Exhaust and fuel questions for a procharger setup
Old January 30th, 2010, 03:18 PM   #1
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
So I just bought a slightly used 3.8", 7psi procharger kit for my 2000 v6 because the price was right. I'm not looking to make a drag car or anything of the likes but would very much enjoy having something reliable around 275-300hp. I may end up running higher boost later on but for now I'll just leave it around 7psi.
As for fuel questions:
The seller told me it's coming with the 30lb originally included with the kit, is it normal for procharger kits to only come with 30lb injectors and will they be enough?
I have a 03/04 focus SVT pump on it's way as well and from what I've read that should provide sufficient fuel for a v6 procharger application. Does anyone have experience with maxing out a 03/04 SVT pump and if so about what HP was that at?
As for exhaust:
Right now I have completely stock exhaust. How severely is that going to limit the power made from this kit? -I'm wondering if I should try to upgrade that first even though I'm a bit low on cash at the moment.
Old January 30th, 2010, 06:18 PM   #2
9986paulk's Avatar
1999 Mustang V6
9986paulk will become famous soon enough
The exhaust shouldn't be that much of a problem, but I would go duals somehow, cheapest way is with an h pipe adapter and GT takeoffs. And i'd think the focus pump would go to 400hp.
Old January 30th, 2010, 06:26 PM   #3
stangcharger's Avatar
stangcharger is on a distinguished road
Send a message via AIM to stangcharger
yup 2.5in mid pipe to cat back if you can. fuel mods should be fine.
436rwhp/378rwtq tuned by HPP
www.hppmotorsports.com - www.stangcharger.com - www.rpm-mustangs.com
Old January 30th, 2010, 06:45 PM   #4
How exactly does that work with the V6 bumper? Wouldn't it place the tips in the same spot as on a GT?, IE inside of my bumper since I have no cutouts.
Old January 30th, 2010, 07:01 PM   #5
9986paulk's Avatar
1999 Mustang V6
all you do is shim it down with whatever i think what i have under each one is a 1" piece of square pipe.
Threads Similar to: Exhaust and fuel questions for a procharger setup
8 rib procharger setup.... BakerFX4 99-04 3 December 15th, 2009 05:47 PM
stock exhaust setup questions.. warrior86 2005 - 2010 35 February 16th, 2009 11:31 PM
procharger setup 07stanggt 2005 - 2010 22 July 16th, 2008 11:56 AM
