a lot of talk about cams lately
i had a cam spec'd out for me and i told them my goals for the car, like im gonna be n/a for a pretty good while and it was my dd and he spec'd 2 n/a dd cams at-
-210/218 .55lift 112lsa -218/224 and im guessing at the same lift and lobe seperation, since he didnt specify. he said the second one would prolly be a little rough on a daily driver though, and i also want to be able to hear the cam, ya know what i mean? and if the second cam would just effect my gas mileage i wouldnt really care but if it was actually rough on my motor, then i would care. lol would there be much difference in sound and power between the two? and much difference on the wear on the motor? Last edited by joshridge; January 29th, 2010 at 12:11 PM. |
good question, I am curious also, since those are both of the specs for cams that i am looking at. Mine is also a dd but i dont care about mpgs. so same question
![]() UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors |
...who are you getting your cam from? same guy as me?
idk yet. I have been looking at a ton of different sites, and those two specs were what i was looking at.
hmm must be good sizes then. lol
we need answers and we need em now!
2000 Mustang
14.10@96.75
what year is your car and what are your current mods and your near future mod plans?
2000 V6 vert 2003 Lightning |
umm i have a 2002 and i plan on getting 3.73 gears, udp, dual exhaust setup and like a sct xcal III tuner in the near future, and all i have is a cai, but at the same time i get the cam im getting the whole h/c/i package.
do you ever plan on doing nitrous, turbo, or supercharger? I have heard that nitrous, supercharger, and regular n/a cams, are all similar specs, and turbo cams, are different.
eventually but im just looking for n/a power right now. id more than likely go supercharger though just because theyre easier to find.
my first cam in the 3.8L n/a application was a 208/212 and can't remember the lift or LSA. So that first cam is a pretty good one for a 3.8L N/A DD. I think we are finding out more and more our near stock motors may favor a smaller duration cam with a higher lift.
436rwhp/378rwtq tuned by HPP www.hppmotorsports.com - www.stangcharger.com - www.rpm-mustangs.com |
#12 | |
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
Having said that, both the cams in the OP seem to be plenty streetable to me depending on what transmission and rear gear is being employed. In the end, you just have to decide what you are willing to giveup in driveability to gain power. This is not a science and usually people go through several profiles before they decide what is really the best split of convenience and power.
#13 | |
2006 mustang GT
No. I dunno exectly what goes into making a turbo cam but I am pretty surethe difference is in the LSA and degree of the exaust lobe for quicker spooling SC cams will tend to have more intake duration so they can take in more of that pressurized air. nitrouse cams will have alot of exaust duration and typically a wider LSA. the wider LSA helping to keep the combustion pressure generated by the NO2 in thier, and the bigger exaust duration to help get all that hot exaust out ASAP. N/A cams usually tend to be just a bigger version of a stock cam. THAT BEING SAID, it is ok to run a N/A cam on a SC, turbo, or NO2 motor as long as the N/A cam is not to extreme. just don't expect the optimal gains you would get with the correct cam. typically NO2 cams on a N/A motor will give you a badass exaust sound and are ok to use, however once again you will not get the power gains you would with the correct cam. DO NOT try to use a SC or turbo cam on a N/A motor. you will spend all that money, do all that work, and even if by chance you de get a few extra hp the motor will run like crap.
2006 Mustang GT. JLT, UDP's, CMDP's, Bamachips 93tune, LCAs, panard bar, spray, assorted madness. 7.79 @ 90.5 in the 1/8 like a BOSS
#14 | |
MM's Mad Scientist
Slow Fella
2006 mustang GT
I was generalizing and not giving exact numbers. to sit here and try to do that with all the different cams out there would be rediculouse.
and the bottom part of that is based off of motors I have actually worked on and my experiences of taking a N'A cam and then boosting it. and seeing what happens when people take non boosted motors and put boost cams in them and ect. if it is so laughable, state something that proves me wrong.
#16 | |
MM's Mad Scientist
Slow Fella
#17 | |
2006 mustang GT
zippeewannabee
you my friend are arguing with the king of cam building. I would generally think that whatever he has to say about cams (mod motors in general) is correct. just my .02
![]() Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount |
I did not know, but that is just what i heard people say that most na cams will work for nitrous or sc. I know obviously now that you will not get the most power, but they will work
MM's Mad Scientist
Slow Fella
Question of the decade. You should stick to the visual mods section.
Threads Similar to: a lot of talk about cams lately
| A lot of Questions ??? | McMustang5.0 | 5.0 Mustangs | 14 | January 19th, 2010 07:04 PM |
| so I know a lot of you are scared of...... | 97Cobra | The Clubhouse | 4 | July 31st, 2008 06:12 AM |
| baine21225 ..... THANKS A LOT | SALIV8 | 5.0 Mustangs | 1 | June 5th, 2008 10:13 PM |
| Just ordered A Lot! | 1BADSTANG | 5.0 Mustangs | 18 | May 8th, 2008 12:40 PM |
| lot seems to happen when gone. | SWEET2KSTANG | The Clubhouse | 20 | May 5th, 2008 09:20 AM |
