battery
Old January 30th, 2010, 09:07 AM   #1
Stang187 is on a distinguished road
battery
my battery keeps dying and i took my car to auto store and both alternator and battery checked out to be fine, though battery needs to be charged. So they charge it and give it back, about a week later my battery dies again. I've made sure nothing is left on like a light or charger plugged in etc.
what would cause this?
Old January 30th, 2010, 09:08 AM   #2
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
Did they load test the alternator? How many amps was it producing? Do you have a parasitic draw?
TT Build in progress.......
Old January 30th, 2010, 10:31 AM   #3
Matt.'s Avatar
2002 Nitrous Injected V6
12's?
Matt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the rough
Project Red Magic
-Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped-
-18 Inch Hypercoated Saleens wrapped in Nittos-
Old February 8th, 2010, 02:20 AM   #4
joe_shizzle's Avatar
1999 3.8l v6
14.7 @ 100mph
joe_shizzle is on a distinguished road
Send a message via AIM to joe_shizzle Send a message via Yahoo to joe_shizzle
if you have a digital volt miter, you can check the amps drawing off the battery, simply disconnect the negative cable, and put one lead on the cable, and the other on the post, if anything really over 3 amps, then you start pulling fuses to see which circuit is the problem, then you can go from there to solve the problem, it happend to me with my cd player. thats why i know lol
Old February 8th, 2010, 02:37 AM   #5
\/ Hidden Bewbs \/
sikedsyko's Avatar
01 Cobra Vert
sikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to behold
Check for corrosion on your battery terminals? If not check to see if something on your car isn't staying on when even after you turn the car off.
MM Cobra Club #66
Old February 8th, 2010, 06:05 AM   #6
longalan2's Avatar
2007 mustang v6
8.903 1/8 @74.96
longalan2 is on a distinguished road
my 07 v6 did that also. it turned out that the battery was not making good connection . at first i thought that it was the udp doing it, but it was the terminals.
Old February 8th, 2010, 08:40 AM   #7
99 mustang
clidefr0g is an unknown quantity at this point
Make sure you don't have a dime stuck in your lighter socket.
Old February 8th, 2010, 11:50 AM   #8
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
All of the above are good suggestions. I would recommend cleaning the posts like they said above, along with cleaning the clamps. Then you can check the amp draw, and see if you have a parasitic draw like above said
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Threads Similar to: battery
battery ? dtom 2005 - 2010 3 October 14th, 2009 11:54 PM
need new battery? johnbarberr V6 Mustangs 1 September 18th, 2008 01:15 AM
battery joescarff V6 Mustangs 13 February 11th, 2008 07:22 PM
battery relocation with second battery onewinner 5.0 Mustangs 1 May 30th, 2007 11:30 AM
Battery Mustang Mike 99-04 2 February 27th, 2007 07:07 PM
