmission
Old January 28th, 2010, 01:33 AM   #1
2000 Mustang V6
Bigg_Nate is on a distinguished road
C4 transmission
OK to start off Hi everyone long time no talk. lol. BUt on topic I have a 2000 v6 mustang automatic it has the 4r70w ( sure yall know) im wanting to put a c4 in it. I know it will bolt up but what other problems will i run into? Driveshaft, speedo gear, input shaft, etc ANy help would be greatly appreciated my tranny is about to go out.
Old January 28th, 2010, 09:51 AM   #2
shine1stang's Avatar
97 v6 mustang
10.71@125
shine1stang is on a distinguished road
first off y they heck would you want to put a c4 in it? I have one and although its good for racing, it totally sucks on the street and long drives.
Anyway to answer more of your questions; your driveshaft will work but you need a c4/t5 slip yoke. The 99+ had the electronic speedo gear so you'll have problems there. The c4 trannys have the mechanical teeth for the speedo gear. Maybe someone on here has done a speedo swap that could help you with that
97 v6 tma turbo
600hp and 10 sec v6 member
xxxhp @21psi 10.71@125mph
http://www.youtube.com/watch?v=hBoRWBr77Do
Fastest Single Port V6 Mustang w a Ported Stock Upper Intake
www.gssmotorsports.com
Old January 28th, 2010, 03:42 PM   #3
2000 Mustang V6
it was just an idea. i need a tranny but dont feel like spending 300 for a 4r70w than the 170 shift kit and a 150 manual valve body and then 500 for a 2000 stall torque converter and than gears and t loc. Im wanting to add a little get up to the sixer its to slow right now and in college trying to find the cheapest route being money is tough plus paying for school. I was just thinking the c4 might make iot a little quicker. Any one know where i can get a used transmission. The cheapest 4r70w i found was 278 with 70,000 miles on it
2000 full duel flowmaster 40 series with H pipe, roush stage 2 kit, 18'' ruff racing rims, k and n intake, sequential tails, and more
Old January 28th, 2010, 03:46 PM   #4
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
What is wrong with your trans?
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old January 28th, 2010, 03:51 PM   #5
2000 Mustang V6
slipping going into second, doesnt always lock overdrive in, and the car is pulling horrible weak like i would get outrun by my buddies b16 crx
Old January 30th, 2010, 04:57 PM   #6
2000 Mustang V6
anyone know where i would be able to get one from
Old January 30th, 2010, 06:52 PM   #7
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
http://redneck-peformance.com
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old January 31st, 2010, 04:46 PM   #8
2000 Mustang V6
no the 4r70w
Old February 1st, 2010, 03:07 PM   #9
2000 Mustang V6
and also would the v6 tranny hold up to a 302 if so would the torque convertor or anything like that need to change
Old February 1st, 2010, 05:46 PM   #10
97 v6 mustang
10.71@125
yes the v6 tranny will hold up to the 302. They only put out a lil more power than you make now. You will need to make sure you use a flexplate for the 302, for the balancing. The converter will bolt right up. The 4r70w is a strong tranny and has proven up to 500whp, with a jmod and new converter. The stock converter starts slipping in the 300hp range.
97 v6 tma turbo
Old February 1st, 2010, 10:51 PM   #11
2000 Mustang V6
ok good im thinking about getting a 302 bored to a 308 port and polished heads with 3 angle valve job small nitrous cam(dont know what size) i have seen this motor run a 8.50 in a 95 mustang with an automatic with overdrive. How much will the v6 tranny and gearing effect this time? Thanks for all the info guys
Old February 2nd, 2010, 08:25 AM   #12
97 v6 mustang
10.71@125
u must be saying 8.50 in the 1/8 mile right? 302 blocks have been know to split at 500hp or so. If you wanted to drop in a v8, just get a 351 block and stroke it to 410 cid. Our partner in crime builds 410 strokers that run 9s (in the 1/4) on motor.
gssmotorsports.com, his car is the blue one in the gallery
97 v6 tma turbo
Old February 2nd, 2010, 08:28 AM   #13
97 v6 mustang
10.71@125
sorry totally skipped the tranny question. Well if you get a converter that is properly matched to your setup the car will run better. I really dont believe there is any difference in the 4r70ws. Either way you are gonna need like i said above, jmod or aftermarket vb, and converter.
97 v6 tma turbo
Old February 2nd, 2010, 02:55 PM   #14
2000 Mustang V6
o ok. Cool well i can get this motor for 300 its my cousins and to be exact his time is 8.41 on motor in the 1/8. So as long as i get a valve body and torque converter i should be fine. One more question. What type of converter are you talking about and what type vavle body. Sorry for all the questions i just know how to do it and make the changes and modifications just not sure what would be the best. I will be spraying the car also with about a 125 shot.
Old February 2nd, 2010, 03:49 PM   #15
97 v6 mustang
10.71@125
is this motor goin in the 2000 mustang? Is the 302 carbed? If not then you have a lot of work ahead of you... Its just not worth the hassle!!!!! At all!!! Im not sure if the 302 will drop right in your kmember. I know when they changed from the 302 to the 281(4.6) platform they changed k members too.
For the tranny crap contact bc-automotive, Darrin knows his stuff
97 v6 tma turbo
Old February 2nd, 2010, 07:15 PM   #16
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
A 302 is going to be a waste of time. Go with 4.6pi or dohc. If your impressed with a 302...you will damn sure be impressed with a boosted or sprayed 6...4.2 with a cam would be the sweet spot imo....and a whole hell of alot easier to swap in.
Old February 2nd, 2010, 07:22 PM   #17
97 v6 mustang
10.71@125
Isnt that the damn truth!
97 v6 tma turbo
Old February 3rd, 2010, 12:12 AM   #18
2000 Mustang V6
ok well thanks for all your info guys it really helped
Old February 3rd, 2010, 12:15 AM   #19
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
I wouldn't street a C4...rebuild yours if needed get a shift kit, stall, and transcooler and your good man.
Old February 4th, 2010, 05:05 AM   #20
tooldrmr2009 is on a distinguished road
hey if your interested...just a thought. i have a 2001 v6 auto tranny laying around currently in the garage. It was pulled from the 01 with about 75k on it and shifts beautifully, just needs a new torque converter anyway but its all there. I picked it up from a combo with a motor, trans ect from a guy that did a 4.6 swap in his 01 v6. if your interested shoot me a PM ill let it go for really anything its no use for me.
Threads Similar to: C4 transmission
A-5 Transmission screwed by twins 5.0 Mustangs 3 May 9th, 2009 07:25 PM
Transmission Help! 1sl0w88 5.0 Mustangs 7 February 2nd, 2009 10:53 AM
Transmission???? flamed 98 gt 5.0 Mustangs 34 January 28th, 2009 09:17 AM
F*** I need a transmission!!! 99spaded 99-04 32 August 26th, 2007 11:15 PM
Transmission cbrown 99-04 21 August 20th, 2007 03:58 PM
